Question about TruTech PLV16320 Television
CODE FOR REMOTE
DIGICLOGIC MODELD14PTV1 TELEVISON RECEIVER AC230V 50HZ 75W
    President:
  • 814 Answers
To solve this problem you will need to consult the owners manuals for both products.Checking to see if they have the codes or a universal code that will work for any set-up. If you find there is no help for your problem, you must then contact customer service for both products and get technical assistance from them to solve the problem. You can try these numbers for help. 1-888-252-6252 and 1-800-252-6123. I hope this helps you with your problem.
Posted on May 17, 2009
Lost remote for pioneer media receiver PDP ro6g stuck on standbys how to fix until get new remote
Do a hard reset on the receiver to see if you can get it to work. Or contact Pioneer and ask for a hidden code to restore the unit to factory defaults. If nothing works you are SOL
Sep 02, 2017 | Pioneer Televison & Video
Code for remote control akai amd05
Hello Robertas,
There are several codes listed for Akai products that I found, listed by type:
TV Codes: 1002, 1061, 1427.
HDTV Codes: 1427, 1432.
DVD Code: 2378.
VCR Codes: 3055, 3058.
Receiver/Tuner Code: 5083.
There are no codes for audio or amplifiers beyond the code for the Receiver/Tuner.
I hope that helps.
Jeff at Remotes.com
Apr 14, 2017 | Akai Televison & Video
I have a 20.1 Dish remote controller. I would like to use the AUX selection to operate my Denon AV receiver. Can you help me with this?
Depending on the age of your receiver, this may be possible. Turn on the receiver. Then press and hold the Aux button until all of the mode buttons light up. Press 2 to tell the remote that the unit to be controlled is an audio receiver. Then you will need to try one of the Denon 3-digit codes. Press # and check that the mode flashes 3 times. Check if your receiver turns off. If it does, check if the other buttons work to control the receiver. Otherwise try another Denon code by starting at the press and hold the Aux button step.
If you want the remote only to control the volume, mute and power functions of the receiver, press 1 after entering the three-digit code and before pressing the # key.
The Denon device codes to try are 669 670 680 682 696
744 759 760 762 792 809 . You can find the directions for programming the Aux key on page 11-12 of the manual. The code list for audio devices starts on page 43. The manual is available from Dish here: https://www.mydish.com/filestream.ashx?ID=3025 . Usually the code list for universal remote features will not always work with devices that were released less than 6 months before the remote was programmed. Devices released after the remote was programmed are similarly not guaranteed to be supported.
I hope this helps.
Mar 29, 2017 | Denon Televison & Video
How do i link my xfinity remote tv
Link it to what? To link the remote to the receiver, hold setup until the light turns green then hit the xfinity button. the screen will then show you a three digit code, you type that code into the remote, and the two are now connected for UHF communication.
Jan 31, 2017 | Televison & Video
I have a URC-9911B00 Oneforall remote, will it work with a JVC RX-7000V Audio/Visual Control Receiver?
The URC-9911B00 remote probably will work with RX-7000V receiver. Try code 0074. The remote was programmed in 2002 and the receiver was listed for sale Amazon in 1999.
I hope this helps.
Jan 27, 2017 | JVC Televison & Video
I need to get my remote control replaced 2CH MINI DVD PLAYER Model no:RSH-245803 POWER SOURCE: AC230V-50HZ 15V INDENT 2013/2011
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the sites.
http://electro-medical.blogspot.com/
Jan 23, 2017 | Televison & Video
How many watts dose a concept cc-752L amp have ?
4 Ohm Stereo Power (RMS): 75W X 2
4 Ohm Bridged Power (RMS): 250W X 1
2 Ohm Stereo Power (RMS): 125W X 2
Signal-to-noise ratio: 100 dB
Frequency Response: 5 Hz - 50 KHz
Total Harmonic Distortion: 0.05%
Input Sensitivity: 200mV-4V
Continuously variable 0 - 18dB Bass Boost
Built-in continuously variable 18dB per octave crossover, from 50Hz to 250Hz
Sep 26, 2009 | Concept (CC752L) Car Audio Amplifier
Direct TV TC64R remote does not work in RF mode with RCA DRD486RH
The DRD486RH is both IR and RF capable but the remote that you have is obsolete.
Mar 04, 2017 | Televison & Video
Childproof lock code for schneider tv
hi i hve gt problem abt my schneider tv childproof plzz tell me hw can u find?
my model is/ ac230v 50hz help me please
thnk uuuuuuu
Sep 16, 2007 | Schneider 210mm f/5.6 Apo-Symmar Lens with...
TruTech PLV16320 Television Logo
60 people viewed this question
Top TruTech Televison & Video Experts
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
