Dustbuster batteries won't hold a charge.
When my Dustbuster stopped working, I assumed the NiCd cells were bad. Upon opening the unit and testing, the batteries are all good. I noticed that the power adapter is 15V AC, which made me look for a diode to convert the AC to DC, but I can't find one. I was able to charge the batteries using a different (DC) adapter and the Dustbuster works fine. There MUST be a diode in there somewhere. What am I missing?
  • Computers & ... Master
  • 16,210 Answers
The AC is not full sine wave. The diode is in the wall adapter
Posted on Jan 16, 2013
  • 2 more comments
  • gkane3999 Jan 16, 2013
    Thanks for the suggestion, Brad, but the adapter output is AC...no diode. The diode MUST be in the Buster, but I can't find it.
  • Brad Brown Jan 16, 2013
    The ones that I know have a box on the end of the cable and the lugs plug straight in the wall, If you are measuring the voltage at the charging station and it is AC then the diode in box is bad. Note these are not able to be disassembled without breaking them
    http://www.amazon.com/Black-Decker-Batte...
    The sticker on the adapter says "15V AC 130mA." (P/N: 90500910.)
harvester3
  • 181 Answers
SOURCE: Toshiba Satellite A105
The most common problem on these units is the ac connector solder joints break away from the motherboard. If you're sure the ac adapter is working, and the correct one, and it's not charging the battery (assuming the battery is good), it's most likely the problem. They don't have to appear loose to be loose.
Otherwise, it's motherboard time, or a loose screw, etc has caused a dead short on the board.
Good luck, if you have additional info, let me know.
Posted on Feb 09, 2008
Bogdan
  • 198 Answers
SOURCE: My PC won't run with ac /dc power!
Hello. There is a hardware failure with the laptop not the AC charger. AC chargers have some range of protections of their own. If the power requirements of the laptop are bigger then what the charger can handle, the charger will turn off. Also other parameters can bring the charger offline. In your case, you have a problem with a small chip, the battery charge controller unit, witch regulates the amount of current required to propperly charge the battery. When this thing fails, the charging requirements for the battery are reported rong and the AC charger is forced to give more power then necesary. This results in disconnection of the AC charger ( an internal fail safe of the AC charger) and the laptop to swich back to battery power. When the laptop is turned off, it can charge the battery because the power requirements are low, having all processor, main board, hard disk etc turned off. Therefore the AC charger can handle the load. However you will need to have it checked by a service center as it is a hardware fault. Both AC charger and laptop needs that check. The charge controll circuit needs to be replaced probably. It will be a somewhat expensive repair. Don't buy any other battery untill you have the laptop checked. For more aditional info please post back. PS. Sorry for my bad english, I am from Romania, it is pretty hard for me to explain tehnical stuff in english.
Posted on Feb 16, 2007
Pyrhyc
  • 2028 Answers
SOURCE: Thinkpad T43 wont get any AC power
I've run into this many times with IBM machines. The power management chip on the motherboard has failed. Unfortunately, you will have to replace the motherboard in order to fix the problem.
Posted on Aug 13, 2008
joecoolvette
  • 5660 Answers
SOURCE: dv6000 443775-001 power issue
At the risk of subjecting myself to your possible wrath, I suggest you replace the motherboard. I don't know your computer repair prowess, and am not doubting it for a minute, but I 'stand' here to tell you, that it's just not that simple.
The hardware components are installed down into a bare motherboard. The leads for the hardware components are in their 'raw' state, where they hang down past the motherboard. Then the motherboard is heated up using a hot air soldering method, and the solder flows over the leads making a precise, pretty little solder joint. This is done with robotics. Once this is accomplished, the extra length of lead is snipped off.
Some components are installed by hand. Very few of them. The operator uses a soldering station, and an instrument that magnifies the area by a great amount. Looks like a binocular microscope. One, two ,three, and the next motherboard comes up, and the same part, by the same operator is installed once more.
