Question about Hotpoint WMA66 Front Load Washer
Not taking in water
Ive recently changed the drum, done something somewhere but cant track it down!
Wont take water in, although runs through programme and spins ok.
  • paul_paula12 Jan 24, 2009
    thanks, just checked but still no water! after pressing start you hear a click then nothing....then the drum starts.
    Its the Hotpoint ultima extra wma66.
    Thanks for your help
  • 640 Answers
Go back to water vavle and start form there ,,is it humming..verifie water in fill hoses,,check and make sure you have hoses on dispencer correctly,,if removed,,,check and make sure you did not twist or kink hose entering tub...make sure connection are on the water valve..onthejob
Posted on Jan 24, 2009
  • onthethejob1
    onthethejob1 Jan 24, 2009
    but if its not working,,im still here,,please send hole model number so i can take a look at schematic..onthejob
  • onthethejob1
    p and p can you give me the model # right off unit there are no more numbers or letters,,this wma66 wont run...
I recently bought a new rv with a samsung rf217 frig. How do I winterize it? Product lit not clear.
You do not need to do anything to the refrigerator. Just make sure it is wiped down and dry before you close it. What you need to do for winterizing is drain all of the water out of the tanks, water heater and lines. After that is done then pour RV antifreeze into your fresh water tank and pump it through all of your faucets. Once you see the pink color come out then you have it through the lines. You should have what is called a bypass valve for your water heater so you don't have to fill it completely with antifreeze. Next is to take out your battery and store it in your basement or somewhere it wont freeze. Do not put it directly on the ground. Put cardboard or something under it.
Nov 11, 2014 | Samsung RF217ABPN Bottom Freezer French...
Indesit wie 147 washing machine wont empty water it dose every think else but it got stuck and had an error of 5 with water stuck in drain some as looking at the preasure pipe blew down the pipe an no...
It really does sound like you have a blockage somewhere even if you cant feel it. You may need to remove the pump and the pipes to be certain. Try laying the drain pipe on floor level. If it drains then there is definately something in there that needs to be removed. Let me know if you need any more help.
Oct 20, 2011 | Indesit W 123 Front Load Washer
My dryer wont start. When i turn the button to start it, it hums but wont run.
something is jamming the drum of the dryer from turning... remove the casing and take a closer look. There may also have been something recently dried which may have come out and jammed the dryer drum. Try hand turning the dryer drum to see... it should freely revolve at least a little bit
Good luck with it
Ck
Feb 13, 2011 | GE DVL223EBWW Electric Dryer
Respected sir i am having docu color 3535. the working condition is excellent. recently I faced a problem "change the drum unit". are there any possibilities to reset the drum counter. with...
Although you can not reset the counter by any buttons. You can replace the chip on the cartridge at a far less price.
Google a business called "the parts drop".
I have done business with them for years. Give them a call, ask for Britt, they will have what you need. They are simply the best people to deal with for Xerox parts. Courteous and honest.
Cant ask for more.
The chip is easy to replace.
Nov 12, 2010 | Xerox DocuColor 3535 Copier
1999 f 50 v8 vehicle will be running fine turn it off wont start
Hi there, I suspect the starter. Something is loosing its connection when it gets hot (expands). Best thing to do is buy a Haynes or Clinton's repair shop manual at your local AP store for your particular vehicle. Then read up on it in the trouble shooting section or the step by step RR section. You can purchase these at your local Auto Parts store or buy them on line at ebay burdfrenzy
Oct 17, 2009 | 1999 Ford F150 Regular Cab
MPEG 4 music wont play??
You will most likely have to convert them to regular mp3 or burn the tracks off the cd again into mp3 format. Try right clicking on a track and go to something that should say convert to, and click on it and select mp3.
Feb 07, 2009 | Battery Technology Audio Players &...
Reason as a sound module with the 8800
I have a boss 1600 and ive used it in the way that sounds similar to you situation.It sounds like you have overdubbed track 1 to next track.If you dont want to hear track 1 while rec. track 2 turn fader down, unless you have already recorded or overdubbed 1 to 2.You should be able to hear track 1 unless you turn fader down or cancel tracksound for the time being.track 1 swhould be heard but it wont be re-recorded youll only hear it unless you turn fader down.Thats how mine works anyway.It lets you hear it if you want but wont record until you song save or during bounce nd mixdown.Then you select the tracks and or the virtual track you want to use.Id try to undo or stat again and read about the overdubb in manual.Im sure youll figure it out.I cant hardly imagine what all that 8800 has and is capable of doing.But ive seen one and i think the midi devices work alot alike.Hope you get it.Praisehim316.
Oct 10, 2008 | Roland Mv8800 Production Studio
Cant get the paper jam paper to turn off and work again
1- either there is something stuck on the sensor or
2- the sensor is bad or out of place
Aug 19, 2008 | Sharp AL 800 Copier
Works sporadically
Sounds like your head unit is on it's way out, you could try cleaning the contacts of the face plate plate with rubbing alchol and a q-tip. Make sure you get both sets of contacts, the face and radio.Because the display is working it's definatly not a power problem, clean those contacts and if still doesn't work invest in a new radio, sorry to bear bad news if it's not the contacts. L8R
Sep 18, 2007 | Alpine CDA-7894 CD Player
Hotpoint WMA66 Front Load Washer Logo
67 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
