Question about Microwave Ovens
My convection heater thermostat does not work properly and on a lot purchase of 10 units most of them make terrible noises on start-up.
  • Microwave Ovens Master
  • 9,047 Answers
If they're under warranty, the manufacturer will fix them at no charge.
Posted on Jan 17, 2013
My panasonic NN-8500 microwave/convection oven the microwave part is working fine but,the convection grill defrost is not
Possibly the defrost heater element has failed. You will need to strip the cabinet off and use a multimeter to test the element. May also be the overtemp safety thermostat may have failed.
Nov 19, 2016 | Panasonic Microwave Ovens
My electric lower oven doesn't get any heat.
Could be a lot of things, door lock switches, bad element, a fuse, the thermostat a broken wire or cold solder joint. etc
Good luck
Feb 20, 2014 | GE Profile 30 " Stainless Steel Built-In...
I have a panasonic convection/microwave. Last night, after I cleaned it, using oven cleaner on a sponge, it made a loud humming noise after running on microwave for about 10 sec. It does not make the noise...
Since the unit makes the noise on Microwave but not convection it is a problem it he Microwave Circuit. Probably in either the rectifier of bad mag, one of them shorted. Just looked at the date you posted this, Im sure you have fixed or replaced this by now
May 31, 2017 | Panasonic NN-C980 Convection/Microwave...
A Farberware countertop convection oven, purchased in 2004 online does not now heat; the clock and timer are working but nothing happens after I set the timer for cooking time. Is Farberwware out of the...
Ya those are a classic, really made tasty baking with convection heat but think it is old machine. Could be just a bad chord as unit runs about 12 amps. Like space heater, if they loose some connection start to make chord not good. I would look for another. I've seen a China one for around $100, and built-in ovens at Habitate for Humanity retail store with that feature for reasonable. Good to fix but when dealing with high amp points, they will wear out as they do with space heaters often.
Jan 13, 2011 | Faberware Microwave Ovens
My Sharp microwave convection oven (R-967M / R96STM) cuts out during convection pre-heating and cooking, It appears it stops heating after 1 min. If the START button is pressed again the oven starts...
Also the fact it is a convection oven could mean the oven temperature sensor is not picking up the oven temp. it is not telling the machine it is there by the board seeing its resistance, the unit will shut off as a safety feature. The oven sees temperature by reading the value of a temperature dependent resistor. As the temperature changes so does the value of the component ( oven temp sensor) that way the unit determines the temperature inside the unit. Sometimes those sensors will break since they are in the area with the heat and moisture, they get old and break.
Aug 17, 2017 | Sharp Microwave Ovens
I've a Sharp R-953. convection+ microwave makes a lot of noise
check the fan blade on convection, may be loose.
Oct 30, 2009 | Sharp Microwave Ovens
Panasonic Microwave NN-C980-B buzzing noise but it still works.
All:
I have a 2003 Sears Ultra Wave microwave 721.63682300 with a similar problem. A few months ago it started giving off short buzzes when turned on. That stopped but then I noticed that everything took twice as long to heat up. After quite a bit of teardown&inspection I found a circuit break in the inverter board leading to ZD704 diode (pictured). I will now try to find a replacement diode to see if replacing will fix it. Thanks for your postings.
Feb 15, 2009 | Panasonic NN-C980 Convection/Microwave...
My GE Profile Convection Microwave Oven - Convection not working
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
uijjf
Dec 02, 2008 | GE JVM1790SK Convection/Microwave Oven
Microwave Ovens Logo
16 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
