Question about Vacuums
AEG T7 Vacuum Bagless Vacuum Cleaner Manual - Vacuums
  • 36 Answers
SOURCE: Pulse Bagless dust press system
Dear Customer
please check the following link for
Sanyo Instruction Manual Upright Bagless Vacuum Cleaner SC-150, SC-180
http://homeappliance.manualsonline.com/manuals/mfg/sanyo/sanyo_upright_bagless_vacuum_cleaner_product_list.html
please rate this,Thank u
Posted on Dec 16, 2008
  • 22 Answers
SOURCE: how to put on a belt on eureka uno bagless vacuum cleaner
Unplug the vacuum.
Turn it over so you have access to the bottom of the unit (you should see the brushroll)
At the base where the "head" attaches to the body there is a small silver button that you must depress to remove it from the body. Press the button in with a screwdriver or unsharpened pencil while pulling the "head" away from the body.
Use a #2 Philips screwdriver to remove all the large screws from the bottom. They are all the same size and type so you can collect them for safekeeping without worrying about which one goes where. There are 2 smaller screws (if I remember correctly) that are for the upright lock that you do not need to remove. They will be on the small plastic piece near where the bottom brush "head" attaches to the vacuum.
Remove the clear plastic clog cover.
Gently pry the gray cover off. This shouldn't be too difficult as the cover goes loose when you remove the screws.
Flip the gray side over and you should see the innards including the brushroll, the motor, wiring, etc. Facing the assembly like you were looking head-on at the vacuum the belt should be on the right.
Pull up the far end (non-belted end) of the brushroll and then the belted end.
The brushroll should now be free and you should check the teeth on the belted end of the brushroll to ensure none are broken.
Remove the old belt from the motor (also toothed) and replace with new belt (a second spare would be handy to keep around and this is a good opportunity to clean up the air path).
Put toothed end of belt into the belt loop and stretch it a bit to get the toothed end back into place. The belt should auto adjust but just in case you may want to manually rotate the brushroll a few times after replacing the far end (non-toothed end)
Repeat the rest of it in reverse order to put it back.
Posted on Feb 03, 2009
EwingElect
  • 276 Answers
SOURCE: vacuum cleaner won't go - missing a step
In between the filters there's an access panel that can be removed - there may be a blockage there. You should also check your hose for a blockage.
Otherwise you may need to take it to your local Electrolux Service Center. There may be a problem with the pressure board. The machines have a 2 year warranty, not sure what it'd be in your neck of the woods.
Posted on Apr 03, 2009
juststinks
  • 98 Answers
SOURCE: Hoover Bagless WindTunnel vacuum cleaner.
very easy. you have clog. take the brush off look where the hole is thats where the clog is. it might be in there you might have to take the housing off of the motor
Posted on May 08, 2009
  • 33 Answers
SOURCE: download parts and operators manual
This owner's manual is available on the Eureka website. www.eureka.com Type in your model # down in the right corner, search & buy accessories.Click go, then choose either the 402A or 402A-1. It is the same owner manual for either one.
Posted on May 19, 2009
Bissell powerforce manual
You should be able to download manual from this site.
There seem to be quite few filters to worry about.
Good luck.
Bissell User Guide Upright Bagless Vacuum Cleaner 6594 ManualsOnline com
Aug 10, 2014 | Bissell 6594 PowerForce Bagless Upright...
Clean dirt sensor on panasonic bagless vacuum
Did you check to make sure there isn't any small piece of dirt, etc. in the way? Keep working with it; it should reset back to normal
Jun 06, 2012 | Panasonic Bagless Upright Vacuum Cleaner ...
Where can I buy parts for a Kalorik bagless vacuum cleaner? It looks like the model pictured above, but the # on the manual is USK VC2.
Kalorik ' Parts and Accessories ' Discontinued ' item VC16107
Here is their site, it looks like the canister vacuum is discontinued.
If this is not adequate information, you can find several contact options on this page.
Gary
Feb 16, 2011 | Kalorik VC16107 Bagless Canister Cyclonic...
Pulse Bagless dust press system vacuum cleaner I need to download the instruction manual
Dear Customer
Dec 16, 2008 | Sanyo Vacuums
Download parts and operators manual
Sep 15, 2008 | Eureka Boss Superbroom Bagless VacuumStick...
Vacuums Logo
42 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
