Question about Welding Tools
I need wiring diagrams for sip ideal 210 mig welder
Singal phase
5 Suggested Answers
CarlGehrke
  • 169 Answers
SOURCE: electrical problem with mig welder
Call Lincoln Electric (the manufacturer) at 216-481-8100 and ask them to email you one.
please rate my answer,
Carl
Posted on Dec 03, 2008
  • 105 Answers
SOURCE: SIP turbo 150 mig welder instructions wanted
for welding cars or similar thickness steel use it on number1 setting speed 6-7 and practise max and min should be used when you want a bit more power A gose onto number 2 and then 3 these are amp settings and are for thickness of steel to be weled your welder can weld up to 8mm of plate steel on setting 3 max i use 0.9mm gasless flux cored wire great for working out doors the wind tends to blow gas away on standard wire yours is easly converted to gasless as so was mine
Posted on Dec 15, 2009
SOURCE: I have a SIP Ideal 350 Super 3 phase mig welder
The most eco way to fix is to replace the control panel 7902/S
Posted on Jan 13, 2010
luis_david
  • 407 Answers
SOURCE: I just need to know
Hi:
Your Machine is single phase, and it could be a 208/230V or a 230/460/575V depending on the model. Check what kind of voltage do you have at your garage first, before attempting to do the following:
On a three phase wiring you will have 4 wires with the following colors; green, red, white and black. If you have 208/220/230 volts available at your garage you can connect the green, white and black wires, always green being the ground cable in the middle, black and white don't matter which side you screw them in.
Before attempting to connect a 480V to the machine check machine's plaque information in the front (or back) for real voltage, because this voltage can burn the PC board of you machine. The same color sequence applies to the 480V.
Good luck.
If this was useful to you, please vote.
Posted on Mar 21, 2011
My SIP ideal 240v mig welder keeps tripping garage and/or house power, what's wrong?
welder drawing high current.sounds like a earth problem with the house or the unit.
Aug 14, 2014 | Welding Tools
Sip ideal 240 super mig
scrap it, it will cost more then its worth
Oct 26, 2013 | Welding Tools
Wiring a welder 480v to 220
I ahve a linclon ideal arc 250 welder which is 480V 3 phase I would like to change it over to 220V single, what are the procedures.
Mar 03, 2013 | Miller Welding Tools
Sip ideal 240 super users manual
Hey Guys I'm lookin for the user manual of my (SIP Ideal 240 Super ) Mig Welder
Any one can help???
Jan 28, 2012 | Welding Tools
Will not arc
Check ground connection at welder along with your ground clamp. Bad connection could be the issue. Also check settings on your welder.
Apr 23, 2010 | Hobart Welders IronMan 210 MIG 500304A...
Hobart 210 makes an arc but the wire feed motor won't turn. used very little ,has voltage at motor,worked fine the last time i used it
hi,
maybe you haven't got the wire speed control turned up probly not the answer but sometimes its the simply things.
Mar 02, 2010 | Hobart Welders IronMan 210 MIG 500304A...
Nov 02, 2009 | Welding Tools
Welding Tools Logo
112 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
