Question about Scosche Industries Bftak Scosche - Bluefusion Bluetooth Car Kit For Most
Reset bluefusion car kit
It will stop connecting to my phone. If you turn the car engine off and restart it reconnects.
How do I get my Samsung phone GT s5511T to reconnect to my 2015 Subaru Forrester
First: The Forester's radio/Bluetooth is almost brain dead. We should ALL demand Subaru to provide firmware (software) update to correct to numerous problems with this system.
To somewhat correct your problem:
1. Reserve a big amount of time and patient. It will be painful!
2. Navigate the menus to reset all the radio's Bluetooth settings. Make sure that no phone or device is paired with the radio.
3. Reconnect (pair) your phone to the radio by pressing the TALK button on the steering wheel and follow the voice prompts. Do not pair your phone to the radio by pressing buttons on the radio.
NOTE: ONLY ONE PHONE can be connected to the Subaru's radio system and used automatically when starting the car. Kind-of. If you have another phone or user, then... good luck!
Dec 30, 2015 | 2015 Subaru Forester
NO NETWORK SETTING SHOW IN LCD PANEL IN BROTHER 8370DN AFTER RESET THE PF KIT 1 MESSAGE.
Hi gurjit: try this..
Reconnect the LAN cable to the hub to verify
that the cable and network connections are good. If possible, try connecting the
machine to a different port on your hub using a different cable. If the connections
are good, the lower LED of the back panel of the machine will be green.
sends me the result.
Nov 26, 2014 | Brother MFC-8370DN Laser Multifunction...
I cannot reconnect with my ASUS WL-520GC Router after blocking a mac address. While it was reconfiguring the new setting the connection was disconnected before it was finished. Now it has stopped work
You will need to do a "hard reset" which usually requires you to hold in the reset button (30 sec) as you turn on the device.
They always warn against changing settings over the wireless for exactly this reason.
Oct 28, 2014 | ASUS Wireless Router WL-520gc 125HSM...
How do I reconnect my Panasonic Bluetooth to Netflix? It suddenly stopped working and we are paying for Netflix but not getting it
Restart your router (pull power for 10 secs and replace). Wait for the router to reset and reconnect. I have found that internet connections to devices often have difficulties reconnecting from time to time. It may be the issue of automatically assigning IP addresses?
Oct 15, 2014 | Panasonic 3d Blu-ray Dvd Player Dmp-bdt210...
Esp light turns on
you can try that but do it corectly ..key on.. disconnect negative only. key off..reconnect the negative.. then turn on.. wait for dash indicators to go out before restart..
Dec 24, 2013 | 2007 Skoda Superb 1.8
My parrot mki9200 does not turn on i press all the buttons but still does not turn on please help me solve the problem
I had the same problem. stopped turning on one fine day after a little more than a week of installing. then started working again after a few months. realized that it turned on when i thought i had lost it for good. then i also realized that the other instruments in my car were reset, like clock, radio etc. then realized that someone had removed the batteries and installed it again. the clocks restart when you do that. then i realized thats what must've worked and i was right. keeps 'not turning on' from time to time nowadays as well. but works every time i disconnect the batteries and connect them again. like restarting it. hope it works for you too...
May 06, 2011 | Parrot SA Parrot MKi9200 Advanced Color...
WILL NOT CONTECT TO MY I PHONE IT WAS WORKING BUT JUST STOPPED CANT GET IT TO RECONNECT
You can try to reset it, not sure if it will work but worth a try. Hold the green button for a few seconds until it powers down, it will prompt you that it is powering down. Hold the vol + button and the green button until you hear a siren. Turn the device off again by holding the green button. Turn the device on and it will prompt you for language, you must now pair your phone and the device using a 0000 code.
Mar 01, 2011 | Blueant Supertooth Light Bluetooth Speaker...
Nokia CK-7W car kit won't stay switched off when ignition is off!
Main control box could be anywhere behind the dash, try under the glovebox or under the radio. If you have a mute harness to make the sound come through the speakers, this could also be the problem as is sound like you have 12v constantly on the blue wire.
Nov 24, 2009 | Nokia Ck - 7w Bluetooth Wireless Hands -...
Freelander wont start
flywheel sensor hasnt been reconnected,no spark
Mar 15, 2009 | 2002 Land Rover Freelander
Car kit mode activated
I found this on another site, it worked like a charm... roll a VERY THIN piece of aluminum foil, and slide it (almost jiggle it) in the POWER SLOT. I tried it and it worked . Apparently saliva, water or anything liquid will make the connection to activate the phone into the 'car kit mode', so the aluminum foil acts as a conductor and switches your phone out of car kit mode...
Peace
Nov 26, 2007 | Cell Phones
Scosche Industries Bftak Scosche - Bluefusion Bluetooth Car Kit For Most Logo
47 people viewed this question
Top Scosche Industries Car Audio & Video Experts
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Are you a Scosche Industries Car Audio and Video Expert? Answer questions, earn points and help others
