Question about McCulloch 16 In 4.5 Hp Electric Chainsaw With Carrying Case MCC4516FK
I have a stihl chainsaw that won't fire
I have a stihl 0340AV super chainsaw that won't fire-- It has plenty of spark, but just won't fire. Could you please tell me what to do to correct this.
  • tudi platt Jan 25, 2009
    I did this--still won't fire- I have spark, but not firing-- put fresh gas in,new plug,rebuilt the carb, so any suggestions. Thank you for your time.
  • Anonymous May 06, 2009
    I too have the same problem with my stihl chain saw. After cleaning and checking the gap on the spark plug and rebuilding the carb it will not start. It is now spitting the fuel out the exhaust after the rebuilt of the carb. I am guess the rings are bad?
  • 3 Answers
DID YOU REMOVE THE PLUG AND CHECK THE SPARK AT THE GAP? IF YOU HAVE FIRE THERE THEN THE PROBLEM MUST BE A FUEL PROBLEM. ARE YOU USING A FRESH GAS MIXTURE? YOU CAN PUT A FEW DROPS OF MIXED GAS IN CYLINDER THEN RE-INSTALL PLUG TO SEE IF IT FIRES, IF IT DOES THEN YOUR NOT GETTING GAS FROM THE CARB.POSSIBLE STUCK DIAPHRAGM. GOOD LUCK!!!
Posted on Jan 25, 2009
    Brigadier General:
  • 4,088 Answers
Another possibility is the flywheel key has sheared--pull flywheel and check. Is the nut loose? That would allow the key to shear. If the spark timing is off, it sure won't run. The nut should be torqued when tightened.
Posted on Jul 06, 2009
Will fire,wont stay running.wants to be full choked,open choke,it dies
Jerry, First thing to get is a new plug gaped correctly and try. Could need carb. adjustment, fuel filter replaced, bad fuel line(cracked/pinched), Dirt/faulty diaphragm in carb. plugged spark arrester in muffler,etc.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
https://answers.yahoo.com/question/index?qid=20090528073906AA0y882
Chainsaw will only run with choke
Stihl Chainsaw starts but won run
http://tekindoor.com/miscellaneous/stihl-chainsaw-troubleshooting
May 28, 2016 | Garden
Can't start sthil AV34 chainsaw
Do you sitll have a good spark.? Have you increased the gap too much.?
Nov 12, 2012 | Stihl Garden
Stihl o28av wood boss will not start even after I rebuilt carb
Rebuilding it does not mean it is adjusted correctly but if you are confident with that I would check for air leaks in the hoses. Replace the spark plug or make sure that there is spark in the existing one. You can test that it will fire with starting fluid then you know that it is not getting the right amount of fuel.
Oct 10, 2012 | Stihl Wood Boss Chainsaw 20"
Has spark but want start
028 is the size ofm a Stihl brand chainsaw.
Jul 30, 2012 | Garden
Working on a Stihl 16" 031AV Chainsaw and have
Plug may have weak spark, as odd as it sounds it does happen, try fresh plug.
Sep 02, 2011 | Garden
The Stihl 038 super won't start. It is getting too much gas on the spark plug when I try to crank it. Just replaced the carb hoping it was that but still it won't start. The saw was working fine a...
hi there mwb15
have you made sure the ignition coil is producing enough voltage to fire under compression load ?
you may get a spark at the plug unloaded but under load it may be breaking down / weak making you think its got a fuel problem ?
does your system use a cdi coil system or point/condenser system ?
spark usually falls into weak spark, no spark catergory
if compression , fuel ( you replaced carb) and exhaust are ok , and you have air and vaccuum tight c/cases only things left are timming and spark
remember F A C T S
F = Fuel A = Air & ( air tight c/cases ) C = Compression T = Timming S = Spark
compression should be about 130- 140 approx if in good running order
take a look and let me know
cheers pauly46
Jun 18, 2011 | Garden
I have a Stihl 028 Av super chainsaw it has been runing well but now I can't start it how do I check the spark on the ingnition
Just remove the spark plug, connect the wire, and lay the plug base on engine metal. Turn on the ignition and pull the starter. If nothing, first try a fresh plug gapped at 0.020". If still nothing, service on the ignition system is required. Suggest finding a Stihl service dealer if you don't have mechanical service skills. Hope this helps!
Nov 22, 2010 | Garden
0340 AV stihl chainsaw won't fire
Spray a little starter fluid down the carburator . It is starts then is is a fuel problem. Most likely a gummed up carburator. Remove and clean .
Jan 24, 2009 | Garden
McCulloch 16 In 4.5 Hp Electric Chainsaw With Carrying Case MCC4516FK Logo
808 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
