Power and protect light keep flashing back and forth need answer I've check every connection but maybe I missed something !
    Genius:
  • 1,669 Answers
Did you check the polarity as well as the connectors?
Posted on Jan 16, 2013
My vizio xvt3d554sv led light flashes repeatedly from the orange to the white back and forth and doesnt light up
If your able check the power supply voltages and see if they are normal, I think you will find some are missing, if that is the case change the power supply
Nov 13, 2017 | Vizio Televison & Video
I have a 1990 tw 200 yamaha turn signals in front are lit but dont flash the back dont light up or flash
Check the grounds on your 22 year old bike. The flasher works because of heat building up in a bi-metal strip in the flasher. It gets hot, breaks connection; it cools, makes connection, repeat. If the rear lights are NOT coming on, you are not drawing enough power to heat the bi-metal strip thus it is not heating or cooling, making and breaking connection, not flashing. Check ALL ground connections from your rear signal lamp back to the negative terminal on the battery. Dont miss one connection - lamp to lamp holder, lamp holder to fixture housing, housing to fender, fender to frame, frame to battery (minus side) and so forth. Corrosion is not your friend here - if you find it - clean it. I believe you will find that if you put a wire from the housing to the battery negative terminal, your light will come on. If it doesn't, check the hot side of the circuit.
Oh, by the way, your battery is in tip top condition, right?
Thanks for your interest in FixYa.com
Dec 02, 2012 | Motorcycles
The two coffe option lights keep flashing back and forth and the machine will not start
plug out the power cord from the wall outlet then plug in back after 4 hrs probably it want to reset.if this does not work then you will have to get it repaired.the problem is the ic or the transistor that control the heating of the coffee maker.good luck.maybe you will need to invest in a new coffee maker.
Sep 25, 2011 | Nespresso Le Cube
What do i do if all the lights on the printer keep flashing even after i turn it off it just turns itself back on and all the lights keep flashing
check the printer the one that connected to the cartidge the soft like that back and forth check the pines if it is okey..sometimes that the cause of the printer why it stops and blink.
Sep 19, 2011 | HP Photosmart C5280 Printer
We lost power for a few hours .The cable company ( charter ) had to reboot the modem to reestablish the internet connection. Since then I cannot get the Cisco router to work.. I've done all the plug,...
1. if the power went out and then back on it is possibly due to a "power surge" and it possibly damaged the power supply to the Cisco router and or to the router itself.
2. check the routers power supply and replacement is needed if the router was not plugged into a surge protected socket.
Jul 15, 2011 | Computers & Internet
LG projection screen television model 62DC1D-AB switches on then keep switching off and the symbol looks like a flashing light globe what does this mean
Your LG HDTV is in protect mode that why you can see light .To protect further damage of some component parts.There is something internal problem inside maybe there is a shorted or leak capacitor in power supply section.
Regards:
votit
Feb 03, 2011 | LG DU-62SY20D 62" Rear Projection HDTV
My phoenix gold x200.4 amp turns on but the protect light keep on flashing
  • What does it mean when the LEDs flash on my amplifier?
    With most recently produced Phoenix Gold amplifiers, a flashing/blinking LED is an indication that the unit is in protect mode, usually due to an overcurrent condition caused by an internal short, external short (speakers), or low impedance. Overheating will also cause the amplifier to shut down temporarily.
    If amplifier remains in protect mode, power down the amplifier, disconnect the speakers, and power up again. If LEDs continue to flash, there is probably an internal problem with the amplifier that will require service attention to fix.
  • Sep 23, 2010 | Phoenix Gold ZX600ti Car Audio Amplifier
    Red protection light
    make sure amp is not grounded out or shorted out like if u miss and touch ground to power or the other way around protect light usaully comes on be resets once u turn the amp power off then back on . if that don't fix it maybe ur amp needs some repairs inside.
    Jun 06, 2010 | Planet Audio VX4002 Car Audio Amplifier
    Sony Wega 42" LCD HDTV
    I've been trying to find th thermal fuse on a 42we655 for like 3 weeks...It's not under the lamp...Any one know where it is?
    Thanks
    Aug 31, 2007 | Sony Grand WEGA KDF-42WE655 42" Rear...
    Problems with Infinity Amp 611A
    are you running a large ground wire directly to the battery negative terminal?
    Jun 03, 2007 | Infinity Reference 611a Car Audio...
    Computers & Internet Logo
    44 people viewed this question
    David Payne
    David Payne