Again, not doubting your expertise in this area, but if you have use much heat, or linger too long, you stand the chance of making the copper circuit trace, lift right off of the motherboard, when you go to remove a component. Not enough heat, and you can't remove enough solder, nor get the lead to come out of the hole. (I use solder wick. Also known as Desoldering Braid. Solder ****** tools are for the bird's! (Desoldering Tool)
Same thing with soldering a new component in place. Too much heat or linger too long,....well you know what happens. Not enough heat, or staying in position long enough, plus using the right technique, you get a cold solder joint. It's a lot of fun, when you reassemble the laptop all the way, and find this! Guess what happens next? Yep! Do it all over again!
I'm not a saleman for Ebay, but I find a lot of my motherboards for laptops on there. I would also suggest looking at -> Laptops for Parts.
Posted on Apr 14, 2009
issken
  • 1472 Answers
SOURCE: dell 1525 not charging. dc usb board replacement
rubberman
Sorry to hear that you are still having trouble. The only other thing to try is your battery on your buddies notebook. If it works there then it is the charging mechanism on your notebook and this would mean replacing the motherboard.
Issken
Posted on Jan 11, 2010
My 9.6v DustBuster doesn't hold a charge
Does the charge light come on when you plug in the charger? If not, the charger or cord is probably bad. If it seems to charge but you're not getting as much time as you used to, the battery probably needs to be replaced. Check your warranty and call dustbuster or go online to purchase a new battery. Another alternative, especially if it is out of warranty is to take the unit to a Batteries Plus store and have them replace the battery.
May 01, 2017 | Vacuums
Not charging
The chances are that the battery has failed. The age of the device would indicate that the battery is probably NiCd - these batteries have a memory effect that means after a while the battery thinks that "fully Discharged" would be the state that is the most usual for the charger to be used most often. You will need to open the device to get the battery out to find the part number. You will then be able to order on from an online retailer.
Jul 11, 2013 | Aluratek APMP101F Cinepal HD Media Player...
Battery will not charge
li-Ion batteries have a bad habit: whenever fully depleted, they lose a few cells, to the extent that they might not be able to hold a full charge if enough cells are damaged. In other words, repeatedly using a laptop (or any other Li-Ion powered device) to battery depletion can shorten the battery's life significantly. You might want to keep the batteries fully charged whenever possible and avoid fully depleting them too often.
There is also the habit of "re-setting" the batteries by using the "fully deplete-fully charge" procedure. It only applies to niMH or NiCD batteries ( and is used to erase the "memory effect" ) but is damaging to Li-Ion batteries for the reason mentioned above.
so if your battery can not full charge,this mean you need change a new battery for your laptop
http://www.aulaptopbattery.com.au
Oct 05, 2012 | Computers & Internet
Should the red light on my 15.6v dustbuster turn green when it's fully charged? It doesn't.
I had the same issue, then i just found the manual, in charging part, it says:"The charging indicator will be lit as long as the
appliance is connected to the plugged-in
charger."
Also it says:"While charging, the charger may get warm, this is
perfectly normal and safe. It can remain on
charge indefinitely without damage or danger. It
is not possible to "overcharge" the battery cells
with the charger provided"
Jul 29, 2012 | Black & Decker 15.6 Volt DustBuster Vacuum
I put in a new battery and now the radio beeps when it is keyed up. I put the old battery back in and it works fine. Both batteries fully charged. Any suggestions?
A beep when keyed up can mean a low battery.
1) It is possible your new battery did not take its initial charge, it can take as many as 3 chargings to 'jump start' a new battery. You might try charging the battery an addition 2 full charge cycles.
2) Try the new battery in another SP50 radio to see if it works, or test with a volt meter, if available.
3) Double check the battery is the correct HNN9018 or equivalent NiCd battery. If you are using an after-market battery, check to see if it is a NiCd. If it is a NiMH battery you will need a fast rate charger to charge it up. (On an SP50 the fast rate charger has a blue button on the tray which needs pressed to put it in fast charge mode)
4) This may sound silly, but check to see you installed the battery the correct way. On a Motorola battery the STOP sign would not be visible when installed correctly.
5) If all these items do not solve the 'new battery' problem, you should return the battery to the place of purchase for an exchange.
Best regards.
