Question about Toshiba Satellite C655d-s5518 Amd-e-300 1.3ghz 3gb 320gb Dvd/-rw Win7
Disable a touchpad that doesn't appear anywhere in system
I want to disable the touchpad but the FN-F9 doesn't work bringing up the mouse in devices is no help since the touchpad doesn't appear there nor can I find it in system
I had same problem,i will solve your problem now
just download touch freese program and install then there will be touchpad problem in your pc,
peace
Posted on Apr 05, 2013
  • Toshiba Master
  • 15,756 Answers
Go to device manager in windows control panel admin tools and look under human interface devices. You can right click on it and disable it there.
Posted on Jan 16, 2013
  • 23 Answers
SOURCE: Touchpad doesn't work on Toshiba Satellite 305 PSAGU-03601V
Go to
Use a mouse or Tab+Aly keys
Win XP
Start > Control Panel > System
Click the "Hardware" tab
Click the "Device" manager button.
Click the cross near "Mice and other pointing devices".
Right click, "Enable"
Vista
As above but
Start > Control Panel > Device Manager
Posted on Mar 19, 2010
etaf
  • 779 Answers
SOURCE: Satellite P505 Model S8980 - unable to get
----- control panel - mouse - see if touch pad disabled there ----- have a look in the bios/setup and see if the touch pad is disabled there, as the PC boots - you should see which key to use to enter the bios/setup F2, F10, DEL KEY are often used ----- On some machines a combination of FN and F key can disable/enable the touch pad - F7 or F9 ----- If you point the mouse to the top of the screen you may get a menu dropdown, which will also tell which key to use to disable/enable the touchpad ----- control panel>system>{vista}lefthand side device manger or {XP}hardware>Device Manager>Mouse and other pointing devices>Touchpad>highlight touchpad and right click, Properties, may be an option here to Disable/enable,
Posted on Mar 20, 2010
flipbooks
  • 177 Answers
SOURCE: Toshiba satellite L300 when i have used the
If you're using Windows 7, then I recommend you download and install this touchpad driver. Usually, the reason the manufacturer will release a new driver is in response to some problem they've become aware of.
Touchpad driver: http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=2221251&rpn=PSLC8U&modelFilter=L300D-ST3501&selCategory=2756709&selFamily=1073768663
Posted on Mar 04, 2011
drifterK
  • 4924 Answers
SOURCE: My touchpad is disabled. Fn+F9
Just use the driver disk to load the driver again and this will also enable it ..If not ..just go to control panel and under the touch-pad feature just enable the device ..You can also do it from device manager ..to do so just click on the my computer icon ..and select properties and hardware and device manager ..In here look for the touch-pad under the human interface ..and select it ..right click and enable .
If in the device manager the pad is in yellow with a exclamation sign ..you need the driver and in case you do not have it ..it can be found on the support site of the manufacturer.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=380609&rpn=PS630U&modelFilter=M15-S405&selCategory=2756709&selFamily=1073768667
these are the drivers in case your laptop is the same as this category you placed the question into ..
have a nice day and please rate my answer !
Posted on Dec 20, 2011
  • 6771 Answers
SOURCE: cursor jumps around. fn key is disabled and there is no reference to my touchpad in the control panel under mouse, just references to external mouse. have tried many fixes online and nothing is helpin
Have you thought about doing a complete recovery of the operational system to factory settings. This should address your problems in getting the computer up and running the way it should be.
Posted on Mar 12, 2012
Upgraded toshiba a305-s6852 from windows vista to windows 7 FN buttons no longer work'
"Don't mean to insult .. but did you go to toshiba's website and follow their instructions?
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=2060005&rpn=PSAG0U&modelFilter=A305-S6852&selCategory=2756709&selFamily=1073768663
** FORTH FROM THE BOTTOM **
How to Upgrade Toshiba laptops to Windows 7
You will need your serial number to match against which path to take. They have an "installer" program that will help you get the drivers.
Jul 28, 2012 | Toshiba Satellite A305-S6852 Notebook
Cursor jumps around. fn key is disabled and there is no reference to my touchpad in the control panel under mouse, just references to external mouse. have tried many fixes online and nothing is helpin
Mar 12, 2012 | Toshiba Computers & Internet
Just bought the netbook and the mouse pad isnt working any solutions before I return the thing?
Pretty much only one thing to try or check and that is if the touchpad has been shut off. I believe the keys used are FN and F9. Press and hold down the FN key and then press the F9. That should switch it back on. If not you can use a usb mouse and then look under control panel device/hardware manager and under mouse it should show the touchpad. as well as the usb mouse. If it shows it and it is not disabled then I'd say you definitely have a hardware problem.
If it won't work after checking then take it back. It really is never worth trying to make do with something new under warranty.
Nov 25, 2011 | Sylvania G-Netbook
I bought a new asus laptop 3 weeks ago, one of the reasons I chose it was the feature of disableing & enableing the mouse pad. (I'm 72 yrs, old & I have bad tremmer. Since I had a heartattack...
