Question about Exercise & Fitness
I need to replace the walking belt on a Proform 835QT. Is there a how-to manual?
    Problem Solver:
  • 9 Answers
There is, but I\'m a tech who has to do it, and I very rarely see a how-to.
You have to loosen the rear roller all the way, then very carefully back out the bolts that hold the front roller in, but just enough to let it loose. If you pull them out all the way you\'ll spend an hour trying to get the frame lined back up.
If you think this seems like a pain in the butt, you are right. It is one of the most labor intensive repairs on a treadmill. Second only to replacing the walkboard.
Posted on Feb 06, 2013
erpaalai
  • 999 Answers
SOURCE: Squeaking noise on my Proform 580 Cross walk
it is the edge of the belt on the deck. Walk in the middle. Eric
Posted on Aug 11, 2009
SOURCE: Proform 520
Not sure what's happened here. treadmill won't turn on when red key is inserted. checked electrical plug to make sure it worked. I couldn't see that there's anything wrong with the red key. Have any ideas?
Posted on Sep 12, 2009
maxtreadmill
  • 832 Answers
SOURCE: Proform 545S needs replacement walking belt
Here is the replacement part page for iconfitness.com
www.iconservice.com/CustomerService/partsModelSearch.do
Posted on Apr 16, 2010
maxtreadmill
  • 832 Answers
SOURCE: Proform 622 Exp treadmill belt slips
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the hex key, turn both rear roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 inches above the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened. Now if this does not solve this problem then check the drive belt and adjust accordingly, also reverse the process of the above mentioned
Posted on Apr 26, 2010
maxtreadmill
  • 832 Answers
SOURCE: my treadmill Proform caliber walk... belts keeps
The deck needs to be lubricated. The lubricant can be purchase @ gympart.com. LUBRICATION PROCEDURE: 1. Turn off and unplug treadmill. 2. Cut off the end of the tube of lubricant. 3. Holding the tube in one hand, insert the tube underneath the treadbelt halfway between front and back and halfway between right and left. 4. Squeeze the full contents of the tube onto the deck in a circular pattern in the center 1/3 of the deck. 5. Plug in2_bing.gif and turn on treadmill, then walk normally on treadmill at 0.5 mph for five minutes
Posted on May 16, 2010
Proform crosswalk 395 keeps tripping circuit breakers
If it's happening as soon as you press start then you need a controller and a walking belt. If it's doing it after a few minutes of use then you need to replace your walking belt.
Jun 27, 2017 | Proform Exercise & Fitness
I replaced the belt on the Proform 530x and it still sticks. I have also tried to silicone spray the deck,. Help ?
You must LUBE very well the deck belt. 2) adjus the roller bearing and LUBE very well 3) Motor can be LUBE follow the instruction manual for LUBE. 4) Adjust the deck belt see the diagram.
sincerely. God bless you.
Apr 23, 2012 | Proform 530 Treadmill Walking Belt
Need lubrication for proform 785 belt
Some ProForm treadmills require lubrication every six months or so, depending on the usage amount. Lift the walking belt and feel on the underside of the belt. If it is dry, you should lubricate it. ProForm recommends you use 100-percent, non-petroleum silicone spray to lubricate the walking belt. Do not use wax or other lubricants, such as WD-40 or a Teflon-based spray
Aug 24, 2011 | Proform 785 Treadmill
How do you adjust a belt on a Proform 385X. It is
If the walking belt is off-center, first remove the keyand UNPLUG THE POWER CORD. If the walking belt has shifted to the left, use the hex key to turn the left rear roller bolt clockwise 1/2 of a turn; if the walking belt has shifted to the right, turn the left bolt counterclockwise 1/2 of a turn. Be careful not to over tighten the walking belt. Then, plug in the power cord, insert the key, and run the treadmill for a few minutes. Repeat until the walking belt is centered
May 17, 2010 | Proform Exercise & Fitness
Apr 26, 2010 | Treadmill Doctor Proform 622 Exp Treadmill...
I need key for ifit 835QT
Hello there. You can get parts here. http://www.iconservice.com/CustomerService/partsPartsList.do?model=29948&modelName=PROFORM+835QT&version=0&company=11
If you have your manual the parts list in the book is the same as online.
Part #90 is the safety key.
Good Luck! Tim
Mar 24, 2010 | Exercise & Fitness
Was just given a Proform 490GS. It has been
Clean item up real good with damp rag-not dripping wet-dust/dirt will hurt walking platform/belt. Icon.com
Icon is the manufacture located in login Utah. Manuals can be downloaded through internet with model# of item, thats located on a silver tag in frt on frame,or under walking platform/mtr hood area. Proform did make one style that the model# was underneth...but thats been 10yrs ago
Jan 06, 2010 | Proform 490GS Treadmill Walking Belt
Pro form service manual?
Please type in your model number on this page to get the free downloadable manual:
http://www.iconservice.com/proform/manuals.html
Hope this is helpful
Sep 11, 2009 | Proform Sport 1000 Folding Treadmill...
Exercise & Fitness Logo
99 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
