Question about Caterpillar 3516 DITA Generator Set - 4160V
How to find out if your on intake strok
Need to know how to determan wither we are on intake strok
    Prodigy:
    An expert who has answered 500 questions.
  • Caterpillar Expert
  • 573 Answers
Not sure of what you mean intake stroke? you can crack fuel line to cylinder 1 and rotate engine manually until you see fuel point of delivery. That should line up with mark on flywheel.
Posted on Nov 17, 2013
What is the wiring diagram for a tonaro 6v 250w65x23.4
use a test light the power lead will light up the neg. one won't.
Sep 12, 2014 | Cars & Trucks
Mercury outboard
are you sure the water pump is workiing
Jul 01, 2014 | Boating
Changed cap and rotor put in new coil but it just turns over and won't start
First you need to determan if you are getting spark, take the coil wire off, ether end...hold it close with a good insulated pear of pliers, to were you removed it from, with out plugging it in, now have someone crank the engine a few times to see if it is sparking. If it is not, you need to dig deeper into the electrical parts like distributor pickup , brain ect....If you have spark...now you need to check to see if you have fuel...disconnect the fuel line and hold a rag over it so you don't get splashed, again have someone crank the motor a few time to determan if you have fuel....if not, you need to check for glogged fuel filter, fuel pump relay or maybe fuel pump it self....
This should get you going in the right direction.....
May 26, 2011 | GMC Safari Cars & Trucks
Is this 2 strok or 4 strok engine? Thanks beky
If this is a chainsaw then it is a two stroke.
Mar 12, 2011 | Garden
What is four strok engine ? with working
You would like to know how a four stroke engine works.
There is a good write up on wikipedia here
http://en.wikipedia.org/wiki/Four-stroke_engine
or here
http://www.compgoparts.com/TechnicalResources/FourStrokeEngineBasics.asp
Please dont forget to vote this answer was helpful.
Many thanks
Mar 04, 2011 | Nokia Lands Phones
Need to know how determan what to do to get the gas gauge to work. replaced sending unit, computer, and put in new cluster. where is the problem?????
Sending unit you mean Fuel Pump? if so I would check float on fuel pump. don't know what you drive, year and model would help.
Sep 03, 2010 | Dodge Ram 1500 Cars & Trucks
Excessive smoke
sounds like fuel mix is to lean, try another oil, and only use freshly mixed, the gas tears down the oil after even a few days, or as 2 stroks are know for it may be time to rebuild the top end.
Dec 27, 2009 | 2004 Yamaha YZ 250 F
We have a 1967 2 strok mercury 65 outboard motor. wont start cold
Wow.It sounds like some people I know.Late starters.Don,t get out of bed 'till 10 am.With all you have written, a check on the operation of the choke (cold start) would be worth looking at.As you crank the motor,squeeze the fuel bulb at the same time and see if that also may help.Hope this helps
Aug 29, 2009 | Sport & Outdoor - Others
The Dirt Devil 085850 doesn't pick up anything!
the intake hose is clogged thats the clear looking hose that comes up from the bottom on the back side.you will need a coat hanger wither the end bent so its rounded.on the back where you sere the clear hose it conects to a fitting that is held in by one or 2 screws take them out and work the coat hanger down through the intake hose.you should be able to push the clog out through the bottom
Dec 04, 2008 | Dirt Devil Featherlight Bagless Upright...
Caterpillar 3516 DITA Generator Set - 4160V Logo
75 people viewed this question
Top Caterpillar Electrical Supplies Experts
Lawrence Oravetz
Todd Arndt
Todd Arndt
Ted Maxwell
Are you a Caterpillar Electrical Supply Expert? Answer questions, earn points and help others
