Question about Hayward Pool & Spa
Thermostat will click on at the lowest point and not turn off as spa went up to 110.and the gauge was barely beyond cool
  • 372 Answers
Your thermostat is obviously malfunctioning, but in addition there should be a high limit that automatically kills the heater when the water hits 105. It is not working either. Have a tech come check it out, water that hot can be deadly.
Posted on Jan 19, 2013
  • kschneider2
    kschneider2 Jan 22, 2013
    Thanks Bill....thank goodness I put my hand in to check the thermometer before getting in.
My temp gauge on the dash started showing the car getting hot as I sit with the car running. When I started driving it goes down. I figured the thermostat was sticking so I replaced it and now the...
Check to see if the fans are operational, anything below 35 MPH the fans cool the radiator, anything above is cooled by air passing thru rad.
Jul 08, 2011 | 2003 BMW 325
What is coldest on the dial 1 or 8
dear sir /madam
please turn to your thermostat nobe clock vise till the end you will got the highest cooling point for lowest turn this nobe anti clock vise position till end it,s lowest point of cooling.
hope answer the question.
please vote!
thank you
Aug 30, 2010 | Kenmore Freezer 14.1 cu. ft. Upright...
Temp gauge goes up and down
first i would purchase a new radiator cap 15 lbs 16 lb capacity cost about $7..then you must let car cool completely...now check radiator coolant level.. top off if it needs it. Now install new cap..let car warm up normally and after it get to normal temp range or higher put hand on upper radiator hose..it should feel hot and when you squeeze it you should feel a slight back pressure..this will mean that the thermostat and water pump are working correctly. if not either the thermostat you purchased is defective or your pump may not be working properly.
when you use just water in an engine the boiling point becomes 212 when you add the correct amount of antifreeze, depending on where you live, the boiling point will go up to 240 degrees. Make sure you put in the correct amount of mix.50/50 will usually work well. sometimes when a gauge does max out like that it could just be trapped air. if after you checked all this out and no air is trapped in the system, i would think that you may have a bad temp sensor. let me know if this helped thanks.
Apr 28, 2010 | 1999 Ford Expedition
96 mystique temperature gauge is not moving. Earlier in the day the gauge seemed to be working fine went up to the middle. Now it has barely moved and never makes it to the normal range.
sounds like your thermostat is stuck open.if you let it idle for a while the temp comes up slowly,but when you drive it it cools down because the thermostat that normally closes,to let in less cold water from the radiator,is stuck open.
in the winter it is bad because the car will take 30 minutes to warm at 32f
May 13, 2009 | 1996 Mercury Mystique
Zanussi 920/g R
your thermostat is faulty you will have to replace it if you keep doing what you are doing your gas will run out ok go to your local appliace shop and give them the model number and they should get you one cheap
Jan 06, 2008 | Zanussi ZEBF250W Bottom Freezer...
Pool & Spa Logo
42 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
