Question about SanDisk MobileMate SD Plus 5-in-1 Media Card Reader (860571) Hard Drive
5 in one media card reader wont read
I have a dell e310 which has worked great. It has a built in 5 in one media card reader. i have used this reader without issue until yesterday. I put my card in, the green light comes on however it's not recognizing the card states put media in J
The card works in the camera. i tried my daughters card again green light goes on however not recognizing that anything is in teh drive. HELP!!!!
  • 6 more comments
  • traciboyd Jan 24, 2009
    The green light that detects the memory card illuminates though. So it's being detected just not read?
    OK now my daughters 2gb reads but my 4GB does not could it be too big for this drive? How do I find out??
    OK now my daughters 2gb card reader reads but mine does not. works in the camera just wont show up when in reader. it is 4GB, could it be too Big???
    I am now getting an error message The request cannot be performed because of an I/O device error?? if there was a problem with the card it wouldn't work in the camera right. the card has only been used twice!
    I am out of warranty is there a way for me to find out if my driver is outdated?. My daughters brand new card is working....
    I used this card just last week in this reader. The error message is reading that the request cannot be performed due to a device error.
    It's a samsung HD160JJ/P.
    OK all other cards work in this reader. Card works in camera and I can transfer with usb cord. Just won't read staes i/o device error. is this the card???
    Brigadier General:
  • 5,158 Answers
What is the brand and model of the sd card you are attempting to use..... there may be a conflict between the file system on the card and what your reader can "read"
Robert
Posted on Jan 24, 2009
  • 535 Answers
Remove & reinstall your card reader driver then try to read your card
    Scholar:
  • 155 Answers
Download the driver from this link.
http://support.dell.com/support/topics/global.aspx/support/downloads/en/downloads_splash?c=us&l=en&s=gen&~mode=popup&file=240264
Follow the wizard and restart when prompted. Try if the issue is fixed. If it still doesn't work, proceed to step 2.
If this doesnt work, update the firmware for the reader.
Here's the link.
http://support.dell.com/support/topics/global.aspx/support/downloads/en/downloads_splash?c=us&l=en&s=gen&~mode=popup&file=240271
Follow these instructions when installing the firmware.
1. Click Download Now, to download the file.
2. When the File Download window appears, click Save (Windows XP users will click Save) this program to disk and click OK. The Save In: window appears.
3. From the Save In: field, click the down arrow then click to select Desktop and click Save. The file will download to your desktop.
4. If the Download Complete window appears, click Close. The file icon appears on your desktop.
Install
1. Double-click the new icon on the desktop. For example labeled R12345.EXE.
2. The Self-Extracting window appears and prompts you to extract or unzip to C:\DELL\DRIVERS\R12345.EXE. (Example path). Write down this path so the executable (Example - Setup.exe) file can be found later.
3. The Self-Extractor window appears.
4. Click OK.
5. After completing the file extraction, if the Self-Extractor window is still open, close it.
6. Click the Start button and then click Run.
7. Type C:\DELL\DRIVERS\R12345 in the Open textbox and then click OK.
8. Follow the on-screen installation instructions.
Restart and see if it works.
If the above steps dont work, this maybe a windows issue. Try to do a system restore. Go to start>all programs>accessories>system tools>system restore. Click next. Choose a date when the reader last worked. Click next, finish and try again after the system has restarted.
You may accept this solution if it fixed the issue. Otherwise, pls post back your progress.
  • Rachelle Aviles
    Rachelle Aviles Jan 24, 2009
    Have you tried updating the driver? Yes it can be the card. It may not be compatible with the card reader. You can tell right away if you have another 4gb card of a different make. I assume there isn't one available so the least we can do is check if your reader's driver and firmware are up to date.
    If you have not been able to read this 4gb drive in the Dell E310's reader before, it is likely a compatibility issue. Try out those steps first or try another 4gb card to point out which causes the error.
    President:
  • 2,559 Answers
This is probably due to a recent windows update.
Just right click on my computer,(if it's not on the desk top use the start menu)click properties,click device manager,scroll down to usb devices,select the usb reader,right click on it and select update drivers.
If that doesn't fix it,Shut down pc,remove the side cover follow the wire from the usb device down to the mother board and unplug it,restart pc,go back to the device manager(as described above)click "uninstall" on the usb device,when un installation is complete,shut down pc,plug usb device back in,restart and allow windows to find and install the new hardware.
  • SanDisk Master
  • 19,396 Answers
The 4GB may not be formatted properly, or the car reader drivers may be outdated.
Call Dell Support, they will set up a remote access connection, and fix the problem on your computer.
Click the links below to find ways to fix the problem with no waste of time.
