Question about Nikon COOLPIX Cameras
Bought new batteries but now on light comes on but all controls locked
All controls blocked but operating light is on
    Genius:
  • 1,019 Answers
Camera needs service.
Posted on Jan 27, 2013
My Road motorcycle won't start after sitting extended time, any ideas?
You said that the lights are on a separate fuse block. Have you check all connections to make sure the other fuse block is getting power and checked the voltage it is receiving? Might also want to check ground to make sure not an open circuit. Also get a test light to make sure you don't have a short in your wiring
Jul 12, 2015 | Road Motorcycles
We bought two new battery's a new alternator checked all fusible links from alternator to battery. Truck only runs for a few days with battery light on then we have to charge the battery. It's an 2004
open or shorted alternator circuit (control wire)
let your auto store test the alternator charging
on and off the truck.
inspect 3 wire connector for burn or lose connection
disconnect 3 pin wire and start the engine.if the light stay on you have shot to ground.
Mar 25, 2014 | Ford Cars & Trucks
Put new battery in my car all lights come but thats it not turn over
I had the same car with the same problem its the silent alarm get out of the car put the key in the lock then lock it unlock lock it unlock if that doesnt fix it try the same thing with the trunk this should turn off the silent alarm I hope this helps good luck
Dec 22, 2012 | Cars & Trucks
Liftmaster security + remotes do not operate. I bought 2 new remotes and neither one of them will program to operate the opener either.
Yes it sounds like the board. Make sure the opener is not in lock. If the light in the wall control is blinking press and hold the lock button for 3 seconds.
Jul 29, 2012 | Sears Craftsman LiftMaster Chamberlain...
ABS Light comes on, speedometer stops working and locks switch
I will bet the check engine light comes on as well?
Jul 05, 2017 | 2003 GMC Yukon XL
Fpa lock on how do i get this offf
hello Lock/Unlock Parental Controls
Selecting this option lets you lock and unlock parental controls settings
using a password.
If you do not lock parental controls, none of the settings for V-Chip,
Channel Block, or Front Panel Block will take effect.
If you forget your password, press the MENU button, then select Parental
Control
(the password entry screen appears). Simultaneously press and
hold CH+ and VOL+ on the front panel for 8 seconds. Parental Controls
unlock and the Parental Control menu appears. You can enter a new
password by locking the Parental Controls again.
Front Panel Block
Selecting this option lets you block (disable) or unblock (enable) the TV’s
front panel. The remote still tunes to any channel. When using this as a
Parental Control method, remove access to any remote that is capable of
operating the television while you have the front panel blocked.
Don’t forget to lock parental controls after you change the status. If you
don’t, the front panel block will not take effect .if this don't work get back to me i've got manual good luck
shaun
Sep 19, 2009 | RCA R52WH73 Projection Television
2006 I-280. Battery died, replaced the battery
I'll try to help. It sounds like the drivers window motor or drivers window control shorted and killed the battery. If you want to fix it yourself you should take off the negative battery cable before taking off the drivers' door panel.
Then look at the backside of the drivers' window control switch and see if anything is melted. It could have melted the lock button too!
Some vehicles have an electronic menu in the dash or information center. This is where the optionable controls for "honking locks" and "flashing security lights" is programmed. You might have to reset the controls.
If you do not have these fancier features check your fuse panel for burn outs. If you do not want to do it yourself go to a glass shop or dealer.
Aug 09, 2009 | 2006 Isuzu i-280
1997 plymouth voyageur locks lock and unlock and interior lights flicker on and off while driving
The "BCM" module on your van has become unreliable.
The BCM is the "Body Control Module" that all these systems go through. The issue is that these are cold soldered and after a time the solder joints break on the computer connection. It is located behind the fusebox underneath the steering wheel.
If you know someone who can solder. You can use an 8mm and a 10mm socket to remove the BCM. Open it up and resolder the joints with a soldering iron. After that everything should be fine.
It is easier than it sounds.
BODY CONTROL MODULE
REMOVAL
Disconnect battery negative cable.
Remove lower steering column cover and knee blocker reinforcement.
Disconnect two wire connectors from bottom of Body Control Module (BCM) Body Control Module .
Remove bolts holding junction block (fuse Panel) to dash panel mounting bracket.
Remove junction block from mounting bracket.
Remove screws holding BCM to junction block.
Slide BCM downward to disengage guide studs on junction block from channels on BCM mounting bracket.
Remove BCM from junction block.
Re-solder Main connection points
INSTALLATION
Reverse the preceding operation.
May 01, 2009 | 1997 Plymouth Voyager
Dummie lights are trying to tell me something!!!!
The ABS light being on means the Anti-Lock Brake System has a problem and is shut off until repaired. The TC light should be Traction Control, which will come on when there is a problem with the ABS. If the check engine light is on then there is a issue with the engine controls, Testing will need to be done to come up with the fix to keep the lights off.
Jan 26, 2009 | 2002 Pontiac Sunfire
Cameras Logo
15 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
