Question about GE Profile 20.7 cu. ft. CustomStyle Side-by-Side Refrigerator with Dispenser TPX21PRBWW
Ge 20.7 no frost tph21pr,tph21pb water leaks out front
Tph 21pr,tph21pb 1994
3 Suggested Answers
Sea Breeze
  • 4654 Answers
SOURCE: refigerator is leaking
There are many types of leaks and where they begin. It is my understanding that you are speaking of the inside back of the refrigerator. Below is a link that covers many different ways they happen. So if I am mistaken by what you are saying please don't rate me low because your meaning was something different. Just tell me what the problem is an where. Thanks, Sea Breeze
click on link below
HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
Posted on Aug 27, 2009
walterkunesk
  • 683 Answers
SOURCE: GE Profile side by side
it sound like the drain pan and the drain line need cleaned or maybe the drain tube got knocked out of the pan, take a light and look and see what you find down there and let me know.
Posted on Feb 21, 2011
GE Model TPH 21 PRSM WW does not turn offf
Many things that could cause the problem First if you just plugged it or have little in it, it will run for a long time. Next check if if it is cooling properly place a thermometer in a liquid it the refrigerator compartment it should read around 42 degrees. If it is warm in the refrigerator compartment Look at the freezer back wall for frost buildup If you have frost on the back wall, you will need to defrost it and repair the defrost circuit. This is a. Common problem on GE models If the temperature is good in the fresh food compartment you will probably need to replace the thermostat or cold control
Aug 01, 2014 | GE Refrigerators
Water leaking on floor,it's a 1997 GE top freezer type
The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the inside of the freezer at the bottom of the rear cover.
Mar 27, 2011 | GE Refrigerators
GE Profile side by side TPH21PR refrigerator leaks water on the floor at left front corner weekly but not daily. It there a fix or should we purchase a new refrigerator.
Feb 21, 2011 | GE Profile PSW26P Stainless Steel Side by...
I have a GE side by side model #tfx22jrba ww and it is leaking. It is wet under the left front corner. I took off the grill to see if I could find the drip pan and see if it was full but didn't see it. Any...
Sep 26, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Water collects under the produce bins at the bottom and leaks out
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Oct 11, 2009 | Refrigerators
Water leaking onto the floor from freezer drain...
Sep 20, 2009 | Freezers
We have a GE refrigerator that is leaking
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Sep 07, 2009 | GE GSS25JEMWW Side by Side
Red glow (from defrost heater?) at bottom of rear panel in freezer
This is from the GE Appliance "Knowledge Database" Web site:
Refrigerator - Explanation Of Red Glow
In a no frost refrigerator, the defrost timer activates defrost heaters in the evaporator section (rear of freezer) which heat up and melt the frost off the evaporator coils. This process lasts for approximately 25-45 minutes and usually happens up to twice a day.
During this time, there will be no running sounds, no fan noise, and you may hear water dripping or sizzling as it hits the heaters. On side by side models, you may even be able to see an orange glow at the bottom of the freezer.
This is normal.
Aug 06, 2008 | GE GSS20IEP Side by Side Refrigerator
Water leaking from refrigerator
If you just want to clean it you may can access it from the rear behind the cardboard backing. If it's overflowing your water filter may be stopped up or you may have had an excessive amount of frost one time.
Jul 09, 2008 | Roper RS25AEXLQ Side by Side Refrigerator
Refridge
Sounds like the icemaker mold is leaking so the whole icemaker should be replaced.  Leaking water will get on the icemaker heater and cause condensation which then freezes and makes frost.
Oct 17, 2007 | GE Monogram ZICS360NRRH C... Bottom...
Refrigerators Logo
127 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
