Question about Canon P23-DHV Calculator
The ink has dried up, so how do i replace the ink
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
Follow the instructions on page 3 of this manual.
Posted on Jan 16, 2013
Hello I have a problem with my xerox. The message is: waste dry ink full! What should I do?
replace the dry ink container
take it out and clean out
get in a technician to clean/ replace it
Jul 15, 2016 | Xerox DocuColor 3535 Copier
I am facing a problem in HP laserjet P1102. printer shows "Install Black Cartridge" when I have tried my best to resolve the issue. I am a technician and many printers come for this problem to me. I
#1-Remove the ink cartridge and use a q-tip and alcohol to clean the metallic portion of the cartridge. Gently slide the q-tip back and forth across the ink distribution openings, ink should cover the q-tip. dab dry with a paper towel and replace into the printer. #2-With the ink cartridge removed...Check the prongs on your printer that press against your ink cartridge when in place for connectivity. If covered with dry ink, use said q-tip and alcohol to clean. #3-replace the ink cartridge with a new one. Be careful, and gentle with your q-tip, rub easy, and let dry before proceeding. Be safe...and have plenty of paper towels on hand.....wear rubber gloves.....
Feb 17, 2015 | HP LaserJet Pro P1102
Color Will Not Print
If you are not using your printer atleast once a week the inks will tend to dry out. you can replace the ink or try a simple test by taking a Q-tip with alcohol on it and rubbing it across the cartridges ink face. then place it back in and try to print something. If it works a little after the test sheet, the ink is too old or dried and needs replacing.
Oct 22, 2013 | Lexmark X Office Equipment & Supplies
I just put in a new black ink cartridge and it will not print black ink. The color ink prints, but the black will not.
Hello nicfurtaw, there are dried ink on the ink carousel, or cradle, you may need to soften the ink. Use cotton buds, dip into warm water and gently wipe the ink hole where the ink pass through, until the carousel is clean.
  1. remove the black ink cartridge
  2. find the spot where the ink pass through
  3. see dried ink on it.
  4. use cotton buds dipped in warm water to soften the ink.
  5. do this several times
  6. clean enough, test to see if the black ink will pass through
  7. replace the black ink cartridge
  8. test the printer.
Feb 10, 2011 | HP Photosmart C3180 All-In-One InkJet...
I have an epson stylus pro 4800. I had not used the printer in a while so I did a power cleaning and the yellow did not work and the other colors were spotty. (I'm running bulk dye sub on left side). I...
Hello
The ink "pipes" under the cartridges in the printer, not in the cartridge, are most likely dried up with ink.
Some times the issue could also be that the cartridges get dried up.
Or possibly the small contacts between the cartridges and the carrier don't touch properly or are dirty.
Something like magic bullet would clear up the dried up ink.
http://www.specialistinks.com/unblock-printer-heads.php
Apr 22, 2010 | Epson Office Equipment & Supplies
How do I clean the printer nozzles as it leaves streekes on printed pictures?
If the ink is smearing, it probably is not getting enough drying time. The ink drying time is a period of time inserted between pages to reduce the chance that a page will smear the one below it in the output tray. This time is factored into the time between when the first page finishes and when the next page finishes. Printing will pause temporarily if more time is needed. The time it takes for ink to dry varies greatly depending on paper type, printer driver settings, humidity, and temperature. In addition, the paper and print settings may affect the speed at which the ink can dry:
  • Transparencies require much longer drying times than other paper types.
  • Some store-branded photo papers do not allow ink to dry correctly because of the coatings used in their manufacture.
  • Printing in Best mode can increase the dry time.
Resolving the problem If the ink smears, increase the drying time. To increase the drying time in Windows, follow the steps below:
  1. When ready to print, click File , click Print .
  2. Depending on your driver version, click Properties , Settings , or Preferences and follow the steps below depending on the option.
    • For Properties or Settings , follow the steps below:
      1. Click the Advanced tab.
      2. In the Extra Dry Time section, move the slider toward More .
    • For Preferences , follow the steps below:
      1. Click the Basics tab.
      2. From the Basics tab, click Advanced Features .
      3. In the Extra Dry Time section, move the slider toward More .
  3. Try a sample print and see if the drying time needs to be increased more.
To increase the drying time for a Macintosh computer, follow the steps below:
  1. From the File/Print Menu , select Ink under the General tab.
  2. In the Dry Time section, move the slider toward More .
Other steps that will reduce ink smearing If the ink still smears when printing, try some of the following suggestions:
  • Decrease the amount of time it takes for the ink to dry by decreasing the print quality to Normal or Fast mode.
  • Try printing on a different type of paper or on paper from another manufacturer. Paper formulas are different between manufacturers and may have a coating that causes the ink to be absorbed at different rates.
  • When printing large graphics or photos on plain paper in Best or Normal modes, improve the results by using heavier paper. Paper that is rated at 90 g/m2 (24 lb.) or higher will not curl or smear as easily as paper of a lighter weight.
Mar 28, 2010 | HP PSC 1210 All-In-One InkJet Printer
Replaced all cartridges will not print black
Before you replaced the ink cartridge, did you let the ink in the previous cartridge run completely dry? If you did, then the printer heads are completely dry and it will take awhile for ink to start flowing again.
Jul 31, 2009 | Epson Stylus CX6000 All-In-One InkJet...
My red ink tank was not down in completely and was like this for maybe two weeks without me catching it and now I can't get the red ink to work. What do I need to clean since I figure something has dried...
It's not good news, the inks have a chemical in them to help them dry quickly so your ink doesn't smear when your prints come out, once it dries like that you can only replace the printhead. QY6-0055-000, around $85.00
Jul 18, 2009 | Canon i850 InkJet Photo Printer
Printer Head needs removal to clean dried ink
Not a cleanable type head, filiment gets burnt, when ink is not around it when printing is done. Ie dodgy ink blocks lines or has air in it and has permanently stuffed the print head, fix on brothers is replace head, cost excessive.,..time for the bin and the newfound wisdom that inks aint just inks.
Ink empy or no inks is read in ink well compartment via a black flag in ink cartridge that must be up and floating as not to obstuct photocell in well area.. check the rectangler bump in rear middle of cartridge. All cartridges must have flags up ie not empty, seeing ink does not indicate a cartridge with ink, a little is always left to prevent air entering system, hence machine calling out no innk cartridge to prevent damage...
Jan 26, 2009 | Brother MFC 420CN All-In-One InkJet...
Canon P23-DHV Calculator Logo
15 people viewed this question
old marine
old marine
