Need a manual for sg-738 coin mech - Washing Machines
2 Suggested Answers
  • 5 Answers
SOURCE: by pass coin mech for a maytag washer mah21pddww
All you have to do is program the machine to run with no coins Open the service hatch and use the woolens key to scroll through to the setting which is your multiplier setting it may be set to 610 for example you need to set it to 600. While viewing this number use the permanent press keypad to change this setting each press changes it by one increment keep pressing it until it goes back around to 600 Then close your service hatch and the machine will be set to work for free you only have to select which program you want to start.
Hope this Helps
Posted on Jun 17, 2009
Coins fall directly into change opening on front instead of dropping into collection box
Your coin-mech is jammed and the coins are bypassing the collection box. use the service door key and visually inspect the coin mechanism for a blockage
Apr 22, 2016 | Washing Machines
Maytag Coin Washer can't select Cycle after putting in coins
check the coin mech
If it is turning on properly
check the selector itself.possibly the switch
Mar 18, 2015 | Maytag MAH21PDD Commercial Front-Load...
I have a 1946 Wurlitzer 1015, when i make a selection all that happens is a hum from the junction box. The record tray is stuck in the upright position. I can move the motor arm manually but cannot ge
What has happened is the mech is jammed..Seen this before. I unjammed the mech by hand, Also check cam follower bearings make sure the arm that holds the bearing is not broke..
Jun 30, 2014 | Audio Players & Recorders
Change the number of coins to operate
you need to take the coin slot apart take pictures as you go to put back together the parts to change amount are hidden inside it in hidden compartment if they wheren't removed by some one. your machine didn't come with the coin mech so if you don't have the parts you will need to take it with you to the parts house to get right parts. open the top of the coin mech box there are 2 long rod screws holding it in place usually 5/16 inch wrench fits may need to wiggle the heck out of it to get it out
Dec 31, 2009 | Maytag Neptune MAH5500B Front Load Washer
The coin mechanism is hard to push the coin slider, but it works.
Coin mech is held in place with 4 screw heads in key hole slots.
Move the mechinisim UPWARDS about 3mm and wiggle it around to disengage the screws.
The hex bar is only used to stop the mech going upwards.
Sep 12, 2009 | Whirlpool CAM2752RQ Coin Operated...
By pass coin mech for a maytag washer mah21pddww
Hope this Helps
May 13, 2009 | Maytag MAT12CS Top Load Washer
Washing Machines Logo
126 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
