Question about Brother MFC-J435W Network-Ready Wireless Color All-In-One Printer
Brother MFC-J435W offline
Printer keeps going offline and nothing can be done except uninstal and reinstall
SOURCE: Brother mfc is offline -
For my MFC, my PC says its ready and working properly. It really only works when I'm not connected to my cable modem. All PCs use it then. It's offline otherwise.
Posted on Oct 30, 2008
SOURCE: Brother mfc-490cw is offline
If you are running Vista and SNMP is turned off
1. Check to see if SNMP is turned off this is a component of Vista
a- Control Panel
b- Program and Features
c- Left side of screen you should see turn windows features on or off
d- Click on this a window box should open scroll down and see if SNMP feature is checked if it is then turn it off (unchecked) follow these steps
e- Under printers select Brother MFC-940CW printer right click
f- Select run as administrator
g- Select properties
h- Select ports
i- Select button configure ports
j- Under port settings uncheck enable SNMP
k- Click ok printer should be on line
l- To find MAC address for MAC filtering on router
m- Run the brother remote setup program and note the IP address
n- Run the command prompt as an administrator at the prompt type the following “apr –a” without the quotes and then hit return and note the physical address (MAC) for the above IP address you noted. Log on to your router and enter the MAC address from the step above and save.
o- Run the brother remote setup program again and change TCP/IP from “auto to static” please note you must have box checked at the top of the window edit network settings.
p- Restart the computer
Posted on Apr 16, 2009
  • 7 Answers
SOURCE: "brother mfc 7840w printer goes offline and i cannot print need turn printer on and off.
The solution, and it took me a long time to find the simple solution, is to right click on your printer, click properties, click the ports tab and click on your Brother printer and click on configure port (or you can delete the existing one and then add another one). What you want to do is update the IP Address. The problem is that the printer does not have a static IP address, it is dynamic. If you want to confirm that, go to your printer and press the reports button and print out the network configuration report. Your IP address will show on that. It's really the last digit in the IP address that changes. This will absolutely solve your problem. Good Luck!
Posted on May 17, 2009
SOURCE: Brother MFC-7820N Toner Problem
Open the cover, press Options and then *00.
Posted on May 22, 2009
SOURCE: Brother MFC-3360C cyan ink cartridge replace ment
On the front of the cartridge there is a sight tube for the ink, the fax shines a light through this tube to detect the ink.
I wraped a piece of paper around the tube to block the light beam on all the cartridges.
I dont need a processer to tell me if the machine is out of ink, I can work thay out when it stops printing!!
Now tell me you are out of ink you peice of electronic ****.
Posted on Oct 21, 2009
Why i am not able to instal my brother mfc-j435w at my mac
Go to the brother website and download latest control center for your model
Jul 15, 2014 | Brother MFC-J435W Network-Ready Wireless...
Laptop does not find Brother MFC-J435W Printer via Linksys E1000 router
Usually you need the printer driver to be installed on each device( PC- yes, but not sure how you would do the Iphone). Also verify that you have done the IP settings within your printer and that your computer can seethe printer
Dec 08, 2012 | Brother Network-Ready Wireless Color...
Problem with Brother MFC-9840CWD
Hi,Check to see in the connectioncables are all plugged in correctly.Open the printer and see if drumunit and toner cartridges are installed correctly. Sometimes not well installedconsumables are the cause of that particular problem.See if the print driver on yourcomputer is correctly installed. Try and reinstall the driver.Check if your printer is working in onlinemode. Sometimes printer changes online to offline method. If printer is atoffline mode click Start button on your computer, enter Control Panel. Click onHardware and Sound and choose Printers. Right click on Brother MFC-9840CWD andmake sure that the Use Printer offline is not checked.Hope this helps.
May 09, 2012 | Brother MFC-9840CDW Laser Printer
Using Windows 7, Trying to install printer, Brother MFC-240C. When computer starts or restarts Small window reads: Failed to start the ControlCenter. The required registry information is missing. Please...
After doing a bit of reading, it seems the Brother MFC-240C model is discontinued. I didn't see any support for windows 7, so what we can try is changing the compatibility.
1) Uninstal the suite/drivers, then restart your computer.
2) Reinstall the suite/drivers and restart your computer once again.
3)Look for BrCtrCen.exe in the directory of where ever the suite is installed.
Should be either
C:\Program Files (x86)\Brother\ControlCenter3\BrCtrCen.exe (for 65 bit windows)
C:\Program Files\Brother\ControlCenter3\BrCtrCen.exe (For 32 bit windows)
4) Right click BrCtrCen.exe, go to compatibility options and set the compatibility to vista.
Information source:
http://www.sevenforums.com/drivers/6086-brother-mfc-240c.html
Mar 28, 2011 | Office Equipment & Supplies
I cant print any documents my brother MFC-255CW says offline and i cant get it to work
I had the same problem, and couldn't find a solution anywhere. My laptop said the wifi Brother MFC-255CW printer was offline, when the printer was definitely online and connected.
In the end I simply went into Control Panel / Printers, selected the Brother printer, and deleted it off the network. Then I chose "Add a Printer" from the network, and reselected the only printer on my home network - which was the Brother MFC-255CW that I had just deleted. The computer reinstalled the driver, and everything was fine again - haven't had a problem since.
Nov 08, 2010 | Brother MFC 240C All-In-One InkJet Printer
My printer is "offline"
Try disabling the firewall, printing, re-enabling the firewall. My printer keeps working after re-enabling the firewall (at least for a while). Not ideal, but beats reinstalling the printer.
Mar 01, 2008 | Brother MultiFunction Center MFC-440CN...
Brother MFC-J435W Network-Ready Wireless Color All-In-One Printer Logo
932 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
