Question about Kenmore Sewing Machines
Pressure foot for Kenmore 385.1960180
Kenmore sewing machine model 385.1960180 pressure foot
5 Suggested Answers
  • 1116 Answers
SOURCE: pressure foot holder is missing
It's presser feet and not pressure feet.
I am not sure what you are asking for. Look through these to see if you can find what you are looking for - http://www.sewingmachinesplus.com/sewing-feet.php
Posted on Mar 10, 2010
Tally Girl
  • 1122 Answers
SOURCE: what is pressure foot on
This is the foot that comes down and holds the fabric layers under the needle.
There will be a pressure foot lever to raise and lower the pressure foot at the back of the sewing area, it usually operates vertically, although some makes have a lever that works horizontally.
The pressure foot needs to be lowered BEFORE you start stitching as it activates the top tension and also helps with the stitch formation by holding the fabric firmly as the needle moves up and down.
You can read some general sewing machine info at www.sewing.about.com too.
Posted on Mar 29, 2011
SOURCE: How to adjust the tension
You are not actually able to adjust the presser foot. For quilting you should pick up a "free motion" foot pedal made specifically for that. They run on e-bay for roughly $10-$20. Make sure you get one that fits your type of machine.
Posted on Apr 16, 2011
  • 539 Answers
SOURCE: My Model 19233 sewing machine
Pressure regulator located top left-hand side of machine. May have a spring baring to "push" into down position for more pressure on pressed foot, or may have turn option. Look at your machine one more time, please. Jimmy
Posted on Apr 02, 2012
NEED DIAGRAM FOR THREADING A KENMORE 158.19802 SEWING MACHINE
The threading on these Kenmores is pretty consistent from model to model (good machine, by the way!). Be sure to ALWAYS raise the presser foot when threading the upper thread--insures the thread seats in the tension disk.
14 Kenmore Top Threading FREE SAMPLE
How to thread Sears Kenmore Sewing Machine 158 12270 158
By the way, the metal projection at the top left of the machine regulates the amount of pressure the presser foot applies to the fabric and feed dogs. Push it down to increase the pressure--important when changing types & weights of fabric. To release the pressure, push down on the ring that surrounds the center projection piece. AND, when finished sewing, it is a "great" idea to always release this pressure button before walking away from the machine. Leaving it pushed down over a long period of time will eventually compress the spring and the pressure will no longer work like it should. Also, be sure to clean and oil your older Kenmore regularly. Use only fresh, good quality sewing machine oil or liquid Tri-Flow Synthetic Lube. Open the top, side, and bobbin area. Gently rotate or rock the handwheel and apply only 1-2 drops of oil every place metal rubs against metal. You can also lube the specific lever and dial mechanisms to keep them operating freely. Do NOT oil belts or plastic gears/parts. Doing this regularly, ie every 40-60 hours of sewing time, will keep your machine running smoothly and quietly and preserve the motor from over stress and possible burn-out.
Dec 31, 2016 | Kenmore Sewing Machines
It seems the problem is the excess pressure of the foot when down.. it must somehow be related to thread tension.. can I change foot pressure?
Depends on the make/model of your machine. Most machines do have a pressure adjustment for the presser foot. Sometimes it is explained in the owner's manual.
Newer machines have a dial somewhere. Older machines will have a screw at the very top of the presser foot bar (sometimes under the top cover). Turning the screw right will increase the pressure, left will release it. Other machines have a plunger type projection on the top left of the machine. Pushing the plunger down will increase the presser foot pressure. To release the plunger, press down on the ring that encircles the plunger.
http://makeitsew.biz/presser-foot-pressure
http://www.sewdaily.com/how-to-sew/sewing-machine-basics/the-best-kept-secret-on-your-sewing-machine
Sewing Machine Pressure Settings for Machine Quilting
Dec 29, 2016 | Sewing Machines
Can you adjust the needle assembly up higher for thicker garments like thicker coats etc. on Kenmore sewing mach. model 158-13360
On some machines, you can lighten the amount of pressure the presser foot applies to the fabric. (Some machines do not have this capability.) But, you don't want to adjust the height of the presser foot.
If the fabric is pushing in front of the presser foot as you are sewing, you might want to try using a walking foot, a teflon foot, or a roller foot.
Kenmore 158 13360 Sewing Machine If this is like your machine, the pressure adjustment is the upright pin at the top left side of the machine. The inner pin pushes down (in various degrees), the further it is pushed down, the more pressure the presser foot applies. To release the inner pin, press down on the outer ring of the pin. It will snap back up where you can again push the inner pin down in degrees. BTW, it is a good idea to always release this pressure pin when you store the machine. If not, what happens is, over time the spring that applies the pressure becomes compressed and no longer applies pressure like it should.
