Question about Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook
My macbook dropped ..now battery cord doesn't light up very much and flickers... alot..? Is this an easy fix? Or is this gonna cost some bucks..? What could dropping the macbook have done to it
Screen flickers with little white lines running across screen when I first start using it. What could be wrong? Seems to stil work fine and charges up...worried
    Champion:
  • 220 Answers
Macbooks are very expensive to fix if you take them to the so called genie bar. so try a mall store to fix it or if money i no problem take it to the apple store.
Posted on Mar 31, 2014
  • 163 Answers
SOURCE: macbook wont turn on
Dont buy a new one as we may be able to repair. These boards are Not Complex by Industry standards and weve had excellent luck tracking and repairing them. (So Glad Apple went Intel).. Talk soon...
Posted on Mar 10, 2008
  • 34 Answers
SOURCE: macbook pro start up problem
First remove the battery, then plug it into your AC adapter. Hold the power button for 5 seconds or until you either hear and beep or the activity light on the front of your laptop lights up. Start up normally.
Posted on Sep 16, 2008
inferno45
  • 45 Answers
SOURCE: Bios setup for MacBook?
Command Button(the one with the apple logo) + Option + F + 0 when it boots
Posted on Nov 21, 2008
actionman14
  • 32 Answers
SOURCE: MacBook will not start up
i have this when my macbook pro starts up i c this icon but i recently changed the hard drive maybe u have a problem where the hard drive is not being found i suggest u replace the hard drive but it is very fiddly, u have tried the reset and i know thats how to do it , if u have knocked it it might have come out , google hard drive replacement there are site that tell u step by step, it might just need pushing in.
actionman
Posted on Feb 27, 2009
SOURCE: on startup, white screen with question mark folder
my mac pro laptop has white screen flashing folder with question mark it fell & when i took it to the store they told me it was the hard drive so i bought a new one and it still does the same thing so how do i fix my laptop . please help
Posted on Apr 10, 2010
My zoom g1xn suddenly stopped working. When i connect the power source, it doesn't turn on. . . When i tried batteries, i turned on but the display was flickering then it turned off. . . What is wrong?
Try another cord/charger. Check the AC jack in the machine. Is the battery charging with the cord/charger plug in? Has the laptop AC jack been pulled by the cord? Damaged?
Dec 11, 2012 | Computers & Internet
How can I tell if a power surge hit my laptop and ruined it? I can't even get it to boot up
It could either be that the motherboard is fried or the Hard drive has just gotten slightly corrupted. If you have the Windows install disk that came with it you could boot that up and then go into repair mode (press R) and then run "chkdsk /r" this would fix a hard drive issue. However if your laptop will not turn on at all when you press the power button then it is likely dead.
Nov 07, 2012 | Computers & Internet
Verbatim usb500 Question? My macbook can't read it anymore?
If the drive did not actually fall, there is a good chance you just damaged the USB port. The jolt could have detached it from the circuit board. The case holds a normal hard drive and can be removed and placed within another case or a dock.
External Hard Disk Drives
HDD Docking Station eBay
External hard drives come in 2 sizes, 2.5" and 3.5". If you get the case be sure you get the right size. The dock accepts both sizes.
Mar 10, 2017 | Verbatim 500GB USB Desktop 500 GB Hard...
How do I fix the constant flickering of the screen?
Take the lcd assembly apart, and disconnect and reconnect the ribbon cable on the back of the lcd. Also disconnect and reconnect the other end of that cable. If that doesn't fix it, disconnect and reconnect both cables that go to the inverter board (it's the small circuit board inside the lcd assembly- example in picture below). If still no good, then you probably need a new inverter board. Call HP and get a phone number for one of their parts suppliers. Inverter boards are cheap ($10-$20). Even if it doesn't fix it, it doesn't cost much to try. If still no good, then take it to a service shop.
Hope this helps!
Joe
Mar 22, 2012 | HEWLETT-PACKARD HP Pavilion G61b70us...
