Question about AEG Lavamat 16810 Front Load Washer/Dryer
Wash cycle moves to drain whatever the setting
My washer dryer has worked without fault for 3 years. Today each time I select a cycle after 1-2 mins it shifts to a 3 min drain only. This is the same for each cycle selected even drying. The control panel is largely not a dial electronic. Any ideas. Many thanks
  • darrenbp Sep 08, 2008
  • sauldavidwil
    sauldavidwil Dec 07, 2012
    I am having the same problem, if you have found a solution please can you post it. thanks
Where can I find these switches?
Posted on Apr 09, 2008
  • 51 Answers
Float switch in bottom of machine activated (leak) or pressure switch (or bottle for pressure switch) blocked or faulty.
Posted on Jul 24, 2007
Stops mid cycle. Light flashes, cant get it to move on so have to start all over again
Hi there.
I have the same problem with my machine. Whatever program I select, the machine runs fine until it reaches 54 mins of the cycle remaining. To overcome the problem just to select a cycle that will not stop mid cycle, select a program which is less than 54 mins. I think the 40 degrees and quick wash select is the one to run with. The cycle is 45 mins, obviously less that 54 mins. The LED timer will display the cycle time. No problems with this cycle whatsoever. Not the total solution, but at least you're able to complete a cycle. After it's completed, I also run the spin program at 1200rpm. I hope this helps.
Regards, Ian.
Nov 22, 2010 | AEG Lavamat 72640 Front Load Washer
Ge stackable washer dryer MODEL wsm2700wbwww
3 year old GE stackable washing machine, had water coming out the top and would not drain or go through cycle, when shut off it drained a little but when turned on again it filled up and over flowed.
Apr 18, 2010 | GE Spacemaker Washer and Dryer Electric...
Rumbling noise during draining
i know with my fridgeadair it was the pump going out of mine , it would take me 3 spins to get the clothes wrung out enough to put in the dryer.
Dec 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My Candy GrandO washing machine is boil washing
sounds like overheating, don't use until you have had it checked, may be dangerous
Sep 29, 2009 | Candy CNW136 Front Load Washer/Dryer
Whirlpool duet frontload washer not draining on automatic cycle
Try unplugging for 10 min. This will reboot the system and clear the curcuit of all power. Replug the washer and select spin to drain. Selecting too many cycles in a short period of time can confuse the little brain in the curcuit just like a power surge does after a storm. Clear the brain and start from scratch.
Apr 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Wash machine sometimes gets stuck on rinse cycle & dryer not dry
Sounds like the drain hose for the washer is too far down in the stand pipe at the wall causing a siphon effect, try raising drain hose a little. The dryer sounds like the vent line from back of dryer too wall is pinched causing an air flow obstruction. Hope this helps.
Mar 19, 2009 | Whirlpool Washing Machines
Spin cycle lasts indefinately
the spin cylce in washer, did not shut off?soundslike an issue with the timer itself, no servicing htetimer strictly replace, as far as teh time in the dryer, i would check for clogged/kinked dryer vent, biggest issue with any dryer, innadequate vent
Nov 25, 2008 | Kenmore 98702 Stacked Washer/Dryer
Reset wash cycle
Changing Cycles, Options and Modifiers
Not all Options and Modifiers are available with all cycles. Cycles,
Options and Modifiers can be changed anytime before HOLD TO
START is selected.
Options and Modifiers can be changed anytime after HOLD TO
START is selected and before the start of the selected Option or
Modifier.
To cancel a cycle and select a new cycle
1.
Select PAUSE/CANCEL twice.
2. Select desired cycle.
3. Select the desired OPTIONS.
4. Select HOLD TO START (for approximately 1 second) to
restart the washer at the beginning of the new cycle.
To cancel a cycle
1.
2. The washer powers down, the door unlocks, and clothes can
be removed.
NOTE: If the water level or the temperature is too high, the
washer will drain automatically before the door unlocks.
To change Options or Modifiers after the cycle has started
1.
Select PAUSE/CANCEL.
2. Select the desired OPTIONS or MODIFIERS.
3. Select HOLD TO START (for approximately 1 second) to
continue the cycle.
To drain the washer manually
1.
2. Select DRAIN/SPIN.
begin the drain.
4. When the spin is complete, the door unlocks. Items can be
removed from the washer.
Nov 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
MLE2000 front load washer
Hi..I had the same problem yesterday...the maching would start when I pushed the button and then stop..I had to push the button again to get it going..My stacked set is around 8 years old.
Here's what we did..moved the washer away from the water source and unscrewed the water intake lines..there is a little screen there...took the screen out of both hot and cold lines..one screen has some debris in it..the other was almost completely blocked..we are on a well and sometimes dirt..etc..gets in the lines..
Today no problems doing the laundry..its working like new..
Oct 26, 2008 | Maytag MLE2000 Front Load Stacked Washer /...
Washing time & quality
Look for wash cycles in your users'manual. It is best the read the manual well before operation.
Apr 05, 2007 | Whirlpool AWG320 Front Load Washer / Dryer
AEG Lavamat 16810 Front Load Washer/Dryer Logo
203 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