Dell Support Home Page
Online Chat
Customer Service
Leave me feedback after you fix the problem.
  • 679 Answers
The problem seems to be with your card reader. the part where the card is inserted contains some pins like structure that might have got tampered while inserting the card. to check where the fault is...with card reader or the card, try putting some other card and then let me know for further assistance.
thanks for using Fixya.
  • 1 more comment
  • rockfixya
    rockfixya Jan 24, 2009
    then the fault is with the card, as the card reader seems to be fine. it does not matter with the size of the card.
    thanks
  • rockfixya
    to check whether the card is fine or not u can check it by using it with some other card reader. try it....
    good luck
  • rockfixya
    try formatting your card by using it with another card reader... and then use it with the computer.
  • 10,594 Answers
Please shut down Dell E310 computer for 10-15 minutes and boot it up again by pressing power button and now check memory card reader work.
  • Shahid Electronics
    Shahid Electronics Jan 24, 2009
    Now 2GB is reads and giving error on 4GB. Its quite possible that 4GB card is no more good or working.
    You can test 4GB card in another PC or camera etc just to make sure that Dell E310 PC is OK now.
    Yes, 4GB card is defective and can be confirmed on another computer through card reader.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Offhand, possibly a hardware fault in the reader. Most likely, dirty/misaligned prongs/contacts of the internal slot of the reader. The reader has several little prongs/contact that ouches the exposed connection points of the memory card and might require cleaning. You can try flattened cottonbuds dipped in alcohol. Alternately, you can try electronic contact cleaner (aerosol type) and spray the insides/slots. You could also use a can of compressed air fitted with the supplied narrow tube/nozzle to direct the air spray inside.
If cleaning would not resolve the issue, then a replacement maybe required.
Good luck and thank you for using FixYa.
  • Louie  Role
    Louie Role Jan 24, 2009
    Since there would be several pins/contacts, it is possible that the dirty/corroded/misaligned pins is just one or a few hence could detect presence of card but not able to read contents.
    Cheers.
I need the technical specifications
This Dell WEB site has the specification of the Dell Latitude E6410 -
http://www.dell.com/us/business/p/latitude-e6410/pd
Feb 09, 2011 | Dell Latitude E6410 Laptop Computer (Intel...
I forgot my Micro sd card password Please help me
Try to access the SD card data with the help of a card reader & take backup. Then you can format the card & install new password.
Jan 24, 2011 | SanDisk MobileMate SD Plus 5-in-1 Media...
How to formate my sd dead card
If you are using Windows, simply use file explorer to locate your SD card, then 'right click' on the mouse and select 'Format' - Ensure you format the card with the correct capacity - i.e. 1gig, 4gig etc...
Cheers.
Jul 03, 2010 | SanDisk MobileMate SD Plus 5-in-1 Media...
How do i transfer audio from sd memory card to hard drive
Hi:
You should be able to open up the SD Card in " my computer"
Once you locate the card, double click on it to open the files, then high light the music files , right click your mouse and send them to the final destination folder of your choich!
Mar 31, 2010 | SanDisk MobileMate SD Plus 5-in-1 Media...
I can't get my card reader to work on my pc
when plugging into a USB you'll hear one of two sounds
a sound from low to high or a sound from high to low
the low to high sound it that the USB is working fine
the high to low means the USB is not working , on
another note SanDisk uses a utility on everyone of its
cards a troublesome utility that is not easily worked
the older it is the less performance it will have , but ultimately the sound has to be there the sound is the
computer recognizing the plugged in device which you'll find in my computer .
Jan 14, 2010 | SanDisk MobileMate SD Plus 5-in-1 Media...
Problem with reading Sandisk 4gig hc micro sd card in my computer and laptop
I guess you put the SD adapter into the card reader right out of the box? You first may have to partition/format it after unpacking it. Under WinXP I can recommend an utility "DiskPart" which you can start from the command prompt (Run... -> cmd). For further instructions (if it sounds to you to be the problem ) contact me again.
Dec 30, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Sandisk mobile mate memory card reader wont work
I do not know if you can redirect it, but you can always go to my computer and open the drive that you memory card is in and get to your photos that way.
Hope this helps
Jun 05, 2008 | SanDisk MobileMate SD Plus 5-in-1 Media...
Sandisk multi card reader
if you are using a cord and usb port it sounds like your usb port is loose and not holding on. Try plugging it into another port maybe on the back of your computer.
Let me know if this works
Dec 14, 2007 | SanDisk MobileMate SD Plus 5-in-1 Media...
Computers & Internet Logo
153 people viewed this question
Top SanDisk Computers & Internet Experts
Brian Sullivan
Brian Sullivan
laikexpert
laikexpert
CiNi
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
