Question about Fedders X Chassis A6X08F2A Air Conditioner
Window unit air conditioner leaking water inside home
My Fedders 8000 BTU window air conditioner is leaking water into my home. I cannot take the front off. Must I remove the unit and take off the entire housing from the back? I am partially disabled so this is not a good option. I have misplaced the manual, can I get a replacement? NC is really hot and humid this year and due to healh conditions I need this unit quickly.
  • Mary Brabble Jul 12, 2007
    I finally WORKED the front housing off, this wa quit hard to do butr it will come off after removing the two screws. I cleaned it all out and made a pathway for the water to drain. I then tipped it a few degrees to the back and reset everything. Now it is draining out the back as it should. I never found the drain pipe though. It works great now and it cools better even at a higher setting. Go figure. Thanks for your help. mb
  • Anonymous Jul 06, 2008
    I have a Fedders ASBO8F2A that was in our house when we bought it and it leaks, has no drain, I don't know what to do, I'll tilt it back more I guess.
Well it might not be tipped at a angle so the water comes to the front tip it back some
Posted on Jul 10, 2007
Hi, I had the same problem see http://homefixfree.com/index.html
they were the big help!
Posted on Apr 14, 2008
SOURCE:
How many BTU's is Fedders model A6Q08F2A?
It is an 8000 BTU, I have one myself. The model A6Q08F2A
The Fedders A6Q10F2A, is a 10,000 BTU
Jun 09, 2014 | Fedders Q Chassis A6Q10F2A Air Conditioner
Water is leaking in front
Tip the air condition back so water drains outside window.
Jul 14, 2013 | Haier Esa408k-l Window Air Conditioner...
Wall unit is leaking water
Hello, if this is a window unit water will leak for one of two reasons, either a blocked drain or the unit is not tilted back enough in the window.
Jul 01, 2012 | Fedders A3X05F2A Air Conditioner
My 8000 BTU LG window AC is dripping on the inside of my house
Check that the hole in the back is not plugged where the water should be running out...also make sure that it is tipped slightly back towards the outside...
heatman101
Jun 11, 2011 | LG Electronic Window Air Conditioner
Freezing up 8000 btu window unit
Coils may be dirty, filter may be dirty, water not draining or low on freon.
Jul 25, 2010 | Whirlpool Electronic Window Air...
Fuse
I am unawhere on any fuse on a window unit.Trying your breaker in the inside electric box..It may be tripped because you over loaded the ac unit.
May 27, 2010 | Fedders AED24E7F Wall/Window Air...
Fedders air conditioner 5200 btu manual ..i just need to know the angle that the unit needs to be on in the window
As rule of thumb the outside part should be lower than the inside part. You know that the angle is right when the water in the drain pan does not go toward the room but towards the drain itself.
I hope it helps.
Jun 26, 2009 | Heating & Cooling
Noise
Adding cloth or any other sound absorbing material will not work. There is not enough room to add anything appreciable in the fan area.
Jul 22, 2008 | Frigidaire FAC107P1A Wall/Window Air...
Fedders X Chassis A6X08F2A Air Conditioner Logo
1,042 people viewed this question
Top Fedders Heating & Cooling Experts
Felizardo Erilla
Felizardo Erilla
Donni Steen
Ekse
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
