Question about Belling SGE12X Front Load Washer / Dryer
Softener wont add
The 3rd compartment we fill with softener, but it doesn't add to the wash! And the compartment is always full of water when we don't use softener. Looking at it, it can't go into the wash as it only enters in when the compartment fills above the hole
    Filmmaker:
    Uploaded 5 video answers.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 30 Answers
Please ensure the machine is turned off at the power socket before you do anything.
Have you tried removing the draw? If you pull the draw out on most washers and slightly tilt the draw up and then try and pull further out the draw will come out. (DO NOT USE BRUT FORCE) if it doesn't come out easily then it probably isn't designed to.
If you get the draw out give it a really good wash in hot soapy water, the compartment where the softener goes normally as a piece of plastic that lifts up so you can clean the compartment throughly. Whilst the draw is out also give the inside of the draw compartment a clean out. (PLEASE ENSURE THE POWER IS OFF) Just for safety.
Once you have cleaned the draw replace it and try a full wash and see if that cleared the problem.softener wont add - 1_15_2013_10_08_16_pm.jpg
Posted on Jan 15, 2013
Dispenser fabric softener slot
Fabric Softener Compartment Full Of Water - White Goods ...
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jul 9, 2013 - The small fabric conditioner compartment in the soap dispenser drawer has a plastic cap or tube at the back for the water to siphon up through. ... Make sure the washer is level front to back as well as side to side. .... If the washing machinehasn't been used since there's always the possibility that the plastic ...
The fabric softener part of my washing machine drawer keeps ...
www.mumsnet.com > Topics > Housekeeping
MumsnetAfter each wash, the fabric conditioner part of the drawer is f. ... The fabric softener part of my washing machine drawer keeps filling with water ... Stopped using thedispenser compartment for fab softener and instead did I separate ... see if that clears it up and also try cleaning behind the drawer in case there is a blockage.
Washing Machine ' Fabric Softener ' Problem ' Won't Empty
Jan 16, 2016 | Washing Machines
Water in the Softerner compartment
The softener drawer cover is designed to siphon out most of the water that runs into the drawer so, when the wash is over, the drawer should always be nearly empty. Unclip and take out the detergent drawer, unclip the softener cover and fill the softener tray with water. Clip the softener cover back on and the water should run out immediately. If it doesn't then a small blockage in any of the 3 pipes in the cover can completely stop the siphon action. Cleaning them out is generally all that's needed.
Apr 06, 2014 | AEG Lavamat 16810 Front Load Washer/Dryer
Soap doesn't always dispense on any cycle. oap drw
Hello Bruce - The drawer requires two valves to open to dispenser: the bleach valve and the wash valve. If one fails, it will not fill the softener compartment. If there isn't any cold water supplied to the unit, it will not rinse the softener or the detergent. Possibly the washer may have a faulty water valve or an incorrect water supply to the unit. Also, if the softener dispenser cap is not installed properly, that can cause it to not rinse out as well. Because it could be a number of any one of several underlying causes, I personally recommend contacting a professional to properly diagnose and repair the unit.
May 29, 2013 | Frigidaire GLTF1670A Front Load Washer
Frigidaire washing machine fabric softner will not dispense out
Hello - There are several things that could cause the fabric softener to not dispense into the washer. Are you sure the liquid in the dispenser after the wash is fabric softener? If it is fabric softener, the solenoid that lets the water into the dispenser is not working. This solenoid is located on the back of the dispenser. It only gets voltage during the dispense time and fills the fabric softener dispenser with water. The fabric softener dispenser fills while the washer is filling for the rinse cycle.
When the washer begins to fill for the rinse cycle, the fabric softener solenoid is energized and water flows into the fabric softener dispenser cup. When the cup is full the water siphons out and softener and water flow into the tub.
If the liquid in the fabric softener dispenser is pure softener you may need a technician to diagnose and repair the problem. The voltage will have to be tested to the softener solenoid and a volt meter is required.
If the liquid in the fabric softener dispenser is water you probably need to clean the dispenser cup. **** will build up in the siphon tube and stop the liquid from going into the washer tub. The incoming water will dilute the softener and overflow the dispenser cup and run into the tub. The instructions for cleaning the dispenser should be located on page 43 of the use and care guide that came with the washer.
If you don't have the use and care guide these instructions will help. Open the dispenser until it stops. In the left rear corner of the dispenser, there is a release that is labeled push. Press down on the push area and you can slide the dispenser drawer out.
Remove the insert from the bleach and fabric softener compartments. Clean the bottom of the insert and the bleach and fabric softener compartments. Reinstall the insert and put the drawer back inside the washer.
To test the siphon action slowly pour water into the fabric softener compartment. When the water level goes above the maximum line stop pouring. The water should all drain out.
Hope this information proves to be helpful however if it is ineffective please contact a professional to move forward accurately.
Oct 26, 2012 | Frigidaire Affinity ATF7000E Front Load...
Fabric softener premature release
In my case it was simply a matter of cleaning the nozzles that spray the water into the MAIN DETERGENT compartment. Turns our that when the washer was filling up, some nozzles were partially clogged and were directing water to the side where the softener compartment was, causing the fluid level to rise and therefore releasing the softener early. The washer was NOT spraying water in the softener side, what happens is that the dispenser tray is configured in a way that when the fluid reaches a certain max level in the softener/bleach trays, it completely drains. A way to test for this problem would be to completely dry the softener tray and start the wash cycle like you normally would (including detergent), only without adding any softener to the tray and see if after filling there is any water in the softener tray, this would prove that the water is coming from the other side.
Apr 13, 2012 | Whirlpool GHW9400 Front Load Washer
Zanussie essential 1400 smell of mould can't get rid of it
g'day. Move the machine to check for leaking water. This could be from the taps in the back, or hose clamps throughout the machine and could be causing chronic dampness around the machine. Also check for filter to clean pump. You might have to look under the machine. The soap draw can also get clogged up - but generally doesn't smell. good luck
Aug 14, 2011 | Zanussi FC1200W Front Load Washer
I have an Aqualux 1200 washer/dryer. After the wash cycle the fabric conditioner compartment of the tray is full of water and the fabric conditioner appears not to have been flushed into the machine
If the dispensers are in their proper spot it is normal for some water to be left in the fabric softener dispenser. When you add your softener add water to dilute it as some softeners are very thick and don't dissolve well especially in cold water
Nov 18, 2010 | Electrolux EW1200i Front Load Washer /...
Fabric softener compartment problem.
I have this problem as well.. All washing machines manufactured nowadays are energy effficient, which means that they don't use as much water as the older models. This can result in a build-up of bacteria in the top part of the washing machine, which is clogging up the bit where the water comes through to flush the fabric conditioner into the drum. What I have to do every so often, is to take the top off the washing machine and clean out the layer of black slime that has built up, blocking the holes where the water goes into the washing machine. Another contributory factor is that the usual program used is a 40 degree wash, which is not hot enough to completely flush the machine through. Manufacturers recommend running a 90 degree wash once a month with just washing powder in iit, no clothes. Hope this is some help
Dec 12, 2007 | Washing Machines
Dispenser still full of water and fabric softener
fabric softener This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Nov 15, 2006 | Bosch WFL 2463 Front Load Washer
Belling SGE12X Front Load Washer / Dryer Logo
49 people viewed this question
Top Belling Washing Machines Experts
Are you a Belling Washing Machine Expert? Answer questions, earn points and help others
