Question about 2wire Wireless-G 802.11g ADSL Gateway
Fifth computer unable to connect to internet
I use att dsl service with 2701hg-b 2 wire router for my four other computers, laptops and desktops.
Recently I bought notebook with which I cant go online wireless.
Please help me to set up internet connection
  • dozer7552 Jan 24, 2009
    We have done all that you have stated prior to me asking, still no connection
    Thanks
    4 of the 5 use XP the lone one is using vista that the modem is connected to. they all worked on the linksys modem and router than Bellsouth would not support it so they installed their own to the new one.
  • 4 Answers
-- ckeck if you see 'wireless connection' in the network connections, in order to find it, click start --> control panel --> network connections and you must see wireless connection in case of win xp..
start --> control panel --> network and internet --> network and sharing center --> manage network connections and you must wireless network connection under LAN or hi speed connection... in case of win vista
--if you have that ikon that means you have your drivers installed on the computer properly
--right click wireless network connection and click "view available connections" in case of  xp and "connect/disconnect" in case of vista you must find the network and get connected..
letme know if you have problems connecting..
Posted on Jan 24, 2009
  • vishal reddy
    vishal reddy Jan 24, 2009
    hi,
    can you let me know weather you are using xp or vista or ..
  • vishal reddy
    check this,
    click start--> run and type"services.msc" than enter.
    find wireless zero configuration and check if the status is 'started', if not click 'start' and if yes, click 'restart'.
    try to get connected..
    FYI : inorder to do this you have to be logged in as administrator.
    more or less this would finish the troubleshooting with the computer.
Internet connectivity problems HP pavilion a6230n desktop pc
1.Unplug all phone, fax and satellite TV cables from the wall phone jacks.
2.Plug the double DSL filter into the wall phone jack where the 2701HG-B will be located.
3.Plug the phone wire (for phone, fax, etc.) into the jack on the filter labeled "Phone."
4.Plug the gray phone cable into the other jack on the filter labeled "DSL."
5.Add the single DSL filters on all remaining phone jacks in the same manner, plugging the device phone cables into the filter. The single filters only have one jack.
Ethernet Connection
6.Plug the power adapter into the power port on the back of the 2710HG-B router and then plug the other end into a power outlet. This will cause the power light on the front of the router to turn green.
7.Plug the free end of the gray phone cable into the port on the back of the router labeled "Phone Line."
8.Plug one end of the yellow Ethernet cable into one of the four ports on the back of the router labeled "Ethernet."
9.Plug the other end of the Ethernet cable into your computer's Ethernet port. The Ethernet light on the router should now be green.
Wireless Connection
10.Plug the power adapter into the back of the 2701HG-B and the wall power outlet.
11.Plug the gray phone cable into the jack on the back of the router labeled "Phone Line."
12.Open the Network and Sharing Center on your computer by right-clicking the Internet connection icon in your taskbar.
13.Click "Set up a new connection or network" and follow the instructions provided by the wizard to set up the wireless connection on your computer.
14.Enter the SSID and WEP key when prompted. The SSID is "2WIRE" followed by the last three digits of the router's serial number, which is located on the bottom side of your 2701HG-B router. You will also be prompted to enter a WEP encryption key, also found on the bottom side of the router. The WEP key is the 10 digit number that appears in brackets under the first bar code.
Sep 12, 2012 | HP PAVILION A6230N DESKTOP PC
I have an at&t 2wire 2701hg-b but i dont have at&t internet i have charter and i am not able to figure out how to get my internet to work with this router please help
att 2 wire is a Adsl Modem (Requires a telephone line jack to get the signals) but charter communication is a cable internet service (not DSL) , Requires a TV cable service for internet .
These two jacks differs and there working differs ..
Means : Att works with the username and password type of authentication but charter requires the MAC address of modem for authentication .
Therefore for a cable internet 2wire 2701hg-b modem cant be used . But yes in case charters has username and password authentication and works with the telephone jack in house then its possible to use the same modem.
Aug 19, 2011 | 2wire (2701HG-B) Wireless Router
Can I use AT&T 2701HG-B 2W Wireless Gateway DSL
yes, you can use them together. they'll find each other at protocol layer 2 (bridge) and layer 3 (router),
and route packets appropriately. Check their manuals to make sure that their HTTP management page ip addresses are different - say 192.168.0.0 for one router and 192.168.1.1 for the other - so that you
can manage them separately without disconnecting them.
You'll want to manage them separately to assign them different wireless-N channels. Channel 6 is
the default, and allowing both to compete on the same channel is a bad idea - give each its own
wi-fi channel. There are 11 wireles 802.11n channels, labeled 1-11.
Diagram: DSL === AT&T 2701HG-B ---------- NetGear router --------------- desktop computer
Each link in the diagram above is an ethernet (802.3 10baseT) cable (except the DSL cable,
which is twisted pairs), and wireless devices can
hop onto the Internet by wirelessly connecting to either the AT&T 2701 or the NetGear router.
