Question about Baby Lock Imagine
Thread in the new machine
Do I just cut the thread and pull them out of my new Baby Lock Imagine before putting my own thread on the new machine??
  • 80 Answers
You just have to cut it before putting you own thread on the new machine
Posted on Jan 24, 2009
Babylock espire thread cutter stopped working
Your cutting blade is dull. It needs to be replaced by a experienced technician.
Cheers,
K
Feb 27, 2014 | Baby Lock Espire
Baby Lock "Imagine" serger threading guide
I highly recommend you watch the videos on YouTube. They explain as they are threading the machine and the images show you exactly what to do.
Best of luck!
Aug 14, 2017 | Sewing Machines
Please give me instructions on changing thread color in the serger
go to the babylock website
go to the downloads
it will bring up a menu
pick manuals--it will take you to another page
click on sergers
the babylock imagine are toward the bottom
I have a Eclipse--they are great sergers
Feb 09, 2012 | Baby Lock Imagine
Left needle on baby lock serger "imagine" skips
Change needles if they have done a few hours. Ales use ballpoint if seaming stretch fabrics. Also you can get EL 705 needles, which have a longer scarf (groove at back) which helps with the loopers catching the needle thread. Or SUK is the stretch type with this longer scarf Also if you are using cheaper thread cones, try a better quality with smoother finish and consistent weight, this will help too. However if this doesn't resolve issue, your looper timing might need adjustment.
Oct 28, 2011 | Baby Lock Imagine
Baby lock Imagine Serger - Can anyone tell me how to fix this problem. The force air threader (looper) will not push the thread all the way through
I "THINK" I have my machine threaded properly but it will not make a chain stitch. I followed the thread guide for the narrow three spool set up with the right needle setting.
why would the machine not catch the chain ????
Dec 12, 2010 | Baby Lock Imagine
I have never used a serger before and a friend is letting me use hers. There is string on the machine, but how do I put the colors I want on and get it to the needle? The machine is a Baby Lock BL3-417. ...
here's a tip I learned for sewing machine or serger
do one thread cone at a time-the cone or spool that's on the serger--cut the thread close to the cone-then remove the cone from the serger ,,don't remove the thread that you just cut from the serger,,now put your thread on the spindle & tie your thread to the thread that you just cut (make sure it's a small knot) now the thread that's in the needle pull until the thread that in the needle is your & then cut off the other thread & make sure to cut of the knot part & leave a thread tail of 4 to 6 inches
do each spindle this way
Dec 09, 2010 | Baby Lock Sewing Machines
Hi..I have a babylock imagine, and trying to insert the upper looper thread and the thread won't go in all the way, no matter how hard I try, please help..Thank's
There is a wire threader that came with the serger that you can insert into the thread port to make sure the entry is not clogged with a broken thread.
I lost mine and use a length of fishing line.
Mar 18, 2010 | Baby Lock Imagine
Baby lock EMP6 problem. Machine works great then suddenly bobbin thread starts puling through the design. I have ajusted the tension on the thread, removed all of the thread, cleaned all of the tension...
Have you tried changing out the bobbin case? you may have a small burr or scratch. A new one cost about 20$ I think. I have had to replace mine before and it is always good to have a new one on hand.
hollie
Oct 22, 2008 | Baby Lock Imagine
Baby Lock Evolve wire Looper threading tool
You have to get the replacement wires from a Babylock dealer, I did too then after sticker shock at the price of that wire I learned to make a thread cradle and use that to thread difficult threads no. Take about 24 inches of regular sewing thread and fold it in half, put the open ends (together, same legnth) into the jet air port and hold onto the loop end, press the jet air threader and it will thread the machine, insert the thread you want to use into the loop you have in your hand and pull it thru the machine using the ends of the thread you put thru the machine, sounds harder than it is and works all the time. No more spending $8 on replacement wires. You can use this method for all the jet air sergers.
Oct 03, 2008 | Baby Lock Evolve
Does not stitch lower thread
Make sure when you thread the machine you have the thread seated into the tension assembly on top, then make sure you have the threading ports locked and the switch in the proper place for each looper threading, the machine will only partially thread if you do not have the port locked and it will even still sew although not properly.
May 25, 2008 | Baby Lock Imagine
Sewing Machines Logo
78 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Jon Piercy
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
