Question about E-Machines eMachines Desktop PC
I need hepl with setting up the bios on a T2824 Emachine
Hi i have an T2824 EMACHINE THAT I NEED TO SET THE BIOS UP ON IF YOU CAN HELP ME WITH THIS I WOULD BE VERY THANKFUL FOR THIS
    President:
  • 2,692 Answers
Hit  f 8 when starting computer. When you get into the BIOS setup screen choose the default settings. Find the start priority and put the cd driver first.
Posted on Jan 24, 2009
Hi my emachine 540 PC will not bootup, can you help me?
try pulling the plug on the system board to make the default settings in bios. Unplug all drives and see if you can get in bios this way. Check that it passes memory testing too..start with minimum devices attached (memory and video).
Dec 24, 2012 | Computers & Internet
I need the correct bios setting for emachine model w2828
just enter to the bios screen
and restore to default settings
that's it
May 17, 2010 | Computers & Internet
I insert restore disk and nothing happens
Hi there.
If you don't have the option of hitting F12 to change the boot order to the CD/DVD just as the computer starts up then you will have to enter the bios to change the boot order.
Restart the machine and hit either Del or Esc to enter the bios, look for the boot order and set the CD/DVD as first boot device, hit F10 and exit the bios, the computer will restart and you should now be able to boot from the CD/DVD.
Please post back with the results and if you need anymore help.
Good luck and thanks for using FixYa!!
May 24, 2009 | E-Machines (T2824) PC Desktop
I NEED TO MANUALIE SET UP THE BIOS IN EMACHINE
When you first start the computer press the f 8,(that is the key most use to get into the bios). Set everthing to the default except the drive sequence which you want the cd first. If I am not correct,then  go to the support webpage and downlad the manual.
http://www.emachines.com/support/product_support.html
Jan 24, 2009 | E-Machines eMachines T3830 PC Desktop
Stuck on emachine screen
Hi there
Hit F2 on boot up and get into the bios settings, if it lets you in choose default bios settings, save and reboot, see what happens
Good luck
Jan 08, 2009 | E-Machines eMachines Desktop PC
My pc was doing this but now it's doing something different but simular
Try telling it to boot the CD instead of the disk for now, since you need to install from that...or perhaps a newer OS.
Jun 23, 2008 | E-Machines eMachines T3830 PC Desktop
Emachine boots to bios with a new hard drive installed
Go inside to your BIOS menu then set the BOOT sequence to CD as the first boot so when your PC with the operating system installation disk inside it will load the installation wizard.
Good luck hope that helps........
Jun 16, 2008 | E-Machines eMachines T3830 PC Desktop
Need boot load for emachine T2484
Hi, You need to enter your CMOS/BIOS setup and set your "First Boot Device". Immediately after powering up, press the "Del" key, display will show CMOS/BIOS settings. Verify that all your hard disks are being detected/recognized by your PC. Thereafter, set your First boot device to your new HD. Save and Exit. Hope this be of some idea/help. Post back how things are or should you need additional information. Good luck and kind regards.
Sep 30, 2007 | E-Machines eMachines Desktop PC
Mobo problems
Assuming the power supply is ok, and the pc is a few years old, it could be a flat cmos battery so check for the disc shaped 3V battery and see if it's flat. Whilst you have done that look for the JBAT1 terminal and put jumper on pins 2-3 for a few seconds then back to 1-2. Look at the capacitors (tube shaped things) for the tops and sides swelling, if so mobo needs replacing. You need also to check the power supply leads to the motherboard and check its connected to mobo ok. Start up pc if it will and set the time and date in standard bios settings.
Jan 24, 2007 | E-Machines (T2824) PC Desktop
E-Machines eMachines Desktop PC Logo
219 people viewed this question
Top E-Machines Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
