Microsoft Xbox 360 Console Logo
Posted on Jan 15, 2013
Cannot connect xbox 360 to PC running vista
I am trying to connect my xbox 360 to my computer, which is running Vista. My computer recognizes the 360, but asks for a driver for the 360. My 360 on the other hand will not detect my computer at all. I have done searches all over the place and nothing is helping. Any advice?
Anonymous
Level 1:
New Friend:
  • Contributor 36 Answers
  • Posted on Jan 16, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
36
Questions
0
Helped
6160
Points
61
If you are just trying to share files from your PC to your 360 through Windows Media Center then you have activate the Windows Media Center Mode in your 360 settings and then use the code given and type it into your PC so that your PC shared files can be synced to your 360
5 Related Answers
A
Anonymous
  • Posted on Dec 18, 2007
SOURCE: Xbox 360 Cannot access Xbox Live
My son had the same problem with his xbox 360 and xbox 360 support told me that the prior owner did something illegal and the console has been banned permanently.
We are trying to get xbox 360 support to remove the code.
drlalitv
Lalit Varadpande
  • 488 Answers
  • Posted on Oct 31, 2008
SOURCE: hooking up media center w/ xbox 360
please look at the windows media player settings,click on library go to media sharing and enable the xbox..also check the type of network you configured..a private network will enable to share..look in the network and sharing settings for that..hope it helps! i had gone nuts when i had the same problem!!make sure that your computer is on the same network as the xbox.
Anonymous
  • Posted on Jan 05, 2009
SOURCE: My xbox 360 wont recieve a signal from my computer.
if your laptop get a signal than buy a eithernet cable and coonect your xbox 2 the laptop and go 2 your network settings and check the box that say share connection than wait a few mins. and try to connect to xboxlive this should work because thats how i get on xboxlive at my house.
[email protected]
Anonymous
  • 80 Answers
  • Posted on Mar 14, 2009
SOURCE: Help Microsoft Xbox 360 Wireless Receiver For Windows, help help
Hello my name is Tim Ehrhart, If the reciever is not lighting up then it is dead, you can try to take it to walmart and exchange it for a working one, they are usualy good at swapping out and if they give you a hard time buy a new one and return it with the old reciever instead of the new one. I hope this helps you.
Anonymous
  • Posted on Mar 28, 2009
SOURCE: Can't stream media through xbox 360 using WMP11
I had the same problem in Windows XP and I just created a workgroup to share files on the network. Follow these steps if anyone is still having this problem. My gf has vista and must do it automatically but it's just a matter of remembering to establish a workgroup.
To summarize:
- Enable sharing on WMP 11 --> This should adjust windows firewall automatically but be sure to unblock ports for other firewalls, if need be.
- Create a workgroup --> Start...Control Panel....Network setup wizard.
Follow the steps, if you're connectnig through a router, select "this computer connects through a residentail gateway", apply this to any other computers that want to share files on this network, if necessary.
Restart computer to let the workgroup settings take effect and voila...your computer will now be detected.
My madcatz xbox 360 controller will not connect to my compaq pc. The controller works and installs easily on my laptop. I have downloaded all necessary items from microsoft (xbox 360 controller for...
Vista has an issue with Xbox 360 controllers, let alone Madcatz copies. I would recommend buying an official wired controller for use with Vista. Alternatively you can you a Wireless Gaming Receiver specially designed for using Wireless Controllers on Windows based PC's.
tip
Configure XBOX with Media Center
Windows Media Center setup on your Xbox 360 Begin by connecting your Xbox 360 to your home network. The Introduction to Home Networking guide on the Xbox website will provide information if you're setting up a network for the first time or if you need some guidance for adding the Xbox 360 to your existing home network.
Once your Xbox 360 is connected to your network, begin the Windows Media Center setup process by pressing the green button on your remote control (if you have one), or use your game controller to select the Media Center option from the Media tab in the Xbox 360 on-screen menu.
You are asked if you want to connect your Xbox 360 to a PC running Windows Media Center in Windows Vista. Select the Media Center option to continue.
Once your Windows Vista-based PC has been detected, your Xbox 360 will display an eight-digit code. Write down this code on a piece of paper, and then go to your Windows Vista-based PC.
Note: When connecting to a Windows Vista-based PC, you do not need to select Continue or download additional software.
Add your Xbox 360 as an Extender to your Windows Vista-based PC Important: During the setup process, the Windows Firewall is automatically configured to enable your Windows Media Center Extender to connect to your Windows Vista-based PC. If you're using extra security software that includes a non-Microsoft firewall, you may need to manually configure your firewall to ensure a successful setup and connection.
With your eight-digit code in hand, begin by selecting Windows Media Center from the Start menu in Windows Vista. From the Windows Media Center menu, select Tasks, and then select Add Extender. This will begin a simple, step-by-step path that will add your Xbox 360 to your Windows Vista-based PC. During this setup process, you will be asked to provide the eight-digit setup key you received from your Xbox 360.
Click through this preview of the setup to familiarize yourself with the process.
The Extender Setup screen provides an introduction of the steps you'll go through to add an Extender to your Windows Vista-based PC. Click Next to start the process.
Enter the eight-digit setup key you received from your Xbox 360 (the one that you wrote down on your piece of paper, right?), and then click Next.
