Question about Toshiba Satellite Computers & Internet
No wireless connection suddenly. internet only works by cable in laptop and home hub
  • gary Jan 18, 2013
    thankyou your answer was a great help and i am now back to my wireless connection.MANY THANKS FOR YOUR HELP. kind regards gary
  • Brian Sullivan
    Brian Sullivan Jan 18, 2013
    well done and thanks for replying with the good news
  • Toshiba Master
  • 27,725 Answers
Turn on your computer and locate the Wi-Fi icon. This could be located on the upper row on a laptop it will have the radiation look ((())) Make sure its pressed on. There should be an option to "automatically connect" when it detects the network. Look for a checkbox. create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favorites Tools and Help
click on the tools at the bottom of the drop down list will be internet options in the connections tab tick in the box never dial a connection below that will be change search defaults click on settings you will see all search providers you have if dont need any of them you can disable or remove them Power on the laptop computer and wait for the operating system to boot before proceeding. Right-click the wireless icon in the lower right corner of the desktop. From the pop-up menu select "Enable." This activates the wireless Internet options but it does not turn on the wireless receiver. Push down on the wireless button or wireless switch on the top of the keyboard. After a moments time the switch or button lights up, signifying the computer is ready for an Internet connection. Right-click the wireless icon again. From the pull-up menu choose to view all available wireless networks in the area. A window appears with all the networks your computer receives some sort of signal from. Select the wireless network you want access to, type in the password (if required) and click "Connect." Momentarily the laptop computer connects to the Internet.
you should be able to, it depends on the laptop, the os, the wireless adapter, and the settings .
Click start Control Panel - Network Connections - right click on 'Wireless connection' (or similar) and click 'enable'. right click on the network in the bottom toolbar select open network sharing center you should have the options to either connect or disconnect or set up a network connection this will vary depending on your operating system Hope this helps. b>
Posted on Jan 16, 2013
  • 114 Answers
SOURCE: Wireless laptop disconnects from internet when power cable connec
Does it reconnected again then? Or it never reconnects on the AC? I would try different channels on the wireless router first. Hopefully that will solve the problem do to some interference. If not, report back and I have other things you can try.
Posted on Jan 15, 2009
Just4help
  • 145 Answers
SOURCE: I can't get my usual wireless internet connection anymore on my l
Make sure you don't have your wireless turned off on your laptop. Sometimes there is a button on the laptop.
or. Go to Control panel on laptop -- then system --then device manager and check to see if there are any "explanation points" on any of your devices listed. If so, right click on the one with the "exp point" and hit update driver. Then follow the process on the screen. Sometimes you may have to select roll back driver to get it working again.
or
The wireless adapter was disabled in the same device manager. if so, right click on the adapter line and check to make sure it is enabled.
Hopefully my explanation isn't too confusing. I appologize, I'm relative new at typing directions.
Hope this helps.
Posted on May 26, 2009
kisssmooth
  • 92 Answers
SOURCE: MSI VR 220 can't find wireless network.
you can try and connect it with the cable first and access the GUI (Graphical User Interface) to configure the settings of your wireless gateway/ router. it is possible that the settings are not configured in a way your laptop would be compatible with it...
hope this helps...
Posted on Nov 28, 2009
Jack_Dawson
  • 287 Answers
SOURCE: turn on wireless switch and laptop turns off and
1. It's a bad memory problem! (Blue Screen)
2. Try to close unneccessary processes / software using Task Manager before switching ON wireless!
3. Now, switch ON wireless.
4. If it don't work, reinstall the wireless driver!
5. Restart ur system.
tell me if it helps...tc! :)
Posted on Jan 04, 2010
Jack_Dawson
  • 287 Answers
SOURCE: Toshiba does not connect to wi-fi unless other laptop is on wi-fi
1. Reinstall the wireless driver.
2. Restart your system.
I cannot get these plug in units to pair or connect to the laptop. is it me or are they ****?
If you can install a wireless repeater it may provide a better signal.
OR
A wireless 3G network uses the mobile/cell phone network and can be separate or combine with your cell phone account. This type of Internet connection uses an USB wireless device shaped like an USB memory stick.
Sep 30, 2012 | Computers & Internet
Can I connect my HP PSC1510 to my BT Homehub v1?
yes, you can. I have my printer connect to my hub and my desktop and I can print from my laptop wirelessly.
You will need your all in one connected via a printer or USB cable to a computer AND also connected to your hub. Then, go to the computer that is connected through a cable to the all in one. Your all in one should have some way to configure its IP address. I have my printer configured as 192.168.1.4 and it's plugged into the 4th port of my hub. Check if this works.
Mar 14, 2010 | Acer Aspire One Netbook 8.9" Notebook
I have just bought 2 Acer aspire one netbooks. Before Xmas I checked that these would connect wirelesly to internet and they both did - have now tried again after Xmas and they wont connect wirelessly...
Hello, Vicki.
A drained battery would have no bearing on wireless access.
Since both laptops do not access wirelessly, sounds like as issue with your hub. Try the laptops at a wi-fi cafe to see if they work OK.
Hope this helps.
Dec 28, 2009 | Acer Aspire One PC Notebook
My hp pavilion dv 9000 can not connect to bt home hub 2.0
hi, please make sure that you enable WPA encryption on the wireless router. Vista will give you trouble if you use WEP encryption. Also, please update the firmware on the wireless router, if possible.
Let me know how it goes.
Oct 26, 2009 | Computers & Internet
How do I add an additional laptop to browse the internet?
If you mean to your home network you could use either a router or a hub. With a hub you can connect a cable to access the internet. With a wireless router you can use a wireless card in the laptop as well and use the laptop anywhere in the house.
Sep 12, 2009 | Dell Inspiron 1501 Notebook
Lost connection between switch and hub - LED flashes every 5 secs
You say you have the same problem when you connect the cable directly from router to laptop, so it apparently is not a hub problem. That leaves the router and the cable. You're fortunate in having a working system on the other port. Why not try swapping pieces to see which is the failed piece? For example, what if you swap the ports for the cables? If it's a router problem, then the "bad" cable should work when in the other port. What if you swap cables? That would reveal a bad cable. Finally, swapping computers would show a computer configuration problem, such as the connection not being set to automatic.
Jan 23, 2009 | Dynex 5 Port 10/100 Ethernet Switch...
Wireless connection problem
BT is right, the fault is at your end, because you can connect to the Internet with an ethernet cable.
You have lost your wireless connection with the wireless hub.
This could be low signal strength (especially if the wireless access point is in one part of the house and your laptop is in another room)
OR Your laptop wireless card has lost its wireless access configuration.
Check your laptop wireless configuration, check your signal strength, check your SSID, check your security (WEP or WAP),
Have you got MAC address filtering.
Go to control panel, click on network connections, right click on Wireless Network, Click on repair (might fix your connection problem), Else right click on Status (should give you indication of how your wireless is functioning or not functioning).
Check your TCP/IP settings is set for "Obtain an IP address automatically"
Without more information it is difficult to identify exactly what is wrong with your connection.
May 11, 2008 | Acer Aspire 5100 Notebook
D-link router DKT-710 Wireless G ADSL2+ starter kit
Took it back to shop and changed it for another one. thanks, norman3.
Mar 02, 2008 | Computers & Internet
Computers & Internet Logo
136 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
