Question about Kitchen Ranges
No instruction for using knobs on stove how to use dual knobs never had one be fore and no manal how do i get information on this
Can i down load this info and from where/?
    Filmmaker:
    Uploaded 5 video answers.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 30 Answers
What is the make/model? Try a search of google for your exact make.
Try typing in (your model) user manual. I just typed in rangmaster classic 10 user manual and got the following results on this page:
http://kitchen.manualsonline.com/manuals/mfg/rangemaster/rangemaster_product_list.html
Posted on Jan 15, 2013
The stove surface unit does not heat properly as I turn the knob
The resistance in the switches could be at fault.
Jun 23, 2015 | Kitchen Ranges
Control knob doesnt adjust flame height?
Use a manometer to insure lp gas pressure is correct. The regulator for the stove may need adjusting. The air mixture adjustment may not be correct for PL as well.
Aug 18, 2014 | DCS Professional RDU305N 30" Pro-Style...
I have KitcheAid KERS 807, electric stove/oven range. Left lower part of ceramic stove top that has single/dual heater sizes is malfunctioning. Single one is still working but from recent dual does not.I...
Either the knob has gone out or the burner element. I would test the knob first to see if there is current when turned to the large zone. If the knob is working, next would be to test the burner to see if the outer ring has burned out. I would guess more likely the control has gone out. Burners have less failure (typically).
Apr 14, 2014 | KitchenAid KERS807SSS Electric Kitchen...
30 yer old caloric stove wher light pilot
http://www.partselect.com/Caloric-Stove-Parts.htm
Jan 04, 2014 | Kitchen Ranges
My oven wont turn off from the knob it keeps turning
You didn't say whether you have a gas or electric oven, or oven & stove. I'll assume you have a stove, just to cover all bases.
First, you should shut down the oven: a gas stove will have a valve on the gas line behind the stove. The valve will either have a red handle or a flat stem that usually has a hole in it. Turn either valve 1/4 turn to shut off gas, use a wrench on the flat stem. An electric stove should be shut off by flipping off the double circuit breaker for it in your electric panel. Do not unplug an electric stove when it is on; this can damage the plug &/or electrocute you.
Most likely the inside of the knob has stripped out. Look at the knob for a hole that has a setscrew in it: a small allen wrench or screwdriver will loosen the setscrew, most knobs don't have them and will pull off. Be careful to use even pressure on two sides of the knob; if you can't pull it off, use two butter knives or flat screw drivers to pry it up enough to get a grip on it.
Look at the center stem on the back of the knob, it will likely be cracked or stripped. Some stems have a D-shaped metal insert that strips out inside the plastic stem. If you have one, pull off a burner knob and compare the stems in the back, if they are the same size, put the burner knob on the shaft for the oven control, and use that knob to turn the oven control off.
If the burner knob won't fit, use your fingers or a pair of pliers (gently) to turn off the oven control shaft. If the shaft stops normally, you can turn the stove back on using either the gas valve or the circuit breaker. If you have a gas stove that doesn't have electric ignition (a clicking noise when you turn on a burner) you may need to re-light the pilots for the burners. Lift the covers off the burners to re-light the pilots.
If you have succeeded in turning off the oven, you need a new knob -- you can get one at an appliance parts store or maybe a hardware store. If the oven control did not turn off normally, I would leave the oven/stove turned off: the control itself will need to be replaced by a qualified repair person.
Mar 03, 2013 | Ovens
I need an instruction manual for QD250T gas stove. Where can I get one?
google the make and model you may find a manal or look on fixya they do some on line
Aug 11, 2010 | Procom QL300TYLA Heater
Stoves richmond 1000df - no instructions for which knob operates which oven - dont know how to use slow oven
The book that came with the cooker only explains the symbols on the knobs not which knob to use with what cooker. It is very confusing. Does anyone know where I can get something more comprehensive?
May 14, 2010 | Stoves Richmond RM1000DF Dual Fuel...
I need to reset the clock for summertime but cant! Stoves rangemaster
push the button on the front of the stove that says "clock" and then turn the dial (same one you use for timer and oven temp) till you get the time you want, then LEAVE IT ALONE and it will set itself. Don't touch anything once you have the time set with the knob.
Mar 31, 2010 | Rangemaster Toledo 90 (Dual Fuel) Dual...
Frigidaire FGF378AC Gas Stove
There are 2 possibilities:
1) Are there 2 knobs to control the oven? If so, they may be switched.
2) Depending on the thermostat used, it may be possible to put the knob on upside down.
Jan 22, 2008 | Frigidaire FGF378AC Gas Kitchen Range
Kitchen Ranges Logo
42 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
