Question about Kenmore Kitchen Ranges
What is the "poof" noise coming from my Kenmore 362.75576691 gas range?
I have a Kenmore range oven, model 362.75576691. When the oven is on, especially as it is heating up, I keep hearing a "poof" noise coming from the oven, like there is a delay in the firing. What could this be? Is it a burner in the oven that needs to be replaced?
james klgr
  • 362 Answers
SOURCE: Kenmore Gas Range - burners won't ignite
its possible your gas regulator is bad or the gas line to the ignitor is stopped up look at the line and see if some type of food has blocked the outlet
Posted on Dec 08, 2007
aborcass
  • 2651 Answers
SOURCE: KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
bad oven ignitor is the most common cause of bake failure, located onthe side of hte burner bar itself, if youd like with a multi-meter, you can check the wires leading to the ignitor for 110v. if you have power and nothing was glowing from ignitor theres your problem
Posted on Nov 23, 2008
  • 360 Answers
SOURCE: kenmore glass top range left front large burner out
check the burner socket, it is likely that contact is being lost where the burner connects to the hardwired portion of the system (the socket). It is not unusual for the socket to "burn up" when there is a poor connection to the burner resulting in the burner being replaced and the new burner not working or working intermittently.
Please take the time to rate this solution
Posted on Jan 29, 2009
localwonder
  • 6784 Answers
SOURCE: oven quit working
Hi. this is common in many old gas range ovens. There is a set of coils that are attached to the gas valve assembly. These coils , when activated and operational, open and close the main and secondary valves in this unit. They are controlled by the main ERC(clock/oven control board). I recommend checking these coils and there respective wiring harnesses. if the clips and wires are worn and corroded, simply replace the entire wire harness.
Now, if the wiring harness and wires that are connected to the coils look good and there are no signs of corrosion on the wires and connector clips, this will confirm that the coils have failed and you will need to replace them.
You can also preform an additional test with a multimeter. simply connect your multimeter or voltage meter to both terminal posts located on the coils. once your meter is connected, start the oven cycle. you should register some sort of current during this test at this time. if the current is sufficient and the coils do not initiated the valve action, this will confirm coil failure. if the meter dosen't register a current during oven operation, this will confirm ERC(control) failure. you will have to replace the Oven control board in this case.
The Most common issue in this situation will most defiantly be the coil assembly and not the control.
Please rate and god bless:)
Posted on Apr 21, 2009
SOURCE: Avanti DG 241 BS gas range oven burner goes out and wwill not rel
You need to order parts from AVANTI.
http://www.avantiproducts.com/
Very disappointing customer service.
I have been waiting 6 weeks for a new thermostat. It will not
arrive from China until June -- I was originally told it would come in April. All AVANTI parts are from China and AVANTI in Florida is the
only dealer. I will never buy AVANTI again.
Posted on May 05, 2009
Kenmore Elite range model c970-635131 stainless, oven stopped working
You have short in the wiring; you better call a professional repairman.
Feb 14, 2015 | Kenmore Kitchen Ranges
Turn on gas oven; it lights, big poof/pop comes; then continues to light and heat properly. How do I stop it from popping? The pop is scary!! GE Spectra Gas Stove/Oven
The reason it "POOFS" is because the igniter is slightly weak and some gas enters before it gets lit,this will continue and get worse. To resolve it the igniter would need to be replaced and then as soon as the gas enters it would light it right away without collecting before it lit.
GENE
Oct 10, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
We have a Maytag gas kitchen range. It's about 10 years old. When I have oven turned on while it is warming up and also when something is baking in it, gives off a "poof" sound every so often. ...
The igniter is probally on it's way out. You will likely start noticing it taking longer to cook or not reaching temp easily. The poof is the gas valve partially opening then the igniter finally ignites it. The flame is usually smaller or yellower.
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. This video will walk you thru the correct procedure for testing an oven igniter. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Nov 16, 2010 | Maytag MGR5751AD Gas Kitchen Range
Sears Kenmore Gas oven lights and relights
sounds like dirty nozzle,or not enough air to make combustion, the poof sound is when it builds up with extra gas after flame quits,and re-lights there is a bit of excess gas around igniter.
clean nozzle.altho there is lots of safety percautions built in to stove,MAKE SURE LOTS OF FRESH AIR, AND STOVE AND GAS OFF,when cleaning nozzle.
[could be air intake problem to]
Dec 19, 2009 | Kitchen Ranges
My maytag gas oven model #MGR5755QDW makes a loud poof noise when first turned on. It doesn't do it all the time and it only happens when it is first lights.
You are getting a delayed ignition fom the oven burner. Either the ports on the burner near the ignitor are clogged or you have a weak oven ignitor. part # 12400035 @ $70.00
Apr 08, 2009 | Maytag 30" Self-Cleaning Freestanding Gas...
Problem with oven ignition unit
It works...But I called to have the oven checked out. Thanks, tnf
Feb 19, 2009 | Kenmore Kitchen Ranges
Kenmore Self-cleaning Gas Range 665.75012
I have the same problem with the same exact model. Any helpful troubleshooting tips would be much appreciated. I'm not sure if this is a heat sensor problem or a problem with the control board.
Anyone have any ideas?
Nov 08, 2008 | Kenmore 96422 / 96424 / 96429 Electric...
Oven makes poofing sound when in use
hi. thanks for the question .Yes the igniter is at fault here. replace it. thanks the appliance doc
Oct 02, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Oven makes a poof noise when turning it on.
HI thanks for your question. the poof you hear is the gas sorta igniting because of a failing bake igniter. i would replace it thanks if you need help don't hesitate. thanks.
Aug 08, 2008 | GE Profile JGSP48 Gas Kitchen Range
Kitchen Ranges Logo
26 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
