Question about Kohler Engines NEW 18HP KOHLER ENGINE CH18S-62500 REPLACE KAWASAKI BRIGGS ZERO TURN M
How do I wire a ingnition on akohler 18hp
Wiring
  • 169 Answers
Need more info....model and type #
Posted on Jan 16, 2013
How to wire PIONEER DEH-P66C0 AM/FM car sterio XN/UC 50x4 load impedance
Radios are pritty simple until you get into factory retainment and theft stuff.
You should have 11 wires; Red ( power or ingnition), yellow (power or ignition), black (ground or connect to frame.), And 4 sets of doubles (usually colored simular).
First find your power wires, most radios the power is a bigger wire, and should be wired to a hot 12v. Wire you ingnition wire and your ground. (Stop) now check to see if your ingnition and power is backwords, try programming some presets and see if they save, if not try swich in the ignition and power.
All that's left is the speakers, now tipi call there white, grey, purple and orange, but I have some radios that don't concur, so it's best to test one speaker at a time before soldering. You can do this by using the radio fade and balance. For example turn the fade all the way for word and balance all the way right and only the front right speaker should play. Repeat 4 more times and your done.
Oct 09, 2015 | Pioneer Car Audio & Video
How do I wire a 18hp Briggs & Stratton engine to a craftsman GT5000 lawn mower
I dont have all your anwers. In my experience, Kohler frequently has wires to start, run and stop the engine. They also frequently have a low oil and/or high heat control (engine shut down). Also expect a wire from the charging system. On your tractor, you probably have similar plus 'operator presence' wires. These wires require to you to be sitting in the seat for the machine to operate - a seat switch for example. On my tractor, I can depress the 'brake' (which isnt exactly a brake in fact) and the engine will run when I dismount. However, if the mower is engaged, no matter what, if I get off the tractor, the engine shuts down.
You will have to determine what every wire is for and connect it properly. You may lose some engine 'functionality' or tractor safety features. It is never easy to put a Ford starter on a Chevy. Good luck with your project.
Thanks for your interest in FixYa.com
Dec 02, 2012 | Garden
I have akohler bath drain that seals/drains simply by pushing down on the gasketed spring-loaded chrome stopper. The drain is clogged with hair but I can not figure out how to remove it and snake the...
Toe tap stoppers remove by just gripping the stopper and unscrewing it. Once the stopper has been removed the hair will be usually caught on the crossbar underneath the stopper where it can be removed with needlenose pliers.
Spring type stoppers for drains are just about as notorious for being hair catchers. Once again there is nothing to stop the hair from leaving the tub.
May 21, 2010 | Plumbing
I am teying to wire a motor it is 18 hp 2 cil i
NO, no fuses anywhere actually, except maybe in the main positive wire from battery?
Feb 22, 2010 | Desa International 18hp Briggs And...
Refitting my B&S 18hp. I have two wires spare?
Blue wire goes to the earth for the coil and shorts the coil when you switch it off. Red wire goes to the fuel solenoid.
Oct 20, 2009 | Briggs & Stratton Garden
Battery discharing light is on
Does your tractor have electric clutch ? With the switch turned off try removing positive battery cable you then try touching cable to post if you get a spark you have a short in system you could also charge battery and remove positive cable from battery over night to see if battery stays up to check battery,you also have a alternater under flywheel to charge battery you should be getting an output of about 14 volts most likely not the problem
May 05, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
LOW VOLTAGE ON A FEW WIRES WILL NOT RUN
Many wires on most autos will have low voltage around 5 volts is common for wires going to most sensors. What you described with the fuel pump sounds normal for this truck. I would guess the fuel pump is not your problem cant say for shore with out any more info. I am unclear as to what the symptoms are, is the truck not starting. What led you to check the fuel pump. Did you check for spark.
Jan 10, 2009 | 1991 GMC S-15 Jimmy
Kohler Engines NEW 18HP KOHLER ENGINE CH18S-62500 REPLACE KAWASAKI BRIGGS ZERO TURN M Logo
116 people viewed this question
Top Kohler Engines Garden Experts
Tom Chichester
Dennis Key
Dennis Key
Are you a Kohler Engines Garden Expert? Answer questions, earn points and help others