The setup process will need to make changes to your Windows Vista-based PC settings to establish the connection to the Xbox 360. Click Next to continue.
Review the information provided about Away Mode. Make your selection, and then click Next.
The setup process will ask if you would like to share media with the Extender. Select Yes (recommended) to share media folders, and then click Next. If you are using User Account Control, you'll see a User Account Control dialog box that will seek your permission to run the Windows Media Center Extender Configuration. Select Continue to grant permission.
Your PC will now go through the remaining steps to configure itself and establish the connection to your Xbox 360.
That's it! You're done! When you're finished with the PC setup, go back to your Xbox 360, and start enjoying access to all of the digital entertainment stored on your Windows Vista–based PC through your Xbox 360.
Optimize your home network The quality of your entertainment experience, especially video playback, is dependent on having a reliable and high-performance home network. To help ensure the best performance, we recommend that you run the Windows Media Center Extender Network Performance Tuner during the setup process on your PC. The Network Tuner provides very specific feedback on your network, as well as tips to solve any potential problems.
You can click through the preview of the Network Performance Tuner to familiarize yourself with the process.
The Network Performance Tuner runs diagnostics on your home network and provides feedback on potential issues that would make your Windows Media Center experience less than optimal.
When analyzing the network, the Network Tuner provides specific feedback based on all of the components connected to your network.
The Network Tuner provides feedback on the types of media that your network may have trouble handling effectively and suggests corrective actions than can help to solve the problem
The Network Tuner also looks for performance issues related to how your network is set up. In this case, the fact that the Windows Vista-based PC and the Xbox 360 are both connected wirelessly to the router may cause performance issues. You'll only see these warnings screens when the Network Tuner has detected a problem.
Real-time feedback is offered through the Network Tuner, so you can see if the adjustments you make to your network improve the performance.
Regards,
Shrey
on Dec 17, 2009 • Computers & Internet
Trying to get Xbox live connected...
Follow these steps if you are trying to use a laptop :
1.
Make sure that your XBOX 360 is fully functional and your laptop is connected to the internet by means of a wireless card.
2.
Locate the Ethernet cord and connect it to both the computer and XBOX 360. Don't turn on the XBOX 360 yet.
3.
On your Vista, click "Start" then "Network". After select the tab "Network and Sharing Center." On the left tab, click on "Manage network connections." You will see a Local Area Connection and a Wireless Internet Connection.
4.
Use your mouse to select both icons and right click. Click on Bridge Connections. Turn on your XBOX 360, Sign In, and you will find yourself connected to XBOX LIVE.
5.
Once you are done, and you need to use your computer for other uses. Simply right click on the Bridge Connection and select disable.
For more information on how to connect and use xbox go to the link below you will find all the details :
http://www.microsoft.com/windowsxp/using/networking/setup/xbox.mspx
Can't connect with network
if u dont hav e a router that is ur problem. to get ur xbox 360 to connect to vista media center you cannot connect an ethernet cord directly to ur 360, u must have ur computer hooked to a router with one ethernet cord and a whole different ethernet cord connecting to the same router the computers hooked up to. after you do that go to ur vista media center, turn active sharing on, make sure your router is connected to the internet. then go to ur xbox 360 and follow the on screen instruction from the the connect to media center screen.
if your wanting to connect to xbox live and stuff like that, and u enter ur ip address and security information and it tells u that the ip adress u entered is already in use by another device, and that ur xbox 360 needs to be assigned one, do this: simply go to were u put in ur ip address and set it to get the address automaticly (or in other words choose automatic). then go to test connection (ur router should automaticly assign ur xbox 360 an ip address) and ur router should connect to the internet. if it connects to the internet but not xbox live then u have not yet sign up for an xbox live account.
by the way when u make an xbox live account please send me a friend request. my xboxc live account name is: ghdude22
glad i could help!!! :3
Network Issues - XBox 360
make sure you having network sharing enabled on your computers
Xbox to pc connection
how do u connect the ethernet to ur lap top or do u have a wireless adapter?
World in conflict not running on vista
Grant me a while. Odds are you need a Vista Patch.
Xbox 360-computer?
To connect the Xbox 360 console to this computer, you must be running Windows XP Service Pack 2, Update Rollup 2 for Windows XP Media Center Edition 2005, or Windows Vista.
To obtain your setup package or instructions for connecting your Xbox 360, select the version of Windows installed on this computer from the following list.
To determine the version of Windows XP Media Center Edition that you are running, follow these steps:
  1. Start Media Center.
  2. On the Settings menu, click General.
  3. Scroll down, and then click About Media Center.
  4. Click Software Version
    The version number of Media Center you are running is displayed.
To determine the version of Windows XP that you are running, follow these steps:
  1. On the Start menu, right-click My Computer, and then click Properties.
  2. On the General tab, under System, look for the version of Windows that you are running.
Wuz up
Plug it in to your computer or Xbox? Your computer will only recognize the controller if you are running the Vista operating system or Windows XP
Xbox 360 to pc vga
You need to connect your xbox 360 to your monitors VGA port,not your graphics card. The VGA on the graphics cards are outputs for the PC.
Top Microsoft Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
ELECTRICKSUSA
ELECTRICKSUSA
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