Dec 20, 2016 | Kenmore Sewing Machines
Looking for how to lower the pressure foot on model 16782
Are you talking about presser foot pressure--the amount of pressure the presser foot applies to the fabric and feed dogs?
Some machines have a dial that can raise or lower the pressure.
Some machines have a screw located at the top of the presser foot bar that can be tightened or loosened. (Unfortunately, manufacturers usually did not include this information in the user's manual.)
Even older machines sometimes have a spring-loaded push-button on the top left of the machine. When pushed in, it collapses the spring that applies less or more pressure to the presser foot. The inner button actually applies the pressure in "degrees" which is regulated by how far the button is pushed in. To release this pressure button, press on the outside ring to release the spring. (Incidentally, it is a good practice to release this spring when you are finished sewing. Storing it with the spring compressed may eventually cause the spring to lose its effectiveness.)
Parts of Sewing Machine Pressure Adjustment
Nov 27, 2016 | Sewing Machines
How to thread kenmore sear roebuck sewing machine model 158. 1789181 got at auction no books
Sears carries a lot of manuals for their machines, although usually not free. In the meantime, there are many threading videos that demonstrate machine threading. Machines of similar models will thread similarly.
Threading mom old kenmore sewing machine
Kenmore 158 17550 Sewing Machine Tutorial
Probably best to raise the presser foot when threading so the thread will seat in the tension disk.
Before trying to sew, be sure to oil your machine with fresh, good quality sewing machine oil. Open the top, the side near the needle bar, and turn it on its back to get the underside. Place a couple drops of oil every place that metal rubs on metal. Adding hot air from a handheld hairdryer will make the oil effective quicker.
Be sure to install a brand new needle and use good quality thread--not old or bargain bin variety!
On the top left, there is probably a push button. This is the presser foot pressure adjustment. When the machine is stored, this pop-up button should be released (press down on the outer ring). Being stored with the pressure full on will eventually compress the spring that provides the pressure. Also, be sure to store the machine with the presser foot in the down position (preferably on a piece of scrap fabric). Avoid running the machine with the presser foot in direct contact with the feed dogs as this will wear the feed dogs and also create grooves in the presser foot.
Kenmore 158 1601 Sewing Machine Cleaning oiling and Maintenance
Jul 29, 2016 | Kenmore Sewing Machines
The pressed foot lifter won't hold the material, I can push it up down turn it around this is not right
Are you saying the presser foot has very light pressure on the fabric? If so, most machines have the ability to increase the pressure the presser foot applies to fabric and feed dogs. It depends on your machine's make & model where & how that pressure is adjusted. Older machines usually have a large skrew or knob at the top of the needle bar that tightens down on a big spring, thus the tighter spring increases the pressure. Newer machines sometimes have a dial usually located on the top left or side of the machine head. (Consult your owner's manual.)
The Best Kept Secret on Your Sewing Machine Sew Daily
Under Pressure Adjusting Presser Foot Pressure
May 25, 2016 | Sewing Machines
I have a Kenmore model 1690. The needle when it goes down does not hit the hole in the foot plate. It comes down too far to the left of the opening, making it impossible to use the machine. I have...
This machine, when you have it on straight stitch, will sew with the needle to the left. If it's hitting the pressure foot, you may have the wrong pressure foot on the machine. If it's hitting the needle plate when you have the pressure foot removed, it's possible you have set for zig zag and you have a straight stitch needle plate on the machine. I believe this machine came with 2 needle plates. One for straight stitch, and another for zig zag.
May 03, 2011 | Kenmore Sewing Machines
Pressure foot holder is missing
Mar 10, 2010 | Kenmore Sewing Machines
How do I change the foot on my Viking model 120...can't find my manual and have used the same foot for years.
Hi. I found some illustrations of your model machine on the Husqvarnai Viking web site. (http://www.husqvarnaviking.com) From the pictures, it looks like your machine has what they call snap-on pressure feet.
Pressure feet either attach via a small thumbscrew on the left side of the pressure bar or there is a little device on the back of the pressure bar (usually itself held in place by a thumbscrew) that uses a 'claw' to hold the pressure foot on. This is what it looks like your machine has. To release the 'claw' that is holding the foot, there should be a small lever or button on the back side of the pressure bar. Press that, and the 'claw' will release the foot. To 'snap-on' the foot again, place the foot under the pressure bar and lower it.
I've posted some photos at www.robbiesews.blogspot.com that may help. They're of my Kenmore, but the idea's the same.
Let me know if this helps, ok?
Happy Sewing!!
Robbie
Mar 05, 2010 | Husqvarna Viking 1
Sewing Machines Logo
48 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
SewTechWayne
SewTechWayne
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
