Question about Sony VAIO NR Series Notebook VGNNR460EP
Battery is not working
My sony viao model VGN-NR460E, the battery is not charging when connected to it's adaptor, now the battery is only 30%. i bought this laptop last october 2008 in pricemart barbados. i need your opinion about this problem. thank you so much.
  • 369 Answers
Hi i feel that either the battary is ded and needs to be replaced or the battry is not connecting well with the pin alignment inside please try to remove and clean the golden pins aover both sides with contact cleaner and should work if not then sorry u have to replace the battry cauz the battries cannot be repaired
Posted on Jan 24, 2009
Viao vgn-nr430e/p just died
remove battery and retry with only ac power connected ..if that works then the battery is bad...if that doesnt work then it could many other things like bios battery, power connector, mobo...
Apr 15, 2013 | SONY VAIO NR Series VGN-NR430E/P NoteBook...
Sony Viao laptop just started shutting itself down while I was working on a word document. Laptop will not stay on more than a minute or two after booting up even if nothing is open. Battery is charged
Disconnect external devices. Remove battery and power cord. Then reposition them again. Be sure battery is locked with the switch at the bottom of the unit. Keep charger connected. If issue continues it may require service.
If you can see VGN-CS on the upper left corner of the lid (your unit's model number) you will need to call Sony as this is a known issue
Mar 26, 2011 | Sony Computers & Internet
My Sony Viao wont stay charged and when i try to power it up, it shuts down by itself at the sign in screen. It wont let me get past the sign in screen,
Are you using a Sony Battery or an aftermarket cheaper version?
If your battery has been changed to a different brand then thats your problem and a whole problem in itself.Not saying there is anything wrong with that, but the Sony ISBmngr.exe file will stop the charging of any battery exept Sony's and put the system into hibernation mode. ( website with Info below)....
If you have the original manufacturers battery then go on.
This is the typical charging-plug, jack, for laptops. Many times the plug itself is bumped over time and pushes on the pin in the center. The charging time becomes very short, if at all, because the connection is broken.Some are completely or because of the position of the wire holding it just right long enough to give a short charge.
32917b9.png With a Voltmeter ,check the output of the charger itself to be sure it is working properly.
Although VIAO has been out for a while & because the model was not listed here the age of the battery may also be in question. If the battery has shorted out and the charging unit & jack are fine then a bad battery that has shorted will cause you symptoms also. Try removing the battery and running on the charger alone.
Here are a couple of sites that I found that deal with Sony VIAO's
Oct 04, 2010 | Sony VAIO VGN-CR220E/P Notebook
I have a sony viao vgn-c210e. but there is an x
u r laptop battery has dead u need to replace it
Jul 29, 2009 | Sony VAIO VGN-C210E/H PC Notebook
Hi, I have Sony viao model VGN-N11M/W.My modem
here u go m8 you should now have no troublesgetting the software upto date.
Jul 02, 2009 | Sony Computers & Internet
No power
I think this is not a very big problem check your charger adaptor and try to replace with another one i think it will solve the problem.
Sep 09, 2007 | Sony VIAO P4 PCV-RS712 3.0GHz 512MB 200GB...
Sony VAIO NR Series Notebook VGNNR460EP Logo
130 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
