Question about Whirlpool AWZ410 Front Load Washer/Dryer
Digi display flashes but does not display time
The digital screen then goes blank and the machine will not start.
  • 640 Answers
Defective control board....onthejob
Posted on Jan 24, 2009
How do I set digital watch of UL1159
press MODE button 3 times on left screen DAY will flash press RESET MINUTE will flash, change minute what you want by pressing START.
press again RESET button HOUR will flash press START to change hour.
Press again RESET button DATE will flash change same way.
press again RESET button MONTH will flash change same way.
press again RESET button DAY will flash change same way.
After done press MODE to bring back normal time position.
Changing ALARM ....
press 2 times MODE button. Alarm HOUR will flash press START to set alarm hour.
Press again RESET button Alarm MINUTE will flash press START to change.
After done press MODE to bring back normal position.
SO YOUR TIME & ALARM GET SET. images?q=tbn:and9gctqfaospxemzn5ytb2yvmxsagwhcrw-zhdezmqvoulno244gvhvkgaae8w
Oct 04, 2014 | Kenneth Cole Unlisted Ana-Digi watch
94 deville concours ac works sometimes then u here duct door close and digital climate temp numbers go to blank dashes and defrost comes on and is stuck wont turn off then digital numbers come back on
My first guess would be a wiring problem or the controller.
If anything goes wrong with the system, it will default to the defrost mode for safety.
Jul 10, 2012 | Cadillac Cars & Trucks
I have Nokia 3110c. When I switch it on, NOKIA logo comes, screen flashes 3 times with white blank screen and goes off. It never comes again. It happens every time I press power on button. There is no...
Possible that the software of the phone is corrupt or a possible hardware is defective.
You can remove the battery and memory card, have the card scanned for virus. replace battery after 15 minutes so that the phone is reset.
if the phone wont boot back the services of the Nokia support must be sought for reinstalling the software.
Oct 23, 2010 | Nokia 3110 Cellular Phone
How do you set up digi box with VHS recorderand Tv. Digi box has two scart leads
Take one scart from the digi-box & connect the other end to the TV, & the second scart on the digi-box can connect to the VCR. To record from the digi-box, the VCR must be set to the AUX input (or AV ). The TV will also be set to the AV input, this set up will let you watch digital channels & to record a digital source. Be aware depending on your type of digi-box, you may not be able to record & watch two different digital channels at the same time.
Oct 14, 2009 | Electronics - Others
Cant se time Citizen 8988-q02047 HSB wristwatch
In the time mode, press the upper right button for 2 seconds and the time display will flash. Then press the same button untill the entire time will flash, or both hour and minutes flash at same time. When the hour and minutes flash at same time, this adjust mode is the adjusting of the analog left display (A1). Now, press the lower button for adjusting de hour shown at the digital display that shows the same hour at analog display. This method is to adjusting the 8982 that is the "father" of 8988. Like a Citizen collector, and don´t know any website that you can view the setting instruction of 8988, only the 8982 is disposable here: http://www.citizenwatch.com/downloads/techguides/8982.pdf
Nov 20, 2008 | Citizen Watches
Screen does not display
I had the same problem. more than likely your connector cable between the camera and the display has become brittle over time and is beginning to break. as you open the screen the small wires inside the cable are separating. mine went from 30 deg view to 90 deg no display as yours is now, then 30 deg fuzzy display (cant make out the picture like a VHS when it needs heads cleaned) then the cable gave in and snapped. all the way through. Simply not a lasting camera. I got quotes and it was about $200 to fix. for that price these days u will pick up a better camera anyway. Good luck
Nov 19, 2008 | Panasonic NV-DS60 Mini DV Digital...
Screen goes blank after clicking a picture
This is the normal cycle time and it can increase if the batteries are a bit weak. This is one of the minor issues with this camera. You should only notice this when using a flash since it has to re-charge the flash circuit, without flash the picture should retuen in a second or less.
Sep 16, 2008 | Canon PowerShot A620 Digital Camera
Bosch Axxis problem
Thought these additional details might help as we are having a similar problem.
When the washer is turned on we get a blank screen, then after a bit we see the display flash. After sometime flashing then we see it go to normal and we can run it. It is as almost as if it need to warm up...
We can get the display to show faster, by playing with the knob. However, the machine still needs time before we can use it.
Any ideas?
Thanks in advance.
May 04, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Doesnt work
h4 - is a heater lamp error - fuser is not heating up - machine needs the fuser repaired before you can use it, it has probally got a blown heat lamp, could be thermister or thermal fuse but usally on these it isn't. If you a teco happy and 240v comfortable then remove fuser and check lamp and components for open circuit, if you do not know what you are dealing with then dont try.... call a tec, this area runs live 240v
now this is under AL-1641CS but you are saying also  Digi A161
so I'll give you both resets use at own risk do not put in any other number but 14, damage will result, but this code I doubt will help you untill original problem is fixed, oyur machine will reset but error again also.
CLEAR - EXPOSURE SELECT- CLEAR - EXPOSURE SELECT really fast like 2 secs, display should blank then 14 start
or Press: "Clear", "Interupt", "0", "Interupt", "14", "Start Key"
Oct 30, 2007 | Sharp AL-1641CS Laser Digital Copier
Whirlpool AWZ410 Front Load Washer/Dryer Logo
Dan Webster
Dan Webster
Sal DeAngelo
