Question about Air Tools & Compressors
Craftsman 919.152920 air compressor shuts off
I have Craftsman 919.152920 air compressor when you turn it on it runs until about 30-40 pounds of presure than shuts off if you turn it off and back on again it sounds like it is in labor trying to run but then nothing what could cause this
    New Friend:
    Problem Solver:
  • 8 Answers
If you go to hammerwall.com and look up 919.1529 it will take you with a bit of mucking around to a Sears manual close to your model. Do not click on any of the big green download buttons. Click on the smaller blue message download bars. It tells you basically that your compressor has an internal overload which shuts the motor down if it overheats. the reason for overheating can be low voltage but also could be a stuck pump. To check turn off the power and diconnect the ppower cord from the wall. You should be able to turn the motor and pump with the drive belt. If the pump and motor will not move easily remove the drive belt and see if the motor and the pump turn freely on there own. If one or both are tight it will probably be the motor bearings if the motor is tight or the rings in the compressor if the pump is tight. It depends on your level of mechanical experiance as to wether you want to go further. Small 110v or 240v motors are a pain to pull down and the cost to repair are probably not worth it. If someone you know has a clamp tester and a test plug they could measure the amperage draw with the drive belt off and on. The amp draw should not be more than 10 amps even if you have a fiveteen amp circuit. The motor should have a sticker telling you what the amp draw should be. If all this info is getting beyone you I would suggest a visit to a serviceman for a quote.
Posted on Jan 18, 2013
  • 333 Answers
SOURCE: Craftsman 6hp 150psi 30gal won't keep running
It sounds like the internal circuit breaker in the motor is heating up and then the breaker trips to shut down the motor. This is the protection so you don't have a fire if the motor burns up. The smell you have is the coils in the motor. Sorry to say that you will need a new motor for this unit. I hope this helps out.
Posted on Jan 17, 2009
  • 1388 Answers
SOURCE: Makita MAC2200 runs fine (with new Manifold Switch
I have worked on many makita compressors and have run-across this problem on a few of them. Your compressor has a check valve that is supposed to hold tank pressure after the switch reaches set pressure. There is an unloader valve built into the pressure switch that releases the pressure in the discharge hose after the unit shuts off. The unloader allows the compressor to restart with-out any pressure in the discharge line. If the brass check valve is leaking pressure back into the system, air will leak out of the unloader valve. Follow the discharge line to the tank and you will see the brass check valve. To test valve for fault, run the compressor till it builds around 80 psi and unplug the unit from the wall outlet. Remove the 1/4" hose connector from the check valve and check for air leaking out of the valve. If it is leaking you can order form www.toolpartsdirect.com. or call the makita 1-800 number. The price is about the same. Good Luck on your repair.
Posted on Mar 19, 2009
SOURCE: Craftsman compressor runs for 10 sec. and shuts off.
I have a Craftsman 2hp/12 gallon Air compressor that does basicly the same thing, will start, run for about 3 seconds and stop. I replaced the pressure switch but still have the problem. Any suggestions?
Posted on Apr 13, 2009
  • 5603 Answers
SOURCE: My craftsman air compressor model 919 16737 1.1 hp
Probably the check valve has failed. It apparently is where the pipe goes into the tank from the compressor.
Posted on Aug 24, 2009
dmftrucker
  • 1922 Answers
SOURCE: why did my craftsman 5 hp 240 volt 125 psi air
your motor overheated from too low a voltage if theres a manual reset try this,also replace the two motor start and run capacitors on the motor body
Posted on Dec 24, 2009
The compressor turned on pumped up and shut off and wont start up
Inccrease the line pressure to 90 PSI, a air ratchet is a very high volume air tool and the compressor may not be able to keep up with it.
Jul 14, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Motor runs pressure stays around 25psi
if they are oilless compressors then the rings are worn
Jan 15, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
After the compressor fills completely (up to 120 pounds) it used to shut off completely, but lately it hasn't
remove pressure control cover little black box by air connector and check that switch assembly is clear of dirt and not damaged or apart than run compressor and turn adjustment to desired shut off pressure
Oct 05, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Compressor will not build pressure
It sounds like it is not getting enough electricity.
Try plugging in to an outlet on its own circuit without an extension cord. make sure the circuit is rated for your air compressor. If it is on a circuit with other appliances, refrigerator, lights, ect. try shutting them all off before turning on the air compressor.
Good luck
Aug 04, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Quits pumping at 40 pounds but compressor motor still runs
Did you unlock the ring around the pressure adjustment knob? turn clockwise all the way and relock.
Good Luck
Jun 15, 2009 | Craftsman 1 Hp, 4 Gal. Air Compressor
Apr 08, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Leaks air at the pressure switch
start your compressor and let it buid up pressure to turn off. then unplug from power.lossen the fill tube that goes from the pump to the tank. when you loosen it. if it leaks air then your check valve is bad and will have to be replaced.
Dec 25, 2008 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Air Compressor shuts off
Most compressors have a check valve installed in the tank that allows air from the compressor to enter the tank and not allow back pressure to the compressor. Also there is an unloader valve at the pressure switch that activates when the pressure switch cuts out releasing the pressure in the line. These two devices allow the compressor to start in an unloaded condition so that the motor will not strain. When you place you finger on the intake, the compressor is no longer pumping air thus there is not load on the motor. Your problem may be the intank check valve or the capacitor may be weak or bad. Simple check for both. Many volt meters have capacitor check and amp draw. The capacitor should not be more than 10 percent or rating. enjoy
Nov 28, 2008 | Craftsman Air Tools & Compressors
Air Tools & Compressors Logo
266 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
