Question about Ovens
Neff u1422 trips rcd - Ovens
barkencoa
  • 3463 Answers
SOURCE: Neff U1422 oven overheating
Hi
Yes it does sound like faulty thermostat.
You will have to remove the oven from the oven housing, and remove the top cover, and possibly the front console.
Then you will have trace the sensor back to the main oven, and unfasten sensor in oven
You will probably have to remove the rear
panel as well to get the thermostat sensor out.
One other possibility is the sensor may have become detached inside the oven, this will then affect the oven temp.
Good luck
Hope this will prove helpful.
Posted on Nov 22, 2008
SOURCE: Neff U1410 main oven trips the main RCD. Occurs
I have a u1421 with the same problem! I notice the fan doesnt run too well, sometimes it doesnt run at all, needs a prod to get it running. I suspect with no fan, that the element gets far too hot, and then starts to leak to earth, tripping the RCD. I'm gonna try buying a new fan motor - you should ckeck if your fan is running full speed OK.
Posted on Nov 02, 2009
iwillfixforu
  • 619 Answers
SOURCE: Neff U1721 repeatedly trips RCD. Have replaced
Sounds more like the power supplying the oven is at fault. Need to make sure that all power is correct from stove to box. Very unusual for that many elements to be going bad.
Posted on Feb 04, 2010
  • 196 Answers
SOURCE: my neff oven's handle has become loose. I cannot
You need to remove the inner glass panel, should be 2 screws at top and 2 at bottom and remove. The screws for the handle are behind this
Posted on Mar 02, 2011
BADBOYJAY
  • 264 Answers
SOURCE: neff double oven trips rcd when either oven is turned on
your heater elerment has gone in the main oven i had the same problem if you need help takeing it out and see if its the problem get back to me ok
Posted on Nov 03, 2012
Neff U1422 bottom element faulty, is it needed?
the only problem might be hat the oven will not come up to proper temp with out that element .
Oct 16, 2015 | Neff Ovens
Neff u1422 oven where is the element that needs tobe cleaned
behind back panel in oven held on with several screws.
Feb 20, 2015 | Neff Ovens
Neff double oven trips rcd when either oven is turned on
Nov 03, 2012 | Neff U1421 Double circotherm Electric Oven
My neff oven's handle has become loose. I cannot see any screws. how can i tighten handle ? the model is U1422 oven.
Mar 02, 2011 | Neff U1421 Double circotherm Electric Oven
Keeps tripping out rcd 63 amps when warming up after about 10 minutes
If your oven is rated above 14kw then change the RCD to 80A. But if its rated less than this then please check shorted element and change them
Jun 18, 2010 | Neff U1721 Double circotherm Electric Oven
Neff U1721 repeatedly trips RCD. Have replaced lower element 4 times in last 18 months am I likely to have an underlying earth fault, or are "cheap" elements more prone to failure
Feb 04, 2010 | Neff U1721 Double circotherm Electric Oven
Fuse keeps tripping have checked and removed the inner bulb but cooker still trips the fuse, Fan and elements appear to be working
insulation breakdown on fan element will need replacing when heats up tracking down to earth tripping your rcd.
Jan 07, 2010 | Neff B1421 Electric Single Oven
Oct 25, 2009 | Neff U1421 Double circotherm Electric Oven
Neff U1421 main oven trips the circuit breaker.
It might be that the breaker is overloaded and it's no longer supporting the load of all the appliances together.If you do not want to change your breaker you can still use your oven by switching off other appliances that is running while you are using the oven
Feb 04, 2009 | Neff U1421 Double circotherm Electric Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
