Question about GE / Caddx Networx Programmable LCD Keypad NX148E
Where is the battery that the panel says is low and needs replacing?
The panel says to change the battery and the keypad is beeping like the battery is low but can't find the location of the battery
Low battery mess changed it and still continues to beep how do i fix
Power your system down first. Plug in the battery, the panel should beep, then plug in the AC power. If the panel doesn't beep you might have a bad battery. If the panel powers up after the battery then AC power reset your time and the beeping should stop.
May 16, 2014 | GE Security Simon 3 Wireless Home Security...
How do I change battery in alarm system
Find the main box that has the alarm control board in it. This panel can have a 12v 4ah battery or a 12 7ah battery. Unplug the old one, plug in the new one. Make sure you put the black to black red to red it doesn't matter what order but if you do it backwards then you'll have to guy buy some small fuses. GIve it about 12-24 hours and it should clear from the keypad.
Mar 19, 2014 | Honeywell Ademco Alarm 6150rf Keypad Lk
The low battery alarm is sounding for both the console, AND the remote - which I do not have. The ADT people can't come out for another week. How do I silence the beeping? I turned off the status beeps...
The Simon 3 supervises the panel battery and when it's bad or the a/c has been out for a long time..will likely have to charge the battery. A problem arises where the keypad unit will not acknowledge that the battery has been recharged/replaced without you doing a basic power cycle.
Whenever this panel battery is replaced in a Simon 3 (worn out or depleted from no A/C (power-outage)) you should disconnect the A/C adapter, install the new or recharged battery properly and hear the panel tell you it's ok..."..simon ???? is OK.." and THEN plug in the A/c adapter. Assuming the panel is not damaged..it will talk when a suitable battery is installed with the A/c out. If it doesn't talk..check the battery with a test meter. Voltage over 6 volts(approx) is required to make it talk.
Of course, after a total power cycle you will have to set the clock.
Remotes(key fobs) aren't usually supervised (as they are carried away from the site) so it's unlikely it's referring to a key fob low battery. Might you be talking about a remote keypad or device in another part of the house or garage that may have low batteries..finding it and checking the batteries will clear the second part of your beeping.
Aug 23, 2011 | GE Security Simon 3 Wireless Home Security...
Two nights ago, there was a major power surge in my area and lots of appliances were knocked out. The alarm box AC transformer burnt out. I replaced it but the alarm system, every half hour or so keeps...
It's possible the power surge damaged the panel as well. Disconnect the battery and wait for the AC Loss. You'll get a Low Battery on the keypad. Enter your code + off to silence the beeping. If the panel is damaged, it will shut off and back on when you would normally get the AC Loss. Good Luck.
Apr 14, 2011 | Honeywell Ademco Vista 20p And 6150 Keypad...
I have 3 ademco keypads on my system. The system came with the house that we bought, when we moved in, all 3 keypads have no text on the screen. The main keypad by the front door will beep and say...
This means that the alarm panel's backup battery is either bad or not connected. These batteries provide power for the system in case of a power outage and are essential for a solid alarm system. Look inside your control panel box ( usually in the master bedroom closet ) and see if the battery connection is just off or if the battery is missing. If it is connected, it is probably too old and needs replacement. Contact your local alarm company and they can swap out your battery or provide one for you.
Jan 17, 2011 | Honeywell Vista 20P Alarm System Kit with...
Just moved into new house. Plugged in DSC PC1832 to power outlet. Keypad beeps every 3-5 seconds and yield sign is lit. How do i keep it from beeping, and only beep when doors open?
This means there is a fault on the panel, either something very benign ( like the system clock is not set or a low system battery ) all the way up to a major configuration or communications problem. You can press * + 2 to see the troubles on the panel. If it is the system clock, you can set it from there and be home free. It is probably a good idea to have the local alarm company come by and do an inspection and test, though, as the communications may be down ( last tenant ended the monitoring contract, phone line may be disconnected, etc.) and you probably want to change the user codes.
Jan 03, 2011 | DSC 8 Zone LED Keypad
Lock beeps every 10minutes changed batteries still does it
check that the keypad is not defective. You can disconnect the batteries and then unplug the keypad. Now put the batteries in without the keypad connected. If the beeping stopped, your keypad may need replacing. http://www.weiserlock.com/en/SupportPortal/SuggestedFaqs.aspx?prod=FAQ+Categories_Keyless+Entry_Power+Bolt+1000
Dec 25, 2010 | Weiser Lock Powerbolt 1000 Lock
Ademco 6128 keypad beeping at random times & says bat on the display screen now - is there a battery in there we need to change?
you need to change your main control battiery.
the main control panel takes a 12 volt 7 amphour or a 12 volt 4.5 amphour battery. the larget the amphour the longer the system will last when the power is out. available at fry's radio shack or on line. ps: if the key shows a zone number with the bat, that means you have a wireless sensor low battiery.
mj
Aug 29, 2009 | Honeywell 5804 Ademco Wireless Security...
Wired alarm beeps every 30 secs. No reset code or panel box.
You may need a code to silence it, but you can try pressing the '*' key on the keypad.
If it is only beeping when you exit or enter through a protected door, you can remove the magnet (likely drilled down into the top of your door(s)).
If it is a low battery, you'll need to power down the system. To do that you will have to access the main control panel, pull either lead from the battery and disconnect the transformer in the house. If you have difficulty locating the transformer, go to your circuit breaker panel and shut down your circuits, one at a time, until your keypad's display is blank--track the circuit to locate the transformer.
Jul 12, 2009 | GE SecurityS754DAT-RST1 Motherboard
Simon 3 "System Low Battery" after 3 years use
I install these panels.  For the low battery message to clear you need to power the system down completely.  To do this you need to unplug the battery and also unplug the transformer plugged into an electrical outlet.  When you power the system back up, you need to first plug in the battery leads.  Then the transformer.
Jun 15, 2008 | GE Security Simon 3 Wireless Home Security...
GE / Caddx Networx Programmable LCD Keypad   NX148E Logo
42 people viewed this question
Top GE Home Security Experts
Sean
Jim Goldsmith
Jim Goldsmith
Grantec 2000
Level 1 Expert
Are you a GE Home Security Expert? Answer questions, earn points and help others
