Question about Hotpoint Ariston Aquarius WD420 Front Load All-in-One Washer/Dryer
Hello, I have a hotpoint aquarius WD420. The machine first started playing up by not pumping out properly, and aborting mid cycle qith an error code, after the first pump out. I removed the filter / float ball assembly and cleaned out a lot of debris which were jamming the ball and blocking the filter. I re-fitted the assembly and the machine washed several loads succesfully. The machine once again aborted mid-cycle with an error code. I restarted a couple of times, and on the final time, the machine melted a small area of the plastic zip on an item of clothing. The machine now doesn't start succesfully. The only action when starting a cycleis the "wash" light lights, and the "door locked" light stays off. What do you think the problem is?
  • 8 more comments
  • peterejones Jan 26, 2009
    Hiya,
    Thanks
    Hiya,
    Thanks for
    Hiya,
    I
    Hiya,
    I have now taken the
    Hiya,
    I have now taken the circuit
    Hiya,
    I have now taken the circuit board
    Hiya,
    I have now taken the circuit board out of the
    Hiya,
    I have now
    Hiya,
    Thanks for getting back to me.
    I have now taken the circuit board out.
    I have found an area of circuit board that has blown. The blown area is Q14 and Q9 which are a triac and what appears to be a transistor. There are two triacs on the board - one mounted on a heatsink and one that isn't. The small transistor (Q9) has been blown to pieces. I bought the machine as a graded appliance 2-3 years ago so I don't think I have a parts warranty. I was therefore hoping to replace the parts on the circuit board. I have the part no for Q14 (the triac) but the transistor (Q9) has been vaporised. Do you or anyone else know what part no this might be? Also do you think this is a symptom, rather than the cause? Is this Triac the motor control triac or the heater control triac?
    Thankyou in advance
    Many thanks
  • 112 Answers
Did the circuit board get wet?
Its behind the fascia panel.
You will need to remove the top cover to see.
Screws are at the back of the top cover.
Remove them and slide the top backwards to get the top off.
Look for any water marks.
Best luck
Posted on Jan 25, 2009
  • Steve Draper Jan 26, 2009
    Your best solution is to go on the net & see if you can find another circuit board.
    It will only be a few bucks.
    I wouldn`t bother trying to fix any pats on the board.
    The board could be damaged beyond repair.
    Also, there may be other resistors which are blown but not visible.
    As for the age of the machine, I wouldn`t say it was a symptom, more like worn out.
    good luck
Hotpoint wd420 shows error code f13 after replacing heater element for dryer.
Change electronic board it is what will cause this problem if you checked all ducts an fan and still heats board is bad
Oct 28, 2014 | Hotpoint Ariston Aquarius WD420 Front Load...
Whay my Hotpoint -Ariston Aquarius WD420 Front Load All-in-One Washer / Dryer stpos have way the circle
You say it stops half way through cycle (if I have read it right), especially when fast spin starts. Does it stop anywhere else (in wash cycle or rinse cycle)?
I would check the main filter in the sump (pipe from drum to drain pump) and ensure pump itself is not blocked which could cause the pump out time to be exceeded and thus stop the program. A faulty pressure switch could also be responsible.
I would also check the tacho on the motor and connections to main board at bottom of machine near to motor.
Disconnect machine by pulling out plug and wait 10 minutes for capacitors to discharge before doing anything, to protect yourself against residual voltages.
From a retired engineer who owns one of these machines.
Jul 28, 2012 | Hotpoint Ariston Aquarius WD420 Front Load...
Where is the filter on a Hotpoint Aquarius wd420 washer dryer?
it is located at the back of the machine...are you encountering problems with this machine? check this link i will give you, this a forum/comments which the owners encountered different problems with this machine..
http://www.unbeatable.co.uk/p_rupr/Hotpoint-Aquarius-WD420-Front-Load-All-in-One-Washer--Dryer-Reviews/22394331.html
Nov 13, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
Error on Hotpoint WD420
Try syphoning the water out by laying the hose down into a bucket or similar, once the water is out, try it again, hopefully this will clear the prob
If there is a reset button, try this once the washer is empty.
Hope this helps.
Jan 18, 2010 | Hotpoint Aquarius WD640 Front Load...
Stops near end of cycle and on/off light and drying high heat light flash
error code f08-htr relay stuck-ckeck htr not open citcuit-connections on board are clean especialy botton connecters-if still throws error then req new board
Nov 12, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Hotpoint Aquarius cycle not finishing with f02 error
Dont think its pressure switch.if sticks one way machine overfills the other brings on heater with empty drum..Could be fauly rinse solonoid valve...Check with multimeter coil should read around3k ohms..good luck
Sep 29, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Hotpoint wd420 not pumping
Hi,I have just been on a service call to the same model,the pump windings had shorted turns and after replacing the pump i have found that it has also damaged the module(pcb assembley) not good considering the module is 120 uk sterling!!
Feb 18, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Flashing f - 05
Error f05 is a problem with the pressure system usually caused by a blockage. These are most commonly found in the pipe which is attached to the bottom of the drum.
Take off the access plate at the back of your machine and you can see it is secured by a large jubilee type clip.
Please be aware that there will be water in this pipe.
Hope this helps & thankyou for using Fixya.
Jan 24, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Hotpoint Aquarius WD420 5+5Kg
The water level vacuum switch are not working , check hose might lose.
Dec 31, 2007 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Ariston Aquarius WD420 Front Load All-in-One Washer/Dryer Logo
427 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
