Question about WIRELESS EXTENDERS PCS DIRECTIONAL INDOOR ANTENNA 7 DBI MPN:YX024-PCS SKU:2042320
I need setup instructions for a Dr. Bott ExtendAir
I have a Dr. Bott Extend Air in my house with an Apple airport Extreme. i want to allow users in the guest house to use the interrnet. What do I need in the guest house for the C to be able to access the signal from the Dr. Bott?
Default network security key for apple airport
The Network Security Key is possibly the same pw as the network you are attaching to. This device can be configured in so many different ways.
If you can't figure it out then use the reset button on the back or use paper clip in reset hole.
To set up and configure your AirPort Extreme to use AirPort for wireless networking and Internet access, use the setup assistant in AirPort Utility.
The manual may be of some help... Available here
http://support.apple.com/manuals/#airport
Good Luck
Trevor
Sep 15, 2014 | Apple AirPort Extreme Router
How do I Connect iPad to printer ?
depends on the printer model....
if you have a recent type of printer with Airprint capability it is very easy to setup wireless.
however if you have an old printer with only a USB-cable you'll need another device to get it working:
Apple sells WiFi-devices like Airport-Express, Time-Capsule and Airport-extreme
Print command central.
The included USB port is great for sharing a printer throughout your wireless network. Time Capsule and the Bonjour networking technology let everyone in the house or office - Mac and PC users alike - take advantage of one centrally located printer.
connect-ipad-printer-jq4dbyibaqf10wv4m2e43laj-4-2.jpg connect-ipad-printer-jq4dbyibaqf10wv4m2e43laj-4-5.jpg
Sep 08, 2014 | Apple iPad Tablets & eReaders
How can I use It wider range? ( not to extend another apple router but antenna or setup )
The airport routers have built in antennas and external antennas cannot be attached. For wider range, place the router high up and away from glass, metal, and stone. Try changing wireless channels to lessen interference.
Aug 04, 2013 | Apple AirPort Extreme Router
I have a RCA Digital Broadband DHG535-2 modem but my Apple Airport Extreme router does not work, any ideas on how to resolve this issue?
Apple uses airport for its wireless connection, how ever the device where you want to connect to should have the wireless feature embeded to it or you should have a wireless router to distribute the wireless signal, if you are using just a modem which doesn't have capability of distributing wireless signals, the Apple airport will surely not work for it requires a modem to connect to. you need to get a router and connect it in your modem so the Apple will work for wireless as well.
Dec 29, 2011 | Computers & Internet
We just bought an Apple Airport Extreme router. After installing the Airport Utility software, and hooking up the router, we can not configure the base station using the Airport Utility. No matter what...
First time you should connect an Ethernet cable to the AirPort, and set it up with the software it came with. Then take a note of the wireless network's name (SSID) and the password (you might want to chance them to your personal preference though), security youre using (WEP, WPA, or WPA2)
Feb 20, 2011 | Apple AirPort Extreme Base Station
I cannot connect my hp pavillion dv4330ca to the internet using the Airport Extreme
Howdy. You need the Bonjour application downloadable from Apple to allow the airport to talk to the PC. This deals with almost all connectivity issues between those star-crossed lovers:)
Farmerbear at FixYa.com
Sep 15, 2010 | Apple Computers & Internet
Airport Extreme, Mac Cube and proposed Blue Ray /WIFI
Yes, you just need to connect the Airport to the modem. That way, the Airport will fetch the internet connection and distribute it to all your WiFi enabled device. You don't need any other hardware. You just need to configure the airport using your Mac computer.
Here's a quick setup guide from Apple.com:
Setup Airport Extreme
Jul 23, 2010 | Apple Computers & Internet
We want to supply wireless to our park in Florida, from one router. What router do we buy? Someone tried and they couldn't get any signal, whats best ?
get the Linksys wireless router with hot spot feature.
here is video of what you need.
http://www.youtube.com/watch?v=PwnhggrwfYg
moer info here
http://www.howtoforge.com/wireless_hotspot_howto
Sep 21, 2009 | Linksys Wireless-G WRT54G Router
WIRELESS EXTENDERS PCS DIRECTIONAL INDOOR ANTENNA 7 DBI MPN:YX024-PCS SKU:2042320 Logo
110 people viewed this question
Top WIRELESS EXTENDERS Computers & Internet Experts
David Payne
David Payne
Are you a WIRELESS EXTENDERS Computer and Internet Expert? Answer questions, earn points and help others
