Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Garage door opener will not close in cold weather
My Craftsman garage door opener will open in cold weather, but when I push the button to bring it down, it moves about 6 inches and then reverses and flashes like there is an obstruction. Only happens when temperature gets in the 20's or lower. When warmer, no problem. Have checked track and cannot find anything. Thanks.
  • ghomeghome Jan 24, 2009
    Mine does the same thing. In the cold it moves an inch or two and then goes back up and the light flashes as if there were a blockage. It only happens in cold weather. This is my second winter with this door and it did it all last year also.
  • wsburnette Jan 27, 2009
    Have already tried all adjustments. Unit has been operating for 10+ years without a problem until this year. Beginning to think it is a sensor malfunction. Door will close if you hold the wall unit button down.
  • 112 Answers
The are two knobs on the back of the opener. They are force settings. One is the upforce and the other is downforce. Turn both knobs to "5" and try. This should take care of the problem. They come from the factory at 1 or 2 and when it gets cold it takes a little more force to cloce the door.
Posted on Jan 26, 2009
  • Vince Heuser Jan 27, 2009
    If door will close holing down wall button. It is definatly the safety eyes. Holding the wall button down overrides the safety eyes. Check the lights on safety eyes. If one light is on there is an alignment issue. If no lights are on there is a power issue. Check all wires and connections. If one light is on and the other will not come on with alignment, the safety eyes need to be replaced.
With my door closed, i push door button to open and the chain and opener continues inthe closing mode. any help?
Shop for sears craftsman liftmaste... on Google
Garage Door Opener Gear...
$31.45
Sears Parts D... Liftmaster 41C4220A Ge...
$21.75
Preferred Do... Chamberlain/l... Sprocket, Gea...
$17.95
eBay Direct Replacement f...
$20.95
Moving Up G... Liftmaster 41c4220a gea...
$31.67
North Shore... Search Results
    Liftmaster Gear And Sprocket Kit 41c4220a Chamberlain ...
    www.sears.com/search=liftmaster%20gear%20and%20sprocket%20...
    Searsmore info. + -. Chamberlain LiftMaster 41C4220A Gear & Sprocket Assembly Kit. $31.40 ... Chamberlain Sears Craftsman Liftmaster 41A2817 Gear Kit. $27.65 ...
Jan 10, 2016 | Sears Craftsman LiftMaster Chamberlain...
What does the purple button light flashing on 1/2 horsepower craftsman garage door opener
I think the adjustment mode is on.
For example, that's from Craftsman manual:
Setting the Force
The force setting button is located on the left panel of the motor unit. The force setting measures the amount of force required to open and close the door.
1. Locate the purple button on the left panel of the motor unit (Figure 1).
2. Push the purple button twice to enter the opener into Force Adjustment Mode (Figure 2). The LED (Indicator Light) will flash quickly.
3. Push the remote control or control console (Figure 3). The door will travel to the DOWN (close) position.
Actually, you should just read carefully your garage door opener unit's manual.
Craftsman Garage Door Opener Remote
Jun 21, 2014 | Sears Craftsman LiftMaster Chamberlain...
My Craftsman garage door will not close, only a few inches at a time
have a problem which returns every year when outdoor temperatures drop close to freezing. garage door will open only a few inches, then stops. I can close it and try opening it again... same result. After five or six such attempts it typically will open. Interestingly, when I push the switch button mounted on the interior wall of my garage and keep it pushed, the door will open, until I release the button at which point it stops opening.
Dec 19, 2013 | Building Materials
Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+: My craftsman 1/2 hp garage dood does not close whe...
If the main light flashes 10 times when you try to close the door it is a sensor problem. Make sure they are not flickering ever so slightly and that they are not loose on their brackets. Tweak them a little bit.
May 18, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have a 1/2 hp Craftsman GDO. It intermittently works. When it does not work, to get the door to open or close, I need to push the remote button several times to open or close it all the way. At times it...
On the rear of the motor unit you will find the up and down force adjustments. Increase these just about 1/4 turn and try. Make sure the tracks have not been lubricated at some time with grease. With the cold weather the grease becomes thick. The tracks should never be greased.
Jan 07, 2010 | Sears Craftsman LiftMaster Chamberlain...
During the Winter: I have a garage door that will not close unless I stand inside and hold the button. The door closes but then reveres as if something is underneath it. this happens only in cold weather....
I'd guess that the lights that sensse that something is in the way are dirty or not aligned properly and the cold makes it worse. Also make sure to get some WD40 on the door track and wheels and then the chain on the opener if it's a chain type.
Dec 04, 2009 | Sears Craftsman LiftMaster Chamberlain...
Have to hold the push button inside my garage to close garage.
You have a door sensor problem. Make sure the sensors are pointed at one another and the small light on each one is lit and not blinking. Also check the wiring.
Jul 19, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman Garage Door Premium Control Console Failure in Cold Weather
first guy has the mounting screws tp tight or the wire is preventing wall station for sitting flush against wall....second guy check your safety eyes...
Jan 23, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
1,239 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
