Question about Kenmore Dryers
ON KENMORE LAUNDRY CENTER 3979332A. Washer Lid switch
In order to get access to the switch does the top of the washer just pry off the plastic clips with a big screwdriver?
  • 156 Answers
SOURCE: Kenmore Laundry Center #417.90802990
unplug it drop the panel between easher dryer remove the metal panel behind it remove 2 screws each side controls panel reomve control panel unplug the switch going to dryer door let panel hang down remove 2 screws bottom door panel one each side remove 4 screws on the top front panel with door will fall in your hands oyt seals on it let dry
Posted on Feb 28, 2008
jsrock516
  • 5911 Answers
SOURCE: How do I get top lid off of Kenmore washer model 110.25852400.
The following link will explain:
http://www.fixya.com/support/r385198-replacing_lid_switch
I hope this helps you. If you require additional assistance, please let me know.
Posted on Jan 06, 2009
jumptrout51
  • 3361 Answers
SOURCE: need to gain access to inside of 90 series kenmore washer
http://www.youtube.com/watch?v=WLPGs2UMUJc
This will show you how to get to it.
Posted on Mar 19, 2009
jsrock516
  • 5911 Answers
SOURCE: I have a kenmore 90 super capacity top load washer
You can check your transmission if you like, but I think your problem is your lid switch. A washer that fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch malfunction. You should not have to hold the switch closed with a screwdriver to get it to work. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price. If you have questions, or my advice does not match your symptoms, please let me know. I hope this helps you.
Posted on Jul 08, 2009
canbruce75
  • 1776 Answers
SOURCE: lid switch on a 20802 kenmore washer
Check the video at the following link and see if it is of assistance to you in changing out the lid switch. Sure hope so and best wishes.
http://www.youtube.com/watch?v=fC8SY3cU1Yc&feature=PlayList&p=A8EAB62928245279&playnext=1&playnext_from=PL&index=61
Posted on Sep 25, 2009
How to remove washer top for broken lid switch access
if it is a top loader,,,remove the screws in each end of the control panel,,,some units you have to remove the end caps to access the screws,,,then pull slightly forward on the panel and flip it back it is on hinges,,,,then remove the 2 clips that hold the back to the base,,,unplug the lid switch,,then open the lid and grab the inner lid section and pull the rear of the base towards you slightly and lift off the base,,,, then you can access the lid switch and replace it ,,,,
Apr 29, 2010 | Washing Machines
How to remove top of kenmore oasis washer to replace lid lock mechanism
Disconnect your Kenmore Oasis washing machine from its power source. Make sure that your washer is unplugged before beginning to disassemble it.
Remove the screws that hold the control console to the top of your Oasis washer. In some Kenmore Oasis models, the two screws may be covered by plastic end caps. After removing the screws, set them aside until you are ready to replace them.
Flip the console up, back and out of the way.
Locate the cabinet clips on the top of your Kenmore Oasis washer. These clips are located toward the back of the washer top and would be hidden by the console if it were not currently flipped up.
5
Slide your screwdriver underneath the metal cabinet clips. Wiggle the screwdriver back and forth to gently pry the cabinet clips free.
6
Disconnect the group of colored wires that plug into the top of the washer from the control console. These wires control the lid switch on your Kenmore washing machine. To disconnect, grasp the white plastic clip and pull gently.
7
Remove the washing machine cabinet. Tilt the cabinet towards you, and then lift the entire cabinet up and off of its platform.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 18, 2010 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
Clothing is stuck in the tub of my kenmore washer
5
6
7
Sep 19, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Need to disassemble a kenmore elite oasis dryer
5
6
7
Aug 03, 2009 | Kenmore Elite Oasis ST 6806 Electric Dryer
Removing the top of a Kenmore Elite Oasis Washer to replace hose
5
6
7
May 17, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
The bleach dispenser does not work, and the top will not lift so
5
6
7
Once accessed - look at the bleach tray and actuator assembly.
Apr 08, 2009 | Kenmore Oasis HE 27082 Top Load Washer
I have a Kenmore Oasis HE 27082 and the lid lock bolt broke. How can I replace it?
5
6
7
You can access the lid switch at this point.
Mar 22, 2009 | Kenmore Washing Machines
Kenmore model number 82870120
put the machine on spin and turn on. If you hear the motor it is a part called a coupler if it is completely dead it is the lid switch. to gain access into this machine look for 2 phillips head screwson the lower front or back side of the control panel. some models have plastic covers that pop off on each side covering these screws. after removing these the control panel flips up and you will see 2 brass clips on each side that you will pop of with a flathead screwdriver. now unplug the lid switch wires and the entire shell of the machine will lift off. now you have easy access to the lid switch and down at the bottom you will see the pump for the washer. remove the 2 metal clips and the pump slides off. check it as they are prone to leaking. now you will see 2 more clips securing the motor some also have screws in the clips but anyway remove these and the motor slides out. the coupler consists of two plastic hubs with 3 prongs sticking out one on the motor and one on the transmission with a rubber disk connecting the 2 together. this part has been redesigned 4 times the latest one has teardrop shaped prongs and a metal sleeve insert where they attach to the motor and tranny
Jan 31, 2009 | Kenmore 23822 Top Load Washer
My kenmore elite oasis will not power up and I would like to know how to access the diagnostic mode
5
6
7
Jan 10, 2009 | Kenmore Oasis 27042 Top Load Washer
Replace a lid switch
To access the lid switch:
1.Remove the trim on either side by prying off from the top. Grasp the trim at the top and pull forward to expose to expose a screw.
2. You will find a lid switch connector (white in color). Unplug the switch from the connector.
3. There will be two brass colored clips. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver down and away from you and the clip will release.
4. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Tilt and slide cabinet forward to remove.
If you need further assistance, let me know
Regards,
reg501
The FixYa Team
Jun 24, 2008 | Kenmore 22422 Top Load Washer
Dryers Logo
65 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