Why do the lights flicker when trying to turn over the engine?
The battery is low on charge. Either the battery is failing or your alternator is not putting out enough charge or the starter motor is drawing too much electricity. If you have a volt ohm meter you can check the all of these conditions. Simply by connecting the VOM to the battery. Your battery should have a static charge of about 12.5 volts. When you try to start the engine the voltage on the meter should not drop below 10 volts..If you have the engine running the voltage should come up to about 14.4 volts within 2 minutes. If it doesn't come above 14 volts there is a problem with your alternator.
Dec 04, 2011 | 2006 Acura MDX
Some how my Samsung SL820 digital camera's shutter door got stuck and it is not closing how many ever times I try to switch the camera off and on. Because of this the camera doesn't work. I've...
Did you happen to drop it accidentally? Or accidentally applied force into your camera? If yes, then there is big chance you will gonna have to replace the whole lens! If not, then it might just be dirt stuck inside your lens mechanism. To fix it, hold your camera with the lens facing the ground. Then, tap your camera repeatedly. Start with light tapping to moderate. If that doesn't work, spray condensed air directly into the lens part of your camera.
Sep 21, 2011 | Samsung SL820 Digital Camera
2002 mercury montaineer , battery light comes on , they gages shut down couple minutes after then the truck acts like it gonna shut off....when getting a jump, the truck fires right up, couple minutes...
Your battery is definitely low. First clean the terminals on the battery and the inside of the terminal rings on the wires. If you have a slow charger put it on that overnight and see if it holds a charge. If it still keeps depleting or doesn't charge overnight then either your battery or your alternator are done....possibly both. So take the battery to have it load tested. Most places that sell them can test them. If the battery is done replace it then test the battery with a volt meter. If the old battery is still good put it back in the vehicle and test the voltage with a volt meter. With the engine off the voltage should read 12 volts (once its fully charged or if its new) with the engine running it should read around 14 volts. If it is way higher than that or it doesn't go up at all your alternator requires replacing. Alternators are fairly easy to replace but if you don't feel comfortable with that take it in to a mechanic.
Jul 25, 2011 | 2002 Mercury Mountaineer
The picture on my 2 yr old Toshiba 42hm66 DLP tv starts flickering and with alot of rainbow looking distortion after an hour of veiwing. I replaced the lamp, but it sill has the probelm. Any idea what...
I hope this helps you but you might wanna look into some other posts too cause it goes farther then the lamps and color wheels. Basically it's a bad product and the consumer should be fixing it. But your problem seems to be the color wheel. Or just a good cleaning. We replaced the lamb in ours and still had a color problem. We're gonna do an exstensive cleaning and dusting of our unit and if it don't work. We're going straight to the manufactor. This is enough with this product! It's costly to repair and still don't have the quality picture it should. It's more then a simple fix and too costly for ppl to just fix and move on. For how old these products are this all should not be happening.
Dec 02, 2008 | Toshiba 62HMX84 62" Rear Projection HDTV
Right side of screen flickering (top to bottom)
Your laptop screen has a thin ribbon connecting the screen to the mainboard. after upening and closing your screem these pins sometimes breaks causeings streaks in your screen. My compaq note book has to be resoldered because of a lose connection on back for power. your gonna want to get that fixed before you fry your board. costs about 50 bucks for an hours work to get that solderd. It could be linked to your flikering issue..
Feb 15, 2008 | Toshiba Satellite A105-S4004 Notebook
Can I fix this???
if that is the case, then there is indeed a short on the ac port (thats where you plug in the charger.) that's the reason why the charger light goes off as soon as you plug it in to the back of the computer. I know its gonna cost you a lot since the only way if fixing this is to replace the motherboard. if its gonna cost you $500 + then better buy a new one. they're gonna replace it with a refurbished motherboard anyways.
Hope this helps.
thanks.
Nov 12, 2007 | Dell Latitude D600 Notebook
Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook Logo
90 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