Sep 17, 2011 | Motorola For SP50 7.5v 1500mAh NiCd...
I have a philishave 905 and the original batteries were 600mAh 1.2V Ni-Cd. Once (6 years ago) they were replaced with 700mAh Ni-Cd without any problem. Recently I had the batteries replaced again in a...
Hi!
Warning ! NiCd and NiMh are two different technologies that require different type of charger !
Never replace NiCd with NiMh because a charger designed to charge only NiCd won't be able to detect end of charge of NiMh.
There is a risk of overheating and destruction of batteries and worse, destruction of the appliance !
(At the opposite, a charger that can charge NiMh can charge NiCd))
Regards,
Steve
Nov 25, 2010 | Philips Health & Beauty
Where can I get battery power pack(shell with recharchable batteries inside) for metz 45 cl series,good second hand,off market brand,or even geniune brand,thank you
I have a lot of old 45-40 Series Metz 45 NiCd battery packs, that I will eventually rebuild with new NiCd batteries. I got them from Photographic Trader magazine and from ebay. I've heard that NiCd cells are going out of production, in favour of NiMH cells. I've found it's easier to put NiCd or NiMH cells in the alkaline battery holder, the flash recycle time is only slightly longer. I charge them separately out of the holder, or in the holder with a connector I made. NiMH cells need a suitable charger, with peak detection, as NiMH cells don't like being overcharged.
Nov 05, 2010 | Metz mecablitz 45 CL-4 TTL Flash
SONY MDRIF610 Wireless infrared headphones -- I have two sets that won't work -- the Infrared units light up, but I get nothing from the headphones, which haven't been used in a long time and don't seem to...
Hi, to reach the internal battery You have to 1) gently detach the L(left) internal soft ear cover from the headphones, 2) Unscrew the 4 internal screws -- To replace the original NiCd 600mAh battery, You have to unsolder the contacts of the old battery and solder the contacts of the new one. You must buy a battery with soldering tabs, because tabs are very hard to solder well. - Yes, ONLY with this model You may use a NiMh battery, because the original charge-circuit was designed to stop after the battery is fully charged. (NOT many NiCd battery chargers have a cut-off circuit based on battery charge. they use only thermic protection cut-off) -- I've used 2800mAh NiMh to solve the problem, but I'm thinking to use the new hybrid cells battery, because they have a very small discharge rate when are not in use. -- No, You must not use LiIon or LiPo because they need a more precise charging rate and they may explode.Simply don't do that! ;-)
cheers, Rcatech
Nov 21, 2009 | Sony MDR-NC11 Consumer Headphones
Defective Ni-Cad Battery
Try Re-Conditioning the battery first. Full procedure at: ysuusy.com/easybatteryfix.html
"Cordless Power Tool Batteries and other batteries that contain Nickel Cadmium (NiCd) Cells can be Re-Conditioned to perform as well as new or even better than new. Proper maintenance after the procedure will insure years of usable life.
The First and most common procedure for Re-Conditioning a NiCd cell is by using a Technique called "VOLTAGE SURGING". Over time the crystals within a NiCd cell begin to combine and get larger. This causes them to loose capacitance and also break through the inner seals of the cell.
Surging the NiCd cell using a higher voltage causes the crystals within the NiCd cell to shatter and become smaller. These smaller crystals have a greater surface area and therefore contain a greater capacitance for energy. "
Jan 17, 2009 | Batteries.com 8148 Nickel Cadmium 2-Way...
Motorola t5000
I'm assuming you're using the NiCd batteries. NiCd batteries do not last forever and need to be replaced when they show a resistance to beign charged. To optimize the life of these batteries you need to let them fully discharge before attempting to charge them. This is impractical most of the time.
You have two choices:
1. Purchase a NiMH charger and AA batteries and use that INSTEAD of the CHARGER STAND and NiCd batteries. This type of battery can be recharged without the problems discussed earlier and will last longer... or
2. Purchase another NiCd battery pack.
Oct 24, 2008 | Motorola T5000 Two Pack 2-Way Radios with...
Computers & Internet Logo
149 people viewed this question
David Payne
David Payne
