Question about Jandy Lite 2 Natural Gas Pilot Light Heater
We have a jandy Lite2, when turning on, you hear the igniter firing, and seconds later everything stops and the pool is not being heated!!
  • 372 Answers
Does the heater fire up at all? If the igniter is ticking that means that it is trying to fire. The problem can be as simple as a clogged pilot orifice. Otherwise the gas valve may not be opening due to a bad wire telling it to open, or the gas valve has failed.
Also, double check that the gas cutoff valves at the gas meter and the one next to the heater are open, valve handle in line with pipe. Closed, the handle is perpendicular to the pipe. They have been known to shut themselves!
Posted on Jan 19, 2013
SOURCE: Pool heater leakage
Chances are that the header or manifold is cracked. usually the heat exchanger themselves are not damaged from freeze, but either the rear manifold (header) or the front header (the one that pipes go in and out of). Sometimes both. Replacing the entire heater is not necessary, about $200 in parts usually. We have a schematic diagram of the LJ heater here: http://www.poolcenter.com/parts_heaters_lite2_lj_2003-present_pg1.htm
Rob Cox
POOLCENTER.com
Posted on Jan 28, 2009
SOURCE: Jandy Lite2 controller blinking and can't program
I had the same problem and a friend of mine told me that the board is shot and needs to be replaced. I got a new board and installed it just now and everything is working fine now. The back of the board looked a little fried. If you can take the board out which is connected by a ribbon cord and plug and 4 screws on front. It might be possibly fixed by an electronic person or else you will have to get a whole new board $275. Sorry
Posted on May 30, 2009
  • 246 Answers
SOURCE: How to fox flo 6 problem on Jandy lite2 175n pool heater
possible was the wron one I assume was the same one clean the filter clean the basket check for clog impeller
Posted on Sep 02, 2009
  • 246 Answers
SOURCE: Jandy Lite 2 LG Model not firing up. Was working during day
ok 24 v at the transformer is yes than a safety swicth turn the heater off check fuses
Posted on Oct 15, 2009
SOURCE: I have a Jandy Laars LX Pool-Spa Heater
You have a serious issue call a qualified heating or mechanical contractor sounds like a lock out or solenoid which is designed to shut off gas/flame for things like not blowing your backyard up is doing it's job. Or take the advice of a faceless stranger and hope you get it right 400,000 btu is about 7 x's the average home furnace so should be quite a boom
Posted on Apr 08, 2010
First of all when trying to ingite gas heater there was a igniting sound but no actual ignition of heater and now when trying to inginte heater there is no sound at all of ignition. the brand is a Jandy...
if hooked up 120 volt make sure to turn the power conversion board plug to 120 volt come wired for 220 volt if you didn't the ignitor isn't heating up enough make sure gas pressure is good also
Jul 25, 2010 | Jandy Laars Lite2 Ld 400,000 Btu Heater
Jandy Lite2 Pool heater will not stay lit after firing
If your persure is to high you are probally running propane in a natural gas heater. If this is a new heater take it back and get a new L.P. verson if not they make a conversion kit with new gas orfaces for the burner and a new gas block for the gas valve. if your tech dosen't know this get a new tech, this is a box full of fire next to your hause. Don't save money on the tech it can cost to much!
Jul 23, 2009 | Jandy Laars Lite2 Pool & Spa Heater -...
Describe your Jandy Laars Lite2 Pool & Spa Heater - Electronic Dual Ignition - 125,000 BT Problem FL 4 code and have changed igniter and still getting the FL4 code its the lite 2 model...
A. Check fuses on igniter wires. Identify and correct loose connections or broken wires. B. Measure room temperature resistance and ensure value is in the correct range. See manual for details. C. Replace igniter.
Jul 04, 2009 | Jandy Laars Lite2 Pool & Spa Heater -...
Jandy Lite2 flashing LCD display with number 113
Error showing 113 - Had pro check it out, all systems normal (voltages, gas, etc.). Spent $310 and ordered new control assembly from Amazon (pool store wanted $425) installed myself in under 2mins and heater works perfectly again. Zodiac R0366200 Heater Control Assembly Replacement for Zodiac Jandy Lite2LJ Pool and Spa Heater
Jun 11, 2009 | Zodiac JANDY LITE 125K BTU NATURAL GAS...
Jandy pool heater model #LT400N-L service and ES1 light blinking
The heater won't fire up if there is no or inadequate water flow. Ck water pump and filters.
Jun 01, 2009 | Jandy Lite2 LG400 Ceramic Compact Heater
Jandy Lite2 Pool heater will not stay lit after firing.
Look at the sensor that tells unit that everything is lit. There should be some sort of sensor that tells the ECU that the ingnition area is a burn temp. It sounds like the unit can't tell that flame is lit. Hope this helps.
May 17, 2009 | Jandy Laars Lite2 Pool & Spa Heater -...
Jandy LJ250N pool heater turns on - runs 10 minutes then stops
FL 2 is ignition failure,
If it ignites as you and the heat icon comes on, then it quits it sounds like you are losing gas pressure, no gas flow or it is to low, or air is in the gas line, if there is ignition then your flame sensor is not sensing the flame. or it needs to be replaced.
Apr 30, 2009 | Jandy Digital Lite2 Lj250 Btu Heater,...
Jandy Lite 2 Natural Gas Pilot Light Heater Logo
163 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
