Question about Home
How do i whiten yellowed tub jet covers - Home
2 Suggested Answers
PartsCenter
  • 125 Answers
SOURCE: how to get jet covers on my lasco tub white they
lasco jets usually unthread counter clockwise out of the wall fittings
Posted on Nov 15, 2009
I have a whirlpool tub and need to find some caps to cover the jets. Not sure what brand tub is, sides are all covered. Can you help?
try a plumbers shop as it is a whirlpool tub
you state that it is a whirlpool tub then you say don't know what brand of tub it is
whirlpool is a brand name
any way the plumbers display of bathroom units and tubs will help you as the jets used are generic and not specific for the tub
Nov 16, 2015 | Whirlpool Home
Is this whitening procedure safe?
You can consult an expert from Invisalign London to get a most effective and safe cosmetic dental treatment for tooth whitening.
This treatment can be used to enhance the appearance of your smile.
Also, this treatment can be used to reverse the process of tooth discoloration and staining by providing you a younger, brighter smile without any side effects.
Sep 18, 2014 | Health & Beauty
What is the main differences between cosmetic teeth whitening treatment and the teeth whitening treatment performed at the dental office?
The cosmetic teeth whitening treatment is not permanent and gives result only for sometime while with teeth whitening treatment (Zahnaufhellung M?nche) you get free for some years like 5 years. So if you are planning to whiten your teeth i would prefer teeth whitening treatment. Good Luck.
Mar 30, 2014 | Health & Beauty
Where to do teeth whitening in Haverhill?
I had a good experience with Pearly White Express Teeth Whitening Center. Take a tour at http://www.pearlywhitescenter.com/
May 17, 2013 | Discus Dental NEW Day White ACP 9.5% Teeth...
I want to replace the 5 jet covers and suction cover for my Spurlin whirlpool tub. Where can I get replacement parts?
Jet Trim in your jetted bath tub have to be matched up by sight.
Click on the link below to find the brand name of your bathtub, then click on the name.
http://uspartscenter.com/bath-search.aspx
Match up each item in your tub to what is shown online.
If you are unable to match the pieces up to what is shown online to what you have in your tub you may email us photos and we will match them up for you.
send photos to: sales@uspartscenter.com
Mar 09, 2013 | Home
Need replacement parts for a MAAX WESTCO INC A159869 8Z31 Jet Bath Tub Would like to replace the white plastic parts in side the tub with chrome as they have turned yellow
Try Guillens.com or usparts.com I have had some good luck finnding jets. Maax is still in business and you might be able to get the jet directly from them, although they are in Canada. Hope this helps.
Aug 11, 2010 | Home
Jets don't work in the jetted tub.
First the obvious, most are electrically connected to a ground fault device, ether an outlet or a breaker. BEFORE ADDING WATER, check these out to make sure they are not tripped. Most all tubs have a minimum water level which must be reached before the jets will operate. This is usually a piece of trim located above the depth of the jets. Make sure the tub is filled to cover this part. If you cant identify the water level device fill the tub so that all the jets are covered by an inch or 2. Some tubs have push button switches or touch pads to control the motor, some have touch sensitive trim. There may be some sort of medallion from the maker on the tub, simply touching it will start the tub. Once you get it going most tubs have a built in timer that turns off the pump in 15 - 20 minutes. For more tub time just hit the switch again but keep in mind that extended exposure in a hot tub can mess with your blood pressure and cause you to loose balance or pass out, hence the 20 minute timer.
Mar 22, 2010 | Whirlpool Safety Bath Walk In Bathtub -...
How to get jet covers on my lasco tub white they turned yellow
Oct 16, 2009 | Whirlpool Lasco Builders Choice Ariel III...
Cleaning a whirlpool tub
The jets turn yellow from exposure to the sun, not much you can do except replace the jets (costly). What is leaking? if you broke the seal on a jet it will leak and have to be resealed.
Mar 24, 2009 | Home
Home Logo
485 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
