Question about Verbatim Store 'n' Go SuperSpeed 500 GB USB 3.0 Portable External 97397 (Black) USB 2.0 Hard Drive
My Verbatim Store N Go Portable Hard Dive keeps ejecting itself from my laptop randomly and for no reason
Hello, My Verbatim Store N Go Hard Drive keeps randomly ejecting itself from my laptop even when I am in the middle of transfering files to it, I have installed all of the required software that was mentioned in the manual but it still keeps ejecting itself, can anybody please offer me some advise on how to fix this frustrating problem. I have a Acer Aspire 5750 running Windows 7 Ultimate 64-Bit Edition ( X64 Based System). Thanks In Advance Chris.
  • 22 Answers
SOURCE: verbatim Portable hard drive ? download entire desktop with applications ?
Don't know why you might want to do this, but assuming the portable drive is equal to or bigger than your system drive (C:), I would recommend you check out Ghost software (not sure of name) but this will put you on it. With Ghost, you make a mirror image of an entire hard drive. I used it to make multiple copies of entire PC's for classroom use.. i.e. Load one PC with all the OS and program software, and then connect other drives to the "Master" one at a time, until I had a classroom full of identical systems. Had to pull the drives, but since yours is already external, connectivity would be the only issue. USB should work, I would think.
Posted on May 30, 2008
  • 105 Answers
SOURCE: How can I recover my Verbatim Store 'n' Go Red 4G memory stick?
Hi Karen
Follow the link bellow i have used this a couple of times and it seems to work well
http://www.filehippo.com/download_recuva/
Regard Alan (alstech)
Posted on May 10, 2009
anaesarora
  • 180 Answers
SOURCE: Verbatim USB 8GB file copy problem
ITS virus problem which is playing with the inf file of the usb drive.
also another possibility is 1) the usb port ihas loose connections and disconnects i between drive sensing
2) certain 8 gb drives go back to a capacity of 2 gb drive if one formats it accidentally .
Posted on Sep 19, 2009
Testimonial: "Spot on!.. I found your answer match my further investigation.. Thanks again for professional work and response..I will highly recommend site."
bob_computer
  • 3153 Answers
SOURCE: I have bought a verbatim external hard drive
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Posted on Oct 09, 2009
SOURCE: Verbatim portable hard drive not recognized by XP - works in 2000
Try it is different USB port of your PC. It worked for me.
Farhan
Posted on Nov 10, 2009
How do i fix a verbatim 53032 1 tb external hard drive to recover files? suddenly it turned to raw drive recognized by the pc but the blue light is on
Computer external hard drive could become RAW file system due to a series of reasons, including virus attack, drive unformatted error, and drive corruption and more.
And no matte which one yours is, always remember not to format this RAW USB hard drive before you do take left drive data back with success.
Hence, from now on, stop writing this RAW drive and perform data recovery processes there to see whether all your original drive files are still recoverable.
Also read more memory card photo recovery information here:
Memory card photo recovery
Apr 29, 2014 | Verbatim 53032 1TB Store n Go USB 3.0 2.5...
Error 1407 external drive
That's a Mac error stating that the file you are trying to delete is currently being accessed.
First, close all open programs and try to delete the file. If that doesn't work, eject the drive by clicking the eject button in a Finder window. Disconnect the drive. Reboot. Then reattach the drive and immediately delete the file.
Feb 17, 2014 | Verbatim STORE-N-GO (95312) 8 GB Hard...
Backed up once successfully but any subsequent tries it says 'no space left' on a 320GB Verbatim external hard-drive. Any ideas?
hi
i would format the external dive and then back up the system hard drive on to it. save any necessary data or files onto CD first-- but if you have a back of the hard disk on this external, no need to keep more than one image copy of the computer hard disk drive. i had to format my external. i do not save anything that is of persoanl value on external drive. if i can i save up to 750M of persoanl data on several CDs
please send me 4 thumbs up
Jul 16, 2011 | Verbatim Smartdisk Clon Portable 97061...
I am having Verbatim 2.5 Portable Mobile Hard Drive USB 500GB and transfered my music mp3 file (with folders though my Windows7 laptop) into that. When I connect this with my Audio Theater Its showing some...
If some of the files came from music services like iTunes or a Windows Media store, they will be in formats other than MP3 and will not be visible on an MP3 playing device.
Are they surely all MP3 files?
Apr 11, 2011 | Verbatim 500GB USB Desktop 500 GB Hard...
Unable to safely eject
Just completely "shutdown" your computer, and then disconnect the USB cable. Then, you should be able to manually "eject".
Apr 17, 2010 | Verbatim 160GB USB FireLite: The "drive...
When I plug my portable hard drive into my computer it flashes
i speak only a little english. my problem is the next : i can´t see the portable hard drive in my pc ( windows xp ) . i would like to know the answer to this problem. thank you
Nov 18, 2008 | Verbatim SmartDisk Firelite Portable USB...
Verbatim Store 'n' Go SuperSpeed 500 GB USB 3.0 Portable External 97397 (Black) USB 2.0 Hard Drive Logo
89 people viewed this question
Top Verbatim Computers & Internet Experts
Martin Murray
Arora Singh
Arora Singh
pankaj rautela
pankaj rautela
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
