Question about Genie Building Materials
Why does my garage door opener skip and not open
The garage door opener will close but will skip on the worm gear and not open
    New Friend:
  • 25 Answers
Bad trolley. replace.
Posted on Aug 06, 2013
2 Suggested Answers
  • 217 Answers
SOURCE: craftsman 3/4 hp garage door opener
not sure, but see the users manual here:
http://www.manualslib.com/manual/32293/Craftsman-139-5399.html
Posted on Mar 10, 2013
Genie worm drive garage door opener makes loud noise when in uses
My opener is making a loud noise when opening or closing! I have no clue what to check
Feb 27, 2013 | Genie Company Genie 27092A Replacement...
Liftmaster 1/2 HP Garage Door opener won't open or close. Has been working fine until I pulled out this morning. The door will move freely if I disengage from opener. Went up ladder to see chain not...
The shaft on these garage door motors are not direct drive systems. You'll have to open up the box to see what the actual problem is. I have had stuff like this happen where a gear just slipped out of place.
http://www.aaadooropeners.com/?gclid=CLH3wt628p8CFVZS2goduwSLYQ
Here is a link for a parts supplier. I don't know your model but it looks like most of the Liftmaster worm screw gears and drive gears are plastic so it's possible that one of them has cracked.
Feb 14, 2010 | liftmaster Chamberlain Garage Door Opener...
Recently changed gear and now door will not close
The opener clicking 10 times when the door reverses is a door sensor problem. You may have knocked a wire loose on the back of the motor unit or accidently bumped one of your door sensors. Make sure the small light on each sensor is lit and not flickering. Tweak them a bit to get them properly pointed at one another.
Dec 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door only opens 4 inches then reverses and stops
you need to replace gear when the door is fully closed. then do your tweaking.
Jun 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener
See your post under Garages in the Garden Web.
May 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Garage Door Opener - Gears need to be fixed
Unplug the unit and remove the cover, usually eight screws, if you see a lot of white dust in the cover check the nylon drive/worm gear, they will need to be replaced.
Apr 10, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener does not reverse after hitting obstruction
release the door from the opener and see if door moves freely the check proper torsion by moving door up to 3-4 ft if it stays in this area torsion is properly set if not call technician to adjust torsion
if door does not move freely all the way up and down check for binding track alighnment and roller condition. the adjust closing pressure.
Jan 07, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door will not work
Check to see if you plugged in the 4 wire limit assy. harness.
Dec 16, 2008 | liftmaster Chamberlain Garage Door Opener...
Garage opener cannot close, just replaced gears.
If the unit has photo eyes that could be your problem. not reattching the 4 wireing harness from the limit assy. can cause a similar issue.
Dec 13, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
Building Materials Logo
76 people viewed this question
Top Genie Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Genie Building Material Expert? Answer questions, earn points and help others
