Question about Amana NDE2330AY Electric Dryer
Dryer runs for awhile and just quits - Amana NDE2330AY Electric Dryer
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 69 Answers
The dryer motor has a thermostat in it ,when the motor has been running a while it shuts it off so it dont get too hot,may have to change it or the motor
Posted on Jan 16, 2013
How do I fix the squeaking when the dryer starts up in a fridiadare gallery dryer with model number 341as1 and serial number x021308125
It quits down after it runs awhile?
Your Belt and Rollers are getting old. Live with the short term Squeek or replace the Belt and Rollers and idler
Dec 15, 2013 | Frigidaire GLER341A Electric Dryer
Dryer keeps cutting off and has to be restarted.
There is normally a switch inside the motor that detects in turning at speed. That keeps the dryer running until it is either stopped, the door is opened, or the cycle is through. I am guessing that the contacts are getting bad on this switch.
Jan 03, 2012 | Dryers
Speed Queen Heavy duty Dryer appears to shut down because of over heating. We have had this dryer for quite awhile and the kids are all gone now so we actually don't use it as much. It doesn't...
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Aug 14, 2011 | Speed Queen AES28AWF Electric Dryer
Dryer displays 8.8 when you push start
8.8 is for a faulty control board .The control board is located behind the display in the upper unit. Access to the board is from the back side and is quite easy. They are approximately $150-175, it may work intermittently for awhile but will eventually quit completely.Please let me know if this helps you
Jan 19, 2011 | Maytag Neptune MDG5500AW Gas Dryer
My 7-year old Maytag MDE6000AYW drier will not start when I push the start button. It has been making a buzzing sound before starting for quite awhile. Today it died with a click followed by an...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Sounds like the motor has gone bad...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 16, 2010 | Maytag MDE6000 Dryer
My dryer quit working in the middle of a cycle. Dont know what happen. Its a Maytag PYE 3360AYW dryer, we've had it for awhile.
Disconnect power38732b7.jpg882727e.jpge4ad6bc.jpg58c0a23.jpgThat thermal will blow and kill power to the door switch circuit. The dryer will no longer function till you replace the thermal fuse. 0bdf7e1.jpgFailure to temove lint will cause continued thermal fuse replacement.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 27, 2010 | Maytag Dryers
Dry will not blow heat
Check the entire exhaust vent tubing before buying anything for this dryer to repair.. Most dryers only need a good cleaning to get the heat back running correctly. A moister sensor is working if the lint build up is more than just dust in the vents tubes. Any build up the sensor detects and keeps the heat off. Sometrime you will get heat for awhile although it will shut the burner down quit soon
Jun 09, 2010 | Amana NDG2335AW Gas Dryer
Dryer wont work
I'm assuming that the dryer is gas, since both the washer and dryer are on the "same" breaker. I'd try replacing the wall plug before replacing the dryer. If you have a voltage tester, you should see if you are getting an honest 110 volts coming off the circuit. Since the circuit was a problem before, I would test it first and then more on.
Jun 08, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Breaker tripping
The problem may not be with your dryer but with the circuit breaker...
Locate the circuit breaker for the dryer. Run the dryer for awhile and with the back of your finger pressed against each of the two switches (it will be a double breaker), see if the breaker is getting warm or wait until the dryer quits then check the breaker for any noticeable increase in temperature. With properly rated breakers, they should not get warm. If getting warm, it is a sign the breaker is bad and should be replaced.
Jun 14, 2008 | Roper REX4634KQ Electric Dryer
Amana NDE2330AY Electric Dryer Logo
236 people viewed this question
Top Amana Dryers Experts
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
