Question about Line 6 JM4 Looper
Jm4 line 6 will not record - Line 6 JM4 Looper
Power supply polarity
Most of the time these things will have the negative in the middle of the socket and positive on the outside. I have found this true on most musical equipment but, other electronics will usually have the opposite. If it says 2000 mA, it has to have at least that much current to work properly, more is ok, less is not. Voltage must be the same to avoid damage. FIRST, I would definitely check the power supply with a test meter to be sure it is dead. The socket has a switch mechanism to turn on the battery when it is unplugged which could be stuck. If it were mine, I would take it back where I bought it and let them deal with it.
Mar 29, 2014 | Line 6 JM4 Looper
My back-track led keeps on blinking, i can't stop it or turn it off!
try taking out the battery, and putting it back in just like booting yr computor.
Nov 05, 2013 | Line 6 BackTrack portable digital recorder
Does anybody know how to fix built-in microphones on rolland BR-600. When I attempt to record, the only sound that gets recorded is noice (hissing sound), and that only after cranking rec volume and mic...
Most of these have a SETTING in the menus that selects the source from different mics and/or line inputs. If the setting is to the line input instead of mic, and no audio is connected to the line input it will act like you described.
Jun 23, 2011 | Boss BR-600 Digital Recording Studio
1) how to make my amp record....because its not working when i try... 2) do i have to a cord in line 1 and 2??? 3) do i have to plug in the cord in :.....line in or line out??????
You will use microphone with balanced XLR connector into the XLR mic input. Note, the ALpha does NOT have phantom power so you cannot use condenser mics.
A guitar can be plugged into the hi-z instrument 1/4 inch jack on the left front of the unit.
To use the line 1/4 inch inputs you will use BALANCED TRS 1/4 inch cables from your source.for these channels. The level on these needs to be line level.
The line outs are for sending audio out to an amp. There appears to be RCA outputs you can use as well.
I am not sure what you mean by making your "amp record"... An amp PLAYS the audio, usually into a speaker.
If you are trying to play a guitar through your amp AND record, then you will connect your guitar to the Alpha, the amp input will have a cable from say Line 1 OUTPUT and when recording wou will have the echo feature on so your guitar is passed through to the amp.
Jan 09, 2011 | Lexicon Alpha Personal Recording Studio
Maybe stupid question....is it possible to record 8 separate mono tracks on this thing? I cannot seem to select only track 5, 6, 7, or 8. When I try to record onto 5, for example, it is impossible to not...
I believe you have to adjust the levels DURING the bounce operation... I don't think you can do that after.
I would consider using a computer based editing program to handle more than 4 tracks...
Aug 30, 2010 | Fostex Mr 8hd CD 8 Track Recorder with CDr
En los amplificadores Line 6 Spider III ¿puedo conectar pedales de efectos que no sean de la misma marca línea 6?
translation: In the amplifier Line 6 Spider 3, is it possible to connect effect pedals of other makes apart from Line 6.
Creo si, pero primo del amplificador con una corda guitarra.
I think that you can, just add them to the input
Jan 23, 2010 | Line 6 Spider Iii 30
No power to line 6 fbv express. Tried 4 different rj-45 cables. Using brand new spider IV as source.Tried recalibration procedure as recommended by line 6. Suspect main circuit board kaput
Is it still under warranty?
If so take it to your local Line 6 service center. http://line6.com/service_centers/
Before doing any of this you may want to try another Line 6 amp. Could be a problem with the amp itself.
Dec 28, 2009 | Line 6 Music
I don't know....
As you know, when you plug in your headphones, the amplifier cuts the sound to the external speaker, routing the signal through your headphones instead.
When you accidentally pulled the headphone plug from the jack, it apparently damaged the jack, which has the relay attached that routes the sound to your headphones.
Replace the jack, and everything may be OK. I say may be, because the jack is attached to a circuit board in these line 6 ampllifiers, and if you have damaged the circuit board, you will have to send it to line 6 to be repaired.
The downside is if it is not under warranty, it is an out of pocket expense, and Line 6 will not even give an approximation on how much a fix will cost. I have gone through it with Line 6 in the past, so I am very aware of the procedure. It is also a limited warranty, and they may not cover this particular damage.
However, if you are straight with them and they feel obliging, they may fix it under the warranty, if it is still active on your amp.
I had a spider 2 x 12, which was switching between amp models by itself, and they told me that because it was not under warranty, that I might want to consider NOT sending it to them, and just buying another amp. I didn't like that advice, because they seemed as though they didn't care about retaining my business.
Now, something to consider is taking it to a reputable amp repair shop (preferably one that is Line 6 authorized), and see what they can do. Maybe your clip is just bent, not allowing it to spring back from the contact switch that cuts off the main speaker. It could be a very inexpensive fix, but you need to have a shop actually take a look at it up close and personal.
Good luck. I, for the most part, enjoy Line 6 products, and their excellent distortions. Just remember, their amps tend to have a LOT of problems. You can find sites that list many many dissatisfied Line 6 amp owners. All that electronics (on board effects, soft buttons and switches, etc.,) make them vulnerable.
Now I mainly use my old reliable Marshall 1/2 stack with my Line 6 pod, as well as quite a few other pedals.
You would be amazed by the fact that you can still get pretty good money for a broken line 6 amp, maybe get something with less bells and whistles to break, and go with off-board effects pedals and processors.
Please excuse me for adding my own opinions, I am quite well versed in this type of advice having grown up in a luthier / guitar shop and have been playing for 38 years.
Good luck with everything, and if all goes right, adn it is just bent, it may cost you as little as a few dollars to fix. I'll keep my fingers crossed for you.
Thank you for using FixYa.
Sep 09, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
How do i recod on the ctk-900 casio?
Try running a line out from your keyboard to the line input on your mac. Go into system preferences, select sound, click the input bar in the upper right corner, select line in/Audio line-in port, then adjust your input volume. You should then be able to record from your keyboard. If this doesn't help you, please let me know. I'm a recording engineer that uses a MacBook for all my multi-track recording projects. Thanks & good luck. Mark
Dec 25, 2008 | Casio CTK810 61 Key Keyboard
Line 6 JM4 Looper Logo
20 people viewed this question
Top Line 6 Music Experts
Vito Vacirca Jr.
Larry Stiles
Larry Stiles
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
Are you a Line 6 Music Expert? Answer questions, earn points and help others