Disable / Enable the TouchPad Share « PreviousNext » Summary
On laptops, sometimes your TouchPad is disabled for no apparent reason. To reactivate it, first try restarting your PC. If there's no good change just try:
We need the software driver and your mouse are installed
This trick works in Windows XP and Windows Vista.
  • Go to Control Panel> Mouse> Settings tab of the device
  • Click (or to disable)
Notes:
  • On some models, there is a keyboard shortcut to activate or deactivate the touchpad. For example, a ACER, just do Fn + F7.
  • You can click Reset device if neither of those solutions will work.
  • The official website provides synaptics drivers and software needed to run your TouchPad.
  • On the latest laptops, there is a special button to Enable/Disable the Touchpad.
  • HOPE THIS HELPS
  • NORMAN
Aug 23, 2011 | Computers & Internet
It stopped working what to do to start it
1. The touchpad and external mouse drivers should be able to work together. Just make sure that you have the touchpad enabled. To see if you have the touchpad enabled, hold the Fn key and press F9. The combination Fn-F9 locks and unlocks the touchpad. If pressing Fn-F9 once, twice, thrice does not seem to lock/unlock your touchpad.. then you might not have the Toshiba hotkeys working or enabled. So lets forget it and try step 2. If Fn-F9 solved your problem.. there you go !
Arrow The way it works is you have to keep holding Fn key and have to hit F9 once, that should lock the touchpad. Again if you keep holding Fn and hit F9 again, that should unlock it and so on..
2. Sometimes this solves the problem.. Do a power cycle of your computer.. i.e., unplug the AC.. take the battery out.. Plug the AC back in and try to turn computer ON with AC alone (i.e, leave the battery out and just start computer with AC power).. Once windows loads up and everything is fine, then turn system off. Unplug AC.. put battery back in.. Plug AC back in and restart computer.. All should be working now.. if not, keep reading..
3. Click on START>go to RUN>type devmgmt.msc
4. Now in the Device Manager, click on the + sign next to Mice and other pointing devices. Right click on each device listed under "Mice and other pointing devices" and Uninstall ALL the MOUSE Devices you see listed there..
attention Make sure you ONLY uninstall the Mouse devices and not ALL devices from Device Manager like your CD, Display etc.. Just uninstall the devices listed under Mice and Other pointing devices after you have clicked on the + sign to the left of it..
5.Install Drivers
6. In the page that came up saying Downloads ( All operating systems, All categories ), at the top drop the list Filter by Operating System and select Windows XP (I am assuming you have XP.. if you have another OS, select that instead).. then on the right of it, drop the list Filter by Category and select Touchpad.. then click on the button "Apply Filters"..
7. Now you just see two drivers listed..
09-30-2004 Toshiba Utility
Touchpad Toshiba Touchpad Enable/Disable Utility for Windows XP (v1.27.0.3; 09-24-2004; 5.34M)
06-15-2004 Driver
Touchpad Alps Touchpad Driver for Windows XP/2000 (v6.0.303.5; 05-26-2004; 2.43M)
Click on the Download link on the right.. Save them to your computer somewhere in a folder or desktop, where you can remember.. After the files are downloaded, double-click on the file.. Unzip.. then Run.. and it will install the driver..
8. Restart your computer.. Now the Touchpad should be working fine.. Try Fn-F9 combination.. i.e, keep holding Fn key and tap F9 once, twice to see if it locks/unlocks the touchpad..
Jun 29, 2011 | Microwave Ovens
My onborad mouse on my toshiba Tecra A3 pta3u14004 is not working how can I fix it
You can enable or disable your onboard mouse with Fn+F9
TouchPad Enable/Disable ( Fn+F9 ).
Regards
Jun 03, 2011 | Computers & Internet
How can I disable the trackpad to only use an external mouse? Toshiba laptop (Satellite)
For most Toshiba laptops, you should be able to hit FN+F9, and it will disable the touch pad. If that doesn't work, go to your Control Panel, Hardware and Sound, Mouse, and disable it there. Hope this helps!
Mar 28, 2011 | Toshiba Satellite 2400-S251 Notebook
Satellite P505 Model S8980 - unable to get TouchPad to work now where it did work before. The TouchPad ON/OFF button nor the Fn+F9 approach are no help. A USB-connected mouse worked fine, tho. Just no...
Feb 18, 2010 | Toshiba Satellite P505-S8950 Notebook
How do you unlock the mouse touch pad?
5. Go to http://support.toshiba.com there click on Downloads.. select your computer.. Product=Portable, Family=Satellite, Model=M35X-S149.. then click on "GO" button on the right.. Again in the next page that comes up click on "Downloads"..
06-15-2004 Driver
If above doesnt solve it, then please post any errors that you get and I will see if we need to try something else.
Thanks for using fixya...
Sep 15, 2009 | HP Compaq nc6000 Notebook
My mouse button is lock how do i unlock it
5.Install Drivers
06-15-2004 Driver
If above doesnt solve it, then please post any errors that you get and I will see if we need to try something else. Thanks, CF
Jun 25, 2009 | Computers & Internet
Toshiba Satellite C655d-s5518 Amd-e-300 1.3ghz 3gb 320gb Dvd/-rw Win7 Logo
71 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
