Question about Baby Gear
What isofix is compatable with the jane matrix cup car seat?
  • 3 Answers
SOURCE: fitting cabriofix car seat with seatbelt only
yeah i had a cabrio and just fitted it in car with the seat belt the part of the seat belt that would go around your waist goes over the front of the carseat and over were the baby would be sitting there is clips at either side just below the carryhandle put the seat belt through them then put the part of the seat belt that would go around your neck round the back there should be another clip in the middle of the back above the storage part if you put the seat belt throgh it then clip the buckle in and pull tight the car seat should be secure hope i explained it easy to follow.
Posted on Nov 03, 2008
SOURCE: Need Instruction Manual for Jane Matrix Lie-Flat car seat
I think the instructions you get with this seat are really poor - the best place to find them is on U-tube. There is a full demonstration of how to fit the seat in both the lie flat and rear facing mode. I have followed this for both modes and it is really easy to understand.
Hope this helps!
Posted on Jul 15, 2009
SOURCE: Jane Matrix Cup car seat
The best instructions I have found (as I have the same car seat!) were on YouTube. These instructions are really clear as they are in video format and they show you how to fit the seat in both the lie fat and rear facing mode.
In terms of the harness, you may or may not be aware that there a number of adjustments that can be made. The first is that you are able to adjust the positioning of the straps within the seat so that the child is not overhanging the seat. In addition the straps themselves lengthen by adjustment with the buckles on the straps.
I think all of these adjustments are in the instruction manual, which is available on line from the manufacturer if you have lost it.
Hope this helps!
  • 419 Answers
SOURCE: Can the jane matrix car seat be used in the up
Yes, this seat is designed for newborns, but you are correct as this does look a rather acute angle. If you use the lay flat option for a few weeks until baby's head can support a little better, this is often the best option. Please note that the lay flat option can only be used until 10kg.
I hope this helps.
Posted on Sep 15, 2009
10speed
  • 5 Answers
SOURCE: We have a Britax Isofix car seat and the red clip
Yes but it is a question of ethics and expence/expense! There are belts and hasps/clips/ manufacturers but they may not sell to the public considering the liability of unauthourised fitting. I would go to a recycler or junk place, buy from web auction or newspaper, and get another used seat or the parts from another model and adapt them to suit. Get it checked out by a reputable dealer also. I think it is illegal to tamper with them anyway. Local bylaws or stautess would apply depending where you are.. Remember the safety and life of your child is involved...
Posted on Sep 20, 2009
Please help. I have been handed down a britax ASIs car seat which has isofix. Problem is my car does not have isofix. Can I still use it? And do I need to take isofix off? Thanks
Usually the ISOFIX is simply an easier way to tether the seat to the car. Some believe it is safer than tradional tether methods.
You can simply use you car's seatbelts to hold the car seat in. The car seat has 2 large holes behind the childs lower back and that is where your car seat belts slide thru and then click into their connections.
Here is a link to Britax info on the Isofix and Isofit
Britax Info
Apr 25, 2012 | Britax Baby Gear
How do you remove the isofix base from the car seat?
Every ISOFIX base has a button which you can press and release the base from the car seat.
Usually it's a round one at the junction of the ISOFIX base and it's LEG
Jul 29, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
Does the jane matrix car seat fit on powertrack 360 frame ?
Provided that you have the Matrix with the light grey plastic handle, yes. You would require these adaptors to attach the Matrix to the chassis.
http://www.johnstonprams.co.uk/dynamic/viewitem.php?item=C3718
Hope this helps.
Apr 23, 2011 | Baby Gear
We have just been given a matrix jane car seat with no instructions. its a a lie flat are seat and i dont know how to strap it in to the back seat
hi
here is a link to instructions
http://www.johnstonprams.co.uk/catalogue/productfiles/3487X-H59/Matrix%20Pro%20Manual.pdf
Oct 22, 2010 | Toys
Sheared bolt jane matrix cup
the bolts will shear off if over tightend,,,,the only way to get it out now is to try and drill into the end of the bolt and use an "easy out" however the bolts are hardend steel?
Nov 08, 2009 | Baby Gear
Jane Powertrack 360 Manual
Hi Maureen, if you contact info@jane.es they should be able to either post the manual to you or send you a downloadable PDF.
Sep 15, 2009 | Baby Gear
Fitting jane powertrack 360
Are you attempting to place the car seat onto the stroller? If so then I can help as I have a powertrack 360 with the matrix car seat.
Jan 03, 2009 | Jane Powertwin Jogger
Hope this helps!
Feb 08, 2008 | Baby Gear
Baby Gear Logo
114 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