Jul 08, 2011 | Gateway Computers & Internet
I want use my 2wire (2701HG-B) Wireless Router without the dsl line
Modem and routers are considered only as access point you computer may be able to connect to your router but if you dont have a DSL line you will not be able to go on line... if you dont want a DSL line there are service that concentrates on wireless alone... in this DSL line are not required nor router but may provide you a USB wireless adapter that has their wireless service then again try calling an Internet Service provider for this options...
thanks... Roger
Jun 11, 2011 | 2wire (2701HG-B) Wireless Router
What does a red internet light mean and how do I fix it? I recently moved and when I plugged in my router the dsl light is green and the internet light is red. When I look at my laptop it says I am...
You'll need to contact your ISP and have the DSL service moved to the new line. The laptop sees the mdem or router and thinks it's connected, but the red internet light tells you the connection is not complete to the phone company.
Jan 24, 2018 | 2wire (2701HG-B) Wireless Router
I went from a ATT dsl modem to a net gear modem and i cannot get the net ger mode and linksys mode to talk to the computer
Most DSL providers use PPPoE (Point-to-Point Protocol over Ethernet) to establish Internet connections for end-users. To set up a Linksys router, you need to enable PPPoE on the router’s web-based setup page.
To setup a Linksys router with a DSL connection you need to perform four steps:
  1. Verifying Internet Connection
  2. Connecting the Devices Together
  3. Checking the LEDs
  4. Setting-up a DSL ISP on a Linksys Router
Connect the Broadband modem to the computer using an Ethernet cable without the router installed and make sure that the Internet connection is active. If not, contact your Internet Service Provider.
Aug 01, 2009 | Linksys Wireless-G Broadband Router
Can I use AT&T 2WIRE 2701HG-B DSL to ant ISP?
look if u wish to go for verizon service,,they will provide u with a wireless modem as well,,but if u tell them that u hav a modem then they might configure this modem only,,both ATT and verizon are DSL service providers with PPPoE connections.the only thing u need is the username and passwrd from verizon which u have to setup on the first page of the 2wire setup page,,both the connections are dhcp based.so no other connection settings change required.But when u talk with verizon make sure u tell them of the 2wire modem
Moreover verizon has wireless broadband service which is actually a express card tat u have to put into your computer and u can go online anywhere u go within ur country{it works like a mobile phone}
best of luck,,keep me posted
May 14, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Problem getting to internet through 2wire 2701hg-b router
how can I connect a 2wire 2701HG-B router to a motorola SB5101modem?
Apr 22, 2009 | 2wire Computers & Internet
No internet connection on my laptops
Please understand as I get very basic to start but things very obvious to you I cannot see.
Generally when including a router in a home network starting from the cable (tv) or the phone socket (dsl) in the wall with a phone wire plugged in. The next box is generally provided by your internet service provider and is a modem/something that connects to the phone line or cable. Then sometimes when only one computer exists computers are directly connected to the modem with an ethernet cable (looks like a fat phone wire with oversize connectors) or a USB cable (small flat retangular ends).
When you want to add a router for multiple computers. The computer gets disconnected. If a USB cable was used it is often replaced with an ethernet cable and that cable connects to the WAN port (probably separate from a block of 4 lan ports) of the router you bought (tell me if you have two routers -- that is a different problem). If your service comes from a cable (tv) company your router may already be properly configured. If however you have DSL service from the phone company the chances your router is correctly configured are less. To finish with the cabling story -- your computer then hooks to one of probably 4 LAN ports all in a block. Now if you are lucky power on all devices and boot up your computer and see if you have internet access. If you do great if not please provide me the name of your internet service provider or a link to their help/support website and I will see what I can do to assist in completing the router setup. Until your wired computer gets access to the internet your girls wireless connections will not work either. Once we get the wired connection working we will address the wireless connections.
If necessary unplug the router and plug the computer back into the original cable until we get the router working.
Dec 26, 2007 | Linksys Wireless-G WRT54G Router
Please help
To setup your router
first check..
Connect the Broadband modem to the computer using an Ethernet cable without the router installed and make sure that the Internet connection is active. If it is not, contact your Internet Service Provider. If it can go online,
to setup connection..
Step 1:
Connect the Broadband modem to the router’s WAN or Internet port.
Step 2:
Connect the computer to any available numbered port (1, 2, 3 or 4).
NOTE: In this example, we’ll connect the computer to port number 3.
Step 3:
Make sure the power adapter is plugged to an available power outlet.
Step 4:
check if you are able to go online wired..
if not your router has to be configured first,
config your router by running the setup cd and that would fix your problem..
let me no know in case if you have any problems ...
Dec 02, 2007 | Linksys BEFW11S4 Wireless-B Broadband...
Open Questions:
See all 2wire Wireless-G 802.11g ADSL Gateway Questions
2wire Wireless-G 802.11g ADSL Gateway Logo
296 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
