Question about Panasonic NN-P295SF Microwave Oven
Door does not open - Panasonic NN-P295SF Microwave Oven
  • Panasonic Master
  • 9,098 Answers
You'll need to remove the outer cover to get to the door open button or door lever, either of which can cause this problem.
The service manual is here.
You can order Panasonic parts from Encompass here or you can call them toll-free at 866-779-5835.
Posted on Jan 17, 2013
How to fix the door button on panasonic microwave t6648fx?
Clean the inside edge of the door and oven where it contacts the door. Grease or oil is preventing the door to swing open.
Aug 28, 2014 | Panasonic Microwave Ovens
How do you replace the handle
follow this steps and fix it. see the pictures attached. God bless you2f4dab72-f574-4367-8631-e2d40f813792.gif
Open Lever
If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Enter your model number to see parts for your microwave.
Help me find my model number
Door Spring
If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch
If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook
If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring
If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button
If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator
If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Jun 18, 2013 | KitchenAid KHMS147 Microwave Oven
I have a amana road range microwave and the door won't close . AMV3204VAB-0
proceed according . God bless you
Open Lever
Door Spring
Door Latch
Door Hook
Button Spring
Button
Handle Actuator
Apr 02, 2013 | Microwave Ovens
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
Can't open microwave door
It sounds like the push to open lever is cracked or broken. You have to remove the 'wrapper' to open the door manually from the inside to check the 'door keys' or door hooks to make sure that they are in tact. Then, check the door opening lever between the 'push to open button' and the lower door key.
Sep 11, 2009 | Microwave Ovens
MIcrowave runs with the door open also
your door switch is mis-adjusted,furthermore the other safety switch on the door should have blown the power fuse in the unit,because by design for safety it produces a short circuit if door opens under operation,so if door was taken off and replaced it was not adjusted properly
Aug 15, 2009 | Sanyo EM-P790 Microwave Oven
Model 565.66400, still runs when door is opened?
if unit runs with door open then one of the door switch is stuck closed.there are 2 door switches and they could be assesed by removing the control panel.disconnect wires from top and bottom switches and chkf for continuity.they should be normaly open when the door is open and closed when door is closed.one of them will closed even when door is open.replace that bad one.
Aug 11, 2009 | Kenmore Microwave Ovens
Sharp Microwave R-1480 Door Release Button want open the door.
What usually breaks is the door open lever. Please unplug the oven first.
At our site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you'll be able to see how the door open button would press against the door open lever, which would then lift up against the door latch heads (hook-like projections on the door) and the door should open.
You can usually find exploded views and order parts by entering your model number at the Sears parts site, but the best place to order Sharp parts is Tritronics. You can also call them at 866-779-5835.
Nov 19, 2008 | Sharp R-1480 Microwave Oven
DOOR SHOWS OPEN BUT IT IS NOT
After self cleaning the range the door won't open....
The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
Hope this may help;
DON'T FORGET TO HELP
Sep 06, 2008 | KitchenAid KBMC140HSS Convection/Microwave...
Panasonic NN-P295SF Microwave Oven Logo
89 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
