Question about Measuring Tools & Sensors
Does the 2008 toyota fielder use a MAP or MAF sensor and where is this sensor located?
Need to remove the sensor so that I can use AMSOIL Power foam to clean air intake...
SOURCE: Cold Air Intake - Mass Air Flow Sensor Adapter
i have a 91 mx6. the intake is all cattywompus and im just goin to take a piece of metal and tube and cut a hole in the peice of metal and weld the tube to it take my stupid box out and run that pipe staight to a coupling and then to the cone air filter. BAM!!!! problem fixed... i maight be able to fix yours too... e-mail me ajjordan64@hotmail.com. k?
Posted on Apr 16, 2009
  • 218 Answers
SOURCE: 98 Sentra IAT Sensor Location
IT IS ON THE HOSE THAT BRINGS AIR INTO THE AIR FILTER HOUSING
Posted on May 13, 2009
  • 599 Answers
SOURCE: MAF sensor and injectors
the mass air flow sensor is located between the air filter housing and the air inlet to the intake manifold, remove the two band clamps holding the maf sensor, clean when cold with CRC mass air flow sensor,remember to take off the three wire plug to the maf sensor,get back to me if you need more help,please rate my fix as i strive to be the best,problems,get back to me
Posted on May 14, 2009
pippall
  • 1486 Answers
SOURCE: 2000 kia sportage mass air flow sensor
The mass air flow meter is fitted to the air intake pipe Its quite a simple task to change it on your own.Has for the catalytic converter all you will have to do is give the car a realy hard reving when going through the gears and drive it hard for a few miles.That will clear your cat for you.Dont listen to the shop they are out to rip you off.Good luck.Any problems you can contact me via pippall7@hotmail.co.uk.
Posted on Jul 18, 2009
  • 134 Answers
SOURCE: my 2004 toyota tacoma has
Yes your truck is equipped with a mass airflow sensor (MAF). However, I would not just replace that because its running rough. I would begin diagnostics by first checking to see if there were any trouble codes in the engine to give you a clue as to the rough running condition. I would expect a trouble code to be present to support the descision to replace the MAF Sensor. If no codes are present I would suggest that you get the vehicle tuned up. (Spark plug replacement and throttle body cleaning and I would also suggest removing the idle control valve and cleaning the carbon and dirt out of it. Although what you were told might be correct I dont belive that is where I would start.
Posted on Feb 18, 2011
Where is iat sensor located on 2006 tpyota tacoma 4,ol ?
Intake Air Temperature (IAT) sensor and Manifold Absolute Pressure (MAP) sensor are combined into a single assembly which is called Mass Air Flow (MAF) sensor. This MAF sensor is located on the air filter box near air filter hose, and is connected with a five wire connector. You cannot replace the IAT sensor alone. Instead a MAF sensor is replaced altogether.
Thank you for visiting Fixya.
Apr 14, 2015 | 2006 Toyota Tacoma
Does toyota fielder need map to reset radio
what it is asking for is the anti-theft code that cut in when the battery was disconnected
Feb 28, 2015 | 2001 Toyota Corolla Fielder
Where is the map sensor k
double posted, and there is not one.
NO, and NO.
lets do this 1 more time.
no symptoms even hinted at , how can we help like that>???
example, EGR is failing, ok EGR-MAP bad or dirty. or 10 ways, ask.
example2 weak engine power, ok MAF is bad. or 50 reason ask.
easy huh?
http://www.fixkick.com/sensors/92-95MAF/92-95-MAF-testing.html
Jul 29, 2014 | 1998 Suzuki Sidekick
C1201engine codes
remove and clean both of your O2 sensors, i recommend http://www.amsoil.com/shop/by-product/other-products/cleaners-and-protectants/power-foam/?code=APFSC-EA
or any equvlilant carbon cleaner. re-install and clear codes, if problem goes away, it will most likely be something wrong in your intake side
Dec 25, 2013 | 2004 Toyota 4Runner SR5
Map sensor location
Located on top cylinder on transmission side.The MAP sensor is located either directly on the intake manifold or it is mounted high in the engine compartment and connected to the intake manifold
Check out related help links to MAP sensor and its problems:----
Click the link below:-----
MAF, IAT, MAP and Coolant Level Sensor problem all together on Mazda MPV? http://schematicsdiagram.blogspot.com/2011/12/maf-iat-map-and-coolant-level-sensor.html
Oldsmobile Manifold Absolute Pressure (MAP) Sensor...
How to test MAP sensor?
Working of Manifold Absolute Pressure (MAP) Sensor...
--------------These will help.Thanks.
Nov 23, 2012 | Cars & Trucks
Where is the MAF sensor located on a Toyota Landcruiser 2006 ? Cannot find it please help ...
This year and model 4.7 V8 doesn't use a MAF (mass airflow) sensor, it has what is called a MAP (manifold absolute pressure) sensor, it provides similar air flow info to the computer but works on vacuum sensed in the intake and is known as a "speed density" system of sensing. It appears it is located on the firewall of the engine and has a 7/32" vacuum hose from the engine going to it. See picture below.
Feb 24, 2012 | 2006 Toyota Land Cruiser
92 corolla with VAF code 31 acts like MAF sensor is bad; car bogs when accelerated, stalls cold. But there is no MAF-I confirmed this with the dealer. What is malfunctioning?
Your corolla doesn't use a MAF sensor, it uses a MAP sensor
The map sensor is located on the Intake Manifold right by the throttle body. That could easily be causing the issue you're stating.
Mar 01, 2011 | 1992 Toyota Corolla
My 2004 toyota tacoma has a rough idling problems and I was told to replace MAP sensor. Now, would it be Mass air flow sensor ? Because I can not locate any info on MAP sensor of this yeat truck
Feb 18, 2011 | 2004 Toyota Tacoma
I have a 2008 grand prix gxp v8 and i was driving and it stalls on the highway with engine light coming on and car shutting off. The code are map, maf, sensor! car starts and stalls out right away u can...
Hi, you can try cleaning the MAF sensor, but you probably need a new one. Fortunately you can get one for only $70 at autozone. This is cheap compared to other MAF sensors I've seen.
First check the connection on the sensor. If good, remove the sensor and spray thru the mesh with electric parts cleaner. Reinstall and see if it's any better. If not, replace the sensor.
Not sure if the MAP sensor is bad or not. Can you tell us the exact codes you got, as there are several different ones for each sensor?
MAF sensor:
Jan 11, 2011 | 2000 Pontiac Grand Prix
Is there a MAF on a 1998 Toyota Camry?
The 4 cylinder Camry uses a MAP sensor or Manifold Air Pressure sensor instead of a air mass flow sensor which is in the 6 cylinder model. It is located just under the top of the hood in the center of the bay closest to the windscreen.
The computer is programmed to meter fuel and spark timing from manifold absolute pressure (MAP), engine temperature, air temperature, and throttle position only.
Nov 24, 2009 | 1998 Toyota Camry
Measuring Tools & Sensors Logo
620 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
